TDA4VM: MAX96722-BAK-EVK#驱动
Part Number: TDA4VM
您好
    我们需要在TDA4VM上使用MAX96722-BAK-EVK来实现环视,想咨询一下TI有提供驱动源码或者相关资料么?祝好!
  • 参考以下链接看一下:
    SRV_DEMO:software-dl.ti.com/.../SRV_DEMOS.html
  • 好的,多谢。TI有提供maxim解串器的驱动程序么,比如max9296,max96712
  • 你好,我们在尝试添加新的摄像头时(AR0147+MAX96705),按照添加新镜头的流程操作之后,编译安装成功后,运行vision_app_init.sh 正常无报错
    ./vision_apps_init.sh
    root@j7-evm:/opt/vision_apps# [MCU2_0]      4.363665 s: CIO: Init ... Done !!!
    [MCU2_0]      4.363736 s: ### CPU Frequency = 1000000000 Hz
    [MCU2_0]      4.363781 s: CPU is running FreeRTOS
    [MCU2_0]      4.363809 s: APP: Init ... !!!
    [MCU2_0]      4.363836 s: SCICLIENT: Init ... !!!
    [MCU2_0]      4.364093 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
    [MCU2_0]      4.364148 s: SCICLIENT: DMSC FW revision 0x8
    [MCU2_0]      4.364188 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU2_0]      4.364228 s: SCICLIENT: Init ... Done !!!
    [MCU2_0]      4.364260 s: UDMA: Init ... !!!
    [MCU2_0]      4.365611 s: UDMA: Init ... Done !!!
    [MCU2_0]      4.365677 s: MEM: Init ... !!!
    [MCU2_0]      4.365728 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ d9000000 of size 16777216 bytes !!!
    [MCU2_0]      4.365811 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 262144 bytes !!!
    [MCU2_0]      4.365876 s: MEM: Init ... Done !!!
    [MCU2_0]      4.365905 s: IPC: Init ... !!!
    [MCU2_0]      4.365972 s: IPC: 6 CPUs participating in IPC !!!
    [MCU2_0]      4.366025 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU2_0]     16.739668 s: IPC: HLOS is ready !!!
    [MCU2_0]     16.755284 s: IPC: Init ... Done !!!
    [MCU2_0]     16.755355 s: APP: Syncing with 5 CPUs ... !!!
    [MCU2_0]     16.966976 s: APP: Syncing with 5 CPUs ... Done !!!
    [MCU2_0]     16.967174 s: REMOTE_SERVICE: Init ... !!!
    [MCU2_0]     16.968843 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU2_0]     16.968913 s: ETHFW: Init ... !!!
    [MCU2_0]     16.974028 s: Warning: Using 6 MAC address(es) from static pool
    [MCU2_0]     16.974145 s: ETHFW: Shared multicasts (software fanout):
    [MCU2_0]     16.974193 s: ETHFW: Reserved multicasts:
    [MCU2_0]     16.974319 s:   01:80:c2:00:00:0e
    [MCU2_0]     16.974394 s:   01:1b:19:00:00:00
    [MCU2_0]     16.974663 s: EnetMcm: CPSW_9G on MAIN NAVSS
    [MCU2_0]     16.984169 s: Mdio_open: MDIO manual mode enabled
    [MCU2_0]     16.986986 s: PHY 0 is alive
    [MCU2_0]     16.987282 s: PHY 3 is alive
    [MCU2_0]     16.987931 s: PHY 12 is alive
    [MCU2_0]     16.988179 s: PHY 15 is alive
    [MCU2_0]     16.988289 s: PHY 16 is alive
    [MCU2_0]     16.988408 s: PHY 17 is alive
    [MCU2_0]     16.988524 s: PHY 18 is alive
    [MCU2_0]     16.988634 s: PHY 19 is alive
    [MCU2_0]     16.988934 s: PHY 23 is alive
    [MCU2_0]     16.990018 s: EnetPhy_bindDriver: PHY 12: OUI:080028 Model:23 Ver:01 <-> 'dp83867' : OK
    [MCU2_0]     16.990541 s: EnetPhy_bindDriver: PHY 0: OUI:080028 Model:23 Ver:01 <-> 'dp83867' : OK
    [MCU2_0]     16.991033 s: EnetPhy_bindDriver: PHY 3: OUI:080028 Model:23 Ver:01 <-> 'dp83867' : OK
    [MCU2_0]     16.991533 s: EnetPhy_bindDriver: PHY 15: OUI:080028 Model:23 Ver:01 <-> 'dp83867' : OK
    [MCU2_0]     16.993275 s:
    [MCU2_0] ETHFW Version   : 0.02.00
    [MCU2_0]     16.993352 s: ETHFW Build Date: Jul 24, 2023
    [MCU2_0]     16.993399 s: ETHFW Build Time: 17:46:51
    [MCU2_0]     16.993429 s: ETHFW Commit SHA:
    [MCU2_0]     16.993503 s: ETHFW: Init ... DONE !!!
