6424中断
6424的中断向量表在哪找的到啊
  • 你好,
    可以下面的intvecs.asm
    ; * Copyright (c) Texas Instruments Inc 2002, 2003, 2004, 2005, 2006, 2007
    ; * Use of this software is controlled by the terms and conditions found
    ; * in the license agreement under which this software has been supplied.
    ; * @brief Interrupt vector file for C64x and C64x+.
    ; * @file intvecs.asm
    ; * @verbatim
    ; This file contains interrupt service table. The CPU interrupt 4 vector
    ; contains interrupt4 function.
    ; @endverbatim
    ; Global symbols defined here and exported out of this file
    .global _intcVectorTable
    .global _c_int00
    .global _vector1
    .global _vector2
    .global _vector3
    .global _interrupt4
    .global _vector5
    .global _vector6
    .global _vector7
    .global _vector8
    .global _vector9
    .global _vector10
    .global _vector11
    .global _vector12
    .global _vector13
    .global _vector14
    .global _vector15
    ; This is a macro that instantiates one entry in the interrupt service table.
    VEC_ENTRY .macro addr
    STW B0,*--B15
    MVKL addr,B0
    MVKH addr,B0
    B B0
    LDW *B15++,B0
    NOP 2
    NOP
    NOP
    .endm
    ; This is a dummy interrupt service routine used to initialize the IST.
    _vec_dummy:
    B B3
    NOP 5
    ; This is the actual interrupt service table (IST).
    .sect ".vecs"
    .align 1024
    _intcVectorTable:
    _vector0: VEC_ENTRY _c_int00 ;RESET
    _vector1: VEC_ENTRY _vec_dummy ;NMI
    _vector2: VEC_ENTRY _vec_dummy ;RSVD
    _vector3: VEC_ENTRY _vec_dummy ;RSVD
    _vector4: VEC_ENTRY _interrupt4 ;Interrupt4 ISR
    _vector5: VEC_ENTRY _vec_dummy
    _vector6: VEC_ENTRY _vec_dummy
    _vector7: VEC_ENTRY _vec_dummy
    _vector8: VEC_ENTRY _vec_dummy
    _vector9: VEC_ENTRY _vec_dummy
    _vector10: VEC_ENTRY _vec_dummy
    _vector11: VEC_ENTRY _vec_dummy
    _vector12: VEC_ENTRY _vec_dummy
    _vector13: VEC_ENTRY _vec_dummy
    _vector14: VEC_ENTRY _vec_dummy
    _vector15: VEC_ENTRY _vec_dummy
    ;* Automated Revision Information
    ;* Changed: $Date: 2007-09-11 11:05:40 -0500 (Tue, 11 Sep 2007) $
    ;* Revision: $Revision: 3960 $
  • 我想设置6424的相关中断寄存器,有没有csl库怎么才能给csr里面的gie赋值啊
  • 你好,
    到下面的网站下载PSP, DM648_BIOSPSP_RELEASE_01_10_03\pspdrivers_1_10_03\packages\ti\sdo\pspdrivers\soc\c6424\examples\intc里面有中断例程。
    https://www-a.ti.com/downloads/sds_support/targetcontent/psp/bios_psp/index.html
