Other Parts Discussed in Thread: TPS40041
如标题,并且电源的设计余量足够,芯片散热也没有问题的前提下。
甚至是否可以把CVDD和CVDDC电源共用
不行, 这路电源必须保证使用调压AVS,这个在DM8168手册里面有要求的。
http://processors.wiki.ti.com/index.php/DM816x_Design_Resources#Requirements
AVS is required for DM816x devices. Using a fixed supply voltage level will violate max/min operating conditions for some devices which may fall at the edges of the process corners. This will in turn lead to long term reliability issues and may cause complete device failure.