    [MCU2_0]     16.993542 s: ETHFW: Remove server Init ... !!!
    [MCU2_0]     16.993731 s: CpswProxyServer: Virtual port configuration:
    [MCU2_0]     16.993791 s:   mpu_1_0 <-> Switch port 0: mpu_1_0_ethswitch-device-0
    [MCU2_0]     16.993841 s:   mcu_2_1 <-> Switch port 1: mcu_2_1_ethswitch-device-1
    [MCU2_0]     16.993887 s:   mpu_1_0 <-> MAC port 1: mpu_1_0_ethmac-device-1
    [MCU2_0]     16.993929 s:   mcu_2_1 <-> MAC port 4: mcu_2_1_ethmac-device-4
    [MCU2_0]     16.994958 s: CpswProxyServer: initialization completed (core: mcu2_0)
    [MCU2_0]     16.995030 s: ETHFW: Remove server Init ... DONE !!!
    [MCU2_0]     16.996209 s: Starting lwIP, local interface IP is dhcp-enabled
    [MCU2_0]     17.004408 s: Host MAC address: 70:ff:76:1d:92:c3
    [MCU2_0]     17.008721 s: [LWIPIF_LWIP] Enet LLD netif initialized successfully
    [MCU2_0]     17.008814 s: Added interface 'ti1', IP is 0.0.0.0
    [MCU2_0]     17.044388 s: FVID2: Init ... !!!
    [MCU2_0]     17.044499 s: FVID2: Init ... Done !!!
    [MCU2_0]     17.044560 s: DSS: Init ... !!!
    [MCU2_0]     17.044589 s: DSS: Display type is eDP !!!
    [MCU2_0]     17.044618 s: DSS: M2M Path is enabled !!!
    [MCU2_0]     17.044648 s: DSS: SoC init ... !!!
    [MCU2_0]     17.044675 s: SCICLIENT: Sciclient_pmSetModuleState module=152 state=2
    [MCU2_0]     17.044905 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     17.044948 s: SCICLIENT: Sciclient_pmSetModuleState module=297 state=2
    [MCU2_0]     17.045157 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     17.045196 s: SCICLIENT: Sciclient_pmSetModuleState module=151 state=2
    [MCU2_0]     17.045353 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     17.045503 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=9 parent=11
    [MCU2_0]     17.045651 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
    [MCU2_0]     17.045697 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=13 parent=18
    [MCU2_0]     17.045823 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
    [MCU2_0]     17.045862 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=1 parent=2
    [MCU2_0]     17.045969 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
    [MCU2_0]     17.046009 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=152 clk=1 freq=148500000
    [MCU2_0]     17.047240 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success
    [MCU2_0]     17.047291 s: SCICLIENT: Sciclient_pmModuleClkRequest module=152 clk=1 state=2 flag=0
    [MCU2_0]     17.047528 s: SCICLIENT: Sciclient_pmModuleClkRequest success
    [MCU2_0]     17.047577 s: DSS: SoC init ... Done !!!
    [MCU2_0]     17.047608 s: DSS: Board init ... !!!
    [MCU2_0]     17.047636 s: DSS: Board init ... Done !!!
    [MCU2_0]     17.067570 s: DSS: Init ... Done !!!
    [MCU2_0]     17.067639 s: VHWA: VPAC Init ... !!!
    [MCU2_0]     17.067674 s: SCICLIENT: Sciclient_pmSetModuleState module=290 state=2
    [MCU2_0]     17.067888 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     17.067934 s: VHWA: LDC Init ... !!!
    [MCU2_0]     17.071981 s: VHWA: LDC Init ... Done !!!
    [MCU2_0]     17.072050 s: VHWA: MSC Init ... !!!
    [MCU2_0]     17.085121 s: VHWA: MSC Init ... Done !!!
    [MCU2_0]     17.085192 s: VHWA: NF Init ... !!!
    [MCU2_0]     17.087180 s: VHWA: NF Init ... Done !!!
    [MCU2_0]     17.087250 s: VHWA: VISS Init ... !!!
    [MCU2_0]     17.099544 s: VHWA: VISS Init ... Done !!!
    [MCU2_0]     17.099610 s: VHWA: VPAC Init ... Done !!!
    [MCU2_0]     17.099661 s:  VX_ZONE_INIT:Enabled
    [MCU2_0]     17.099697 s:  VX_ZONE_ERROR:Enabled
    [MCU2_0]     17.099729 s:  VX_ZONE_WARNING:Enabled
    [MCU2_0]     17.101350 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-0
    [MCU2_0]     17.101786 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_NF
    [MCU2_0]     17.102049 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_LDC1
    [MCU2_0]     17.102307 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC1
    [MCU2_0]     17.102750 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC2
    [MCU2_0]     17.103037 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_VISS1
    [MCU2_0]     17.103321 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE1
    [MCU2_0]     17.103726 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE2
    [MCU2_0]     17.104002 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY1
    [MCU2_0]     17.104263 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY2
    [MCU2_0]     17.104632 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CSITX
    [MCU2_0]     17.104927 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE3
    [MCU2_0]     17.105190 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE4
    [MCU2_0]     17.105572 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE5
    [MCU2_0]     17.105869 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE6
    [MCU2_0]     17.106151 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE7
    [MCU2_0]     17.106537 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE8
    [MCU2_0]     17.106813 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M1
    [MCU2_0]     17.107062 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M2
    [MCU2_0]     17.107294 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M3
    [MCU2_0]     17.107719 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M4
    [MCU2_0]     17.107783 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
    [MCU2_0]     17.107823 s: APP: OpenVX Target kernel init ... !!!
    [MCU2_0]     17.130711 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU2_0]     17.130778 s: CSI2RX: Init ... !!!
    [MCU2_0]     17.130809 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2
    [MCU2_0]     17.130950 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     17.130994 s: SCICLIENT: Sciclient_pmSetModuleState module=26 state=2
    [MCU2_0]     17.131193 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     17.131232 s: SCICLIENT: Sciclient_pmSetModuleState module=27 state=2
    [MCU2_0]     17.131473 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     17.131528 s: SCICLIENT: Sciclient_pmSetModuleState module=147 state=2
    [MCU2_0]     17.131648 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     17.131694 s: SCICLIENT: Sciclient_pmSetModuleState module=148 state=2
    [MCU2_0]     17.131795 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     17.132050 s: CSI2RX: Init ... Done !!!
    [MCU2_0]     17.132098 s: CSI2TX: Init ... !!!
    [MCU2_0]     17.132129 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2
    [MCU2_0]     17.132233 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     17.132275 s: SCICLIENT: Sciclient_pmSetModuleState module=28 state=2
    [MCU2_0]     17.132486 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     17.132540 s: SCICLIENT: Sciclient_pmSetModuleState module=296 state=2
    [MCU2_0]     17.132689 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     17.132792 s: CSI2TX: Init ... Done !!!
    [MCU2_0]     17.132833 s: ISS: Init ... !!!
    [MCU2_0]     17.132876 s: IssSensor_Init ... Done !!!
    [MCU2_0]     17.132962 s: IttRemoteServer_Init ... Done !!!
    [MCU2_0]     17.133005 s: VISS REMOTE SERVICE: Init ... !!!
    [MCU2_0]     17.133078 s: VISS REMOTE SERVICE: Init ... Done !!!
    [MCU2_0]     17.133115 s: UDMA Copy: Init ... !!!
    [MCU2_0]     17.135162 s: UDMA Copy: Init ... Done !!!
    [MCU2_0]     17.135279 s: APP: Init ... Done !!!
    [MCU2_0]     17.135323 s: APP: Run ... !!!
    [MCU2_0]     17.135355 s: IPC: Starting echo test ...
    [MCU2_0]     17.138695 s: APP: Run ... Done !!!
    [MCU2_0]     17.140544 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[P] C66X_2[.] C7X_1[.]
    [MCU2_0]     17.140674 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[P] C66X_2[P] C7X_1[.]
    [MCU2_0]     17.140773 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[.]
    [MCU2_0]     17.140863 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[P]
    [MCU2_0]     17.346145 s: Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:6
    [MCU2_0]     17.654891 s: Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:6
    [MCU2_0]     20.800564 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a3a4b034,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c2, FlowIdx:173, FlowIdxOffset:1
    [MCU2_0]     20.842918 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a4b034,CoreKey:38acb7e6,mode:disable
    [MCU2_0]     20.843469 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a4b034,CoreKey:38acb7e6,mode:disable
    [MCU2_0]     20.844332 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a4b034,CoreKey:38acb7e6,mode:disable
    [MCU2_0]     20.859187 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a3a4b034,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1, FlowIdx:172, FlowIdxOffset:0
    [MCU2_0]     20.862441 s: Cpsw_ioctlInternal: CPSW: Registered MAC address. ALE entry:11, Policer Entry:2
    [MCU2_0]     20.899843 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a4b034,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:1, vlanId:0, FlowIdx:172, FlowIdOffset:0
    [MCU2_0]     20.903489 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a4b034,CoreKey:38acb7e6, MacAddress:1:0:5e:0:0:1, vlanId:0, FlowIdx:172, FlowIdOffset:0
    [MCU2_0]     20.907048 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a4b034,CoreKey:38acb7e6, MacAddress:33:33:ff:1d:92:c1, vlanId:0, FlowIdx:172, FlowIdOffset:0
    [MCU2_0]     21.021580 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a4b034,CoreKey:38acb7e6,mode:disable
    [MCU2_0]     21.021886 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a4b034,CoreKey:38acb7e6,mode:disable
    [MCU2_0]     21.037972 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a4b034,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:0, vlanId:0, FlowIdx:172, FlowIdOffset:0
    [MCU2_0]     21.041521 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a4b034,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:3, vlanId:0, FlowIdx:172, FlowIdOffset:0
    [MCU2_0]     21.045002 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a4b034,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:e, vlanId:0, FlowIdx:172, FlowIdOffset:0
    [MCU2_0]     21.045159 s: CpswProxyServer_isRsvdMcast: Reserved mcast cannot be added to filter
    [MCU2_0]     21.222091 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a4b034,CoreKey:38acb7e6,mode:disable
    [MCU2_0]     21.222282 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a4b034,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:fb, vlanId:0, FlowIdx:172, FlowIdOffset:0
    [MCU2_0]     22.415480 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a4b034,CoreKey:38acb7e6, MacAddress:33:33:0:1:0:3, vlanId:0, FlowIdx:172, FlowIdOffset:0
    [MCU2_0]     22.672345 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a4b034,CoreKey:38acb7e6,mode:disable
    [MCU2_1]      4.310311 s: CIO: Init ... Done !!!
    [MCU2_1]      4.310382 s: ### CPU Frequency = 1000000000 Hz
    [MCU2_1]      4.310423 s: CPU is running FreeRTOS
    [MCU2_1]      4.310451 s: APP: Init ... !!!
    [MCU2_1]      4.310476 s: SCICLIENT: Init ... !!!
    [MCU2_1]      4.310720 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
    [MCU2_1]      4.310769 s: SCICLIENT: DMSC FW revision 0x8
    [MCU2_1]      4.310803 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU2_1]      4.310854 s: SCICLIENT: Init ... Done !!!
    [MCU2_1]      4.310884 s: UDMA: Init ... !!!
    [MCU2_1]      4.312313 s: UDMA: Init ... Done !!!
    [MCU2_1]      4.312379 s: MEM: Init ... !!!
    [MCU2_1]      4.312423 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ da000000 of size 16777216 bytes !!!
    [MCU2_1]      4.312500 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 3640000 of size 262144 bytes !!!
    [MCU2_1]      4.312565 s: MEM: Init ... Done !!!
    [MCU2_1]      4.312591 s: IPC: Init ... !!!
    [MCU2_1]      4.312656 s: IPC: 6 CPUs participating in IPC !!!
    [MCU2_1]      4.312723 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU2_1]     16.951363 s: IPC: HLOS is ready !!!
    [MCU2_1]     16.966857 s: IPC: Init ... Done !!!
    [MCU2_1]     16.966925 s: APP: Syncing with 5 CPUs ... !!!
    [MCU2_1]     16.966974 s: APP: Syncing with 5 CPUs ... Done !!!
    [MCU2_1]     16.967012 s: REMOTE_SERVICE: Init ... !!!
    [MCU2_1]     16.968781 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU2_1]     16.968860 s: FVID2: Init ... !!!
    [MCU2_1]     16.968935 s: FVID2: Init ... Done !!!
    [MCU2_1]     16.968972 s: VHWA: DMPAC: Init ... !!!
    [MCU2_1]     16.968998 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2
    [MCU2_1]     16.969481 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_1]     16.969524 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2
    [MCU2_1]     16.969982 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_1]     16.970019 s: VHWA: DOF Init ... !!!
    [MCU2_1]     16.978687 s: VHWA: DOF Init ... Done !!!
    [MCU2_1]     16.978756 s: VHWA: SDE Init ... !!!
    [MCU2_1]     16.981557 s: VHWA: SDE Init ... Done !!!
    [MCU2_1]     16.981616 s: VHWA: DMPAC: Init ... Done !!!
    [MCU2_1]     16.981664 s:  VX_ZONE_INIT:Enabled
    [MCU2_1]     16.981698 s:  VX_ZONE_ERROR:Enabled
    [MCU2_1]     16.981729 s:  VX_ZONE_WARNING:Enabled
    [MCU2_1]     16.983192 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-1
    [MCU2_1]     16.983433 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_SDE
    [MCU2_1]     16.983659 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_DOF
    [MCU2_1]     16.983717 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
    [MCU2_1]     16.983753 s: APP: OpenVX Target kernel init ... !!!
    [MCU2_1]     16.984048 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU2_1]     16.984090 s: UDMA Copy: Init ... !!!
    [MCU2_1]     16.986146 s: UDMA Copy: Init ... Done !!!
    [MCU2_1]     16.986215 s: APP: Init ... Done !!!
    [MCU2_1]     16.986247 s: APP: Run ... !!!
    [MCU2_1]     16.986270 s: IPC: Starting echo test ...
    [MCU2_1]     16.988843 s: APP: Run ... Done !!!
    [MCU2_1]     16.990029 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[.] C7X_1[.]
    [MCU2_1]     16.990149 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[.]
    [MCU2_1]     16.990245 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P]
    [MCU2_1]     17.140162 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P]
    [C6x_1 ]      4.371034 s: CIO: Init ... Done !!!
    [C6x_1 ]      4.371059 s: ### CPU Frequency = 1350000000 Hz
    [C6x_1 ]      4.371068 s: CPU is running FreeRTOS
    [C6x_1 ]      4.371076 s: APP: Init ... !!!
    [C6x_1 ]      4.371084 s: SCICLIENT: Init ... !!!
    [C6x_1 ]      4.371281 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
    [C6x_1 ]      4.371293 s: SCICLIENT: DMSC FW revision 0x8
    [C6x_1 ]      4.371302 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C6x_1 ]      4.371311 s: SCICLIENT: Init ... Done !!!
    [C6x_1 ]      4.371321 s: UDMA: Init ... !!!
    [C6x_1 ]      4.372759 s: UDMA: Init ... Done !!!
    [C6x_1 ]      4.372777 s: MEM: Init ... !!!
    [C6x_1 ]      4.372789 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ dc000000 of size 16777216 bytes !!!
    [C6x_1 ]      4.372806 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!!
    [C6x_1 ]      4.372822 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ dd000000 of size 50331648 bytes !!!
    [C6x_1 ]      4.372838 s: MEM: Init ... Done !!!
    [C6x_1 ]      4.372846 s: IPC: Init ... !!!
    [C6x_1 ]      4.372866 s: IPC: 6 CPUs participating in IPC !!!
    [C6x_1 ]      4.372880 s: IPC: Waiting for HLOS to be ready ... !!!
    [C6x_1 ]     16.087209 s: IPC: HLOS is ready !!!
    [C6x_1 ]     16.090964 s: IPC: Init ... Done !!!
    [C6x_1 ]     16.090992 s: APP: Syncing with 5 CPUs ... !!!
    [C6x_1 ]     16.966974 s: APP: Syncing with 5 CPUs ... Done !!!
    [C6x_1 ]     16.966986 s: REMOTE_SERVICE: Init ... !!!
    [C6x_1 ]     16.967660 s: REMOTE_SERVICE: Init ... Done !!!
    [C6x_1 ]     16.967699 s:  VX_ZONE_INIT:Enabled
    [C6x_1 ]     16.967709 s:  VX_ZONE_ERROR:Enabled
    [C6x_1 ]     16.967719 s:  VX_ZONE_WARNING:Enabled
    [C6x_1 ]     16.968548 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
    [C6x_1 ]     16.968562 s: APP: OpenVX Target kernel init ... !!!
    [C6x_1 ]     16.968828 s: APP: OpenVX Target kernel init ... Done !!!
    [C6x_1 ]     16.968843 s: UDMA Copy: Init ... !!!
    [C6x_1 ]     16.972957 s: UDMA Copy: Init ... Done !!!
    [C6x_1 ]     16.972980 s: APP: Init ... Done !!!
    [C6x_1 ]     16.972989 s: APP: Run ... !!!
    [C6x_1 ]     16.972998 s: IPC: Starting echo test ...
    [C6x_1 ]     16.974142 s: APP: Run ... Done !!!
    [C6x_1 ]     16.974485 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[.]
    [C6x_1 ]     16.974519 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[P]
    [C6x_1 ]     16.989389 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P]
    [C6x_1 ]     17.139345 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P]
    [C6x_2 ]      4.457176 s: CIO: Init ... Done !!!
    [C6x_2 ]      4.457201 s: ### CPU Frequency = 1350000000 Hz
    [C6x_2 ]      4.457211 s: CPU is running FreeRTOS
    [C6x_2 ]      4.457219 s: APP: Init ... !!!
    [C6x_2 ]      4.457226 s: SCICLIENT: Init ... !!!
    [C6x_2 ]      4.457424 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
    [C6x_2 ]      4.457437 s: SCICLIENT: DMSC FW revision 0x8
    [C6x_2 ]      4.457446 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C6x_2 ]      4.457456 s: SCICLIENT: Init ... Done !!!
    [C6x_2 ]      4.457466 s: UDMA: Init ... !!!
    [C6x_2 ]      4.458944 s: UDMA: Init ... Done !!!
    [C6x_2 ]      4.458964 s: MEM: Init ... !!!
    [C6x_2 ]      4.458977 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e0000000 of size 16777216 bytes !!!
    [C6x_2 ]      4.458993 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!!
    [C6x_2 ]      4.459009 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e1000000 of size 50331648 bytes !!!
    [C6x_2 ]      4.459025 s: MEM: Init ... Done !!!
    [C6x_2 ]      4.459033 s: IPC: Init ... !!!
    [C6x_2 ]      4.459054 s: IPC: 6 CPUs participating in IPC !!!
    [C6x_2 ]      4.459067 s: IPC: Waiting for HLOS to be ready ... !!!
    [C6x_2 ]     16.413093 s: IPC: HLOS is ready !!!
    [C6x_2 ]     16.416812 s: IPC: Init ... Done !!!
    [C6x_2 ]     16.416838 s: APP: Syncing with 5 CPUs ... !!!
    [C6x_2 ]     16.966974 s: APP: Syncing with 5 CPUs ... Done !!!
    [C6x_2 ]     16.966986 s: REMOTE_SERVICE: Init ... !!!
    [C6x_2 ]     16.967669 s: REMOTE_SERVICE: Init ... Done !!!
    [C6x_2 ]     16.967705 s:  VX_ZONE_INIT:Enabled
    [C6x_2 ]     16.967715 s:  VX_ZONE_ERROR:Enabled
    [C6x_2 ]     16.967725 s:  VX_ZONE_WARNING:Enabled
    [C6x_2 ]     16.968554 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
    [C6x_2 ]     16.968568 s: APP: OpenVX Target kernel init ... !!!
    [C6x_2 ]     16.968827 s: APP: OpenVX Target kernel init ... Done !!!
    [C6x_2 ]     16.968842 s: UDMA Copy: Init ... !!!
    [C6x_2 ]     16.972591 s: UDMA Copy: Init ... Done !!!
    [C6x_2 ]     16.972613 s: APP: Init ... Done !!!
    [C6x_2 ]     16.972622 s: APP: Run ... !!!
    [C6x_2 ]     16.972630 s: IPC: Starting echo test ...
    [C6x_2 ]     16.973654 s: APP: Run ... Done !!!
    [C6x_2 ]     16.973971 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[x] C66X_2[s] C7X_1[P]
    [C6x_2 ]     16.974478 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[P]
    [C6x_2 ]     16.989417 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P]
    [C6x_2 ]     17.139379 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P]
    [C7x_1 ]      4.683850 s: CIO: Init ... Done !!!
    [C7x_1 ]      4.683865 s: ### CPU Frequency = 1000000000 Hz
    [C7x_1 ]      4.683877 s: CPU is running FreeRTOS
    [C7x_1 ]      4.683885 s: APP: Init ... !!!
    [C7x_1 ]      4.683892 s: SCICLIENT: Init ... !!!
    [C7x_1 ]      4.684104 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
    [C7x_1 ]      4.684119 s: SCICLIENT: DMSC FW revision 0x8
    [C7x_1 ]      4.684128 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C7x_1 ]      4.684139 s: SCICLIENT: Init ... Done !!!
    [C7x_1 ]      4.684148 s: UDMA: Init ... !!!
    [C7x_1 ]      4.685283 s: UDMA: Init ... Done !!!
    [C7x_1 ]      4.685295 s: MEM: Init ... !!!
    [C7x_1 ]      4.685306 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 117000000 of size 268435456 bytes !!!
    [C7x_1 ]      4.685326 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70020000 of size 8159232 bytes !!!
    [C7x_1 ]      4.685345 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 458752 bytes !!!
    [C7x_1 ]      4.685362 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!!
    [C7x_1 ]      4.685379 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 100000000 of size 385875968 bytes !!!
    [C7x_1 ]      4.685397 s: MEM: Init ... Done !!!
    [C7x_1 ]      4.685405 s: IPC: Init ... !!!
    [C7x_1 ]      4.685419 s: IPC: 6 CPUs participating in IPC !!!
    [C7x_1 ]      4.685432 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_1 ]     16.790180 s: IPC: HLOS is ready !!!
    [C7x_1 ]     16.792168 s: IPC: Init ... Done !!!
    [C7x_1 ]     16.792182 s: APP: Syncing with 5 CPUs ... !!!
    [C7x_1 ]     16.966975 s: APP: Syncing with 5 CPUs ... Done !!!
    [C7x_1 ]     16.966992 s: REMOTE_SERVICE: Init ... !!!
    [C7x_1 ]     16.967144 s: REMOTE_SERVICE: Init ... Done !!!
    [C7x_1 ]     16.967167 s:  VX_ZONE_INIT:Enabled
    [C7x_1 ]     16.967179 s:  VX_ZONE_ERROR:Enabled
    [C7x_1 ]     16.967189 s:  VX_ZONE_WARNING:Enabled
    [C7x_1 ]     16.967354 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1
    [C7x_1 ]     16.967452 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_2
    [C7x_1 ]     16.967555 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_3
    [C7x_1 ]     16.967627 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_4
    [C7x_1 ]     16.967697 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_5
    [C7x_1 ]     16.967800 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_6
    [C7x_1 ]     16.967919 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_7
    [C7x_1 ]     16.967986 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_8
    [C7x_1 ]     16.968008 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
    [C7x_1 ]     16.968021 s: APP: OpenVX Target kernel init ... !!!
    [C7x_1 ]     16.968161 s: APP: OpenVX Target kernel init ... Done !!!
    [C7x_1 ]     16.968175 s: APP: Init ... Done !!!
    [C7x_1 ]     16.968185 s: APP: Run ... !!!
    [C7x_1 ]     16.968194 s: IPC: Starting echo test ...
    [C7x_1 ]     16.968351 s: APP: Run ... Done !!!
    [C7x_1 ]     16.973973 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[x] C66X_2[P] C7X_1[s]
    [C7x_1 ]     16.974491 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s]
    [C7x_1 ]     16.989441 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
    [C7x_1 ]     17.140159 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
    运行run_app_single_cam.sh异常,选择Select camera port index 0-11:0 选项sensor drivers:g,对应新增加的摄像头AR0147
    ./run_app_single_cam.sh
    APP: Init ... !!!
    MEM: Init ... !!!
    MEM: Initialized DMA HEAP (fd=4) !!!
    IPC: Init ... !!!
       587.979991 s: GTC Frequency = 200 MHz
       587.983198 s:  VX_ZONE_INIT:Enabled
       587.983207 s:  VX_ZONE_ERROR:Enabled
       587.983212 s:  VX_ZONE_WARNING:Enabled
       587.983959 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
       587.984952 s:  VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!!
    sensor_selection = [0]
    ldc_enable = [0]
    num_frames_to_run = [1000000000]
    is_interactive = [1]
    IttCtrl_registerHandler: command echo registered at location 0
    IttCtrl_registerHandler: command iss_read_2a_params registered at location 1
    IttCtrl_registerHandler: command iss_write_2a_params registered at location 2
    IttCtrl_registerHandler: command iss_raw_save registered at location 3
    IttCtrl_registerHandler: command iss_yuv_save registered at location 4
    IttCtrl_registerHandler: command iss_read_sensor_reg registered at location 5
    IttCtrl_registerHandler: command iss_write_sensor_reg registered at location 6
    IttCtrl_registerHandler: command dev_ctrl registered at location 7
    IttCtrl_registerHandler: command iss_send_dcc_file registered at location 8
     NETWORK: Opened at IP Addr = 192.168.108.42, socket port=5000!!!
       587.994616 s: ISS: Enumerating sensors ... !!!
    [MCU2_0]    588.194483 s: Error writing to TCA6408 register 0x3
       588.395143 s: ISS: Enumerating sensors ... found 0 : IMX390-UB953_D3
       588.395157 s: ISS: Enumerating sensors ... found 1 : AR0233-UB953_MARS
       588.395178 s: ISS: Enumerating sensors ... found 2 : AR0820-UB953_LI
       588.395183 s: ISS: Enumerating sensors ... found 3 : UB9xxx_RAW12_TESTPATTERN
       588.395189 s: ISS: Enumerating sensors ... found 4 : UB96x_UYVY_TESTPATTERN
       588.395194 s: ISS: Enumerating sensors ... found 5 : GW_AR0233_UYVY
       588.395199 s: ISS: Enumerating sensors ... found 6 : AR0147-MAX96705_UYUV
    Select camera port index 0-11 : [MCU2_0]    588.394439 s: rawtestpat_PowerOn Error : initFusion2_UB97x returned 0xffffffff
    [MCU2_0]    588.394581 s: Error writing 0x2 to UB960 register 0x1
    [MCU2_0]    588.394645 s:  UB960 Error: Reg Write Failed for regAddr 1, cnt = 0
    [MCU2_0]    588.394706 s: Error : ub960_cfgScript returned -1 while configuring DES 0
    [MCU2_0]    588.394812 s: Error writing 0x2 to UB960 register 0x1
    [MCU2_0]    588.394875 s:  UB960 Error: Reg Write Failed for regAddr 1, cnt = 0
    [MCU2_0]    588.394932 s: Error :  returned -1 while configuring DES 1
    0
    7 registered sensor drivers
    a : IMX390-UB953_D3
    b : AR0233-UB953_MARS
    c : AR0820-UB953_LI
    d : UB9xxx_RAW12_TESTPATTERN
    e : UB96x_UYVY_TESTPATTERN
    f : GW_AR0233_UYVY
    g : AR0147-MAX96705_UYUV
    Select a sensor above or press '0' to autodetect the sensor : Invalid selection
    . Try again
    a : IMX390-UB953_D3
    c : AR0820-UB953_LI
    f : GW_AR0233_UYVY
    Select a sensor above or press '0' to autodetect the sensor : g
    Sensor selected : AR0147-MAX96705_UYUV
    LDC Selection Yes(1)/No(0) : LDC Selection Yes(1)/No(0) : 1
    Querying AR0147-MAX96705_UYUV
       878.010421 s: ISS: Querying sensor [AR0147-MAX96705_UYUV] ... !!!
       878.010792 s: ISS: Querying sensor [AR0147-MAX96705_UYUV] ... Done !!!
       878.010802 s: ISS: Initializing sensor [AR0147-MAX96705_UYUV], doing IM_SENSOR_CMD_PWRON ... !!!
       878.011095 s: ISS: Initializing sensor [AR0147-MAX96705_UYUV], doing IM_SENSOR_CMD_CONFIG ... !!!
       878.012491 s: ISS: ERROR: Initializing sensor [AR0147-MAX96705_UYUV] failed !!!
       878.012498 s: ISS: Initializing sensor [AR0147-MAX96705_UYUV] ... Done !!!
    Error initializing sensor AR0147-MAX96705_UYUV
    [MCU2_0]    878.011439 s: Error writing 0x1 to UB960 register 0x4c
    [MCU2_0]    878.011522 s:  UB960 Error: Reg Write Failed for regAddr 4c, cnt = 0
    [MCU2_0]    878.011638 s: Error writing 0x1 to UB960 register 0x4c
    [MCU2_0]    878.011700 s:  UB960 Error: Reg Write Failed for regAddr 4c, cnt = 0
    [MCU2_0]    878.011807 s: Error writing 0x1 to UB960 register 0x4c
    [MCU2_0]    878.011872 s:  UB960 Error: Reg Write Failed for regAddr 4c, cnt = 0
    [MCU2_0]    878.011981 s: Error reading from UB960 register 0x4c
    [MCU2_0]    878.012085 s: Error writing 0x1 to UB960 register 0x4c
    [MCU2_0]    878.012146 s:  UB960 Error: Reg Write Failed for regAddr 4c, cnt = 0
    [MCU2_0]    878.012213 s: AR0147_Probe Error : UB960_SetSensorAlias for chId 0 returned -1
    [MCU2_0]    878.012273 s: Error : sensor probe failed for channel 0
    Test data path is NULL. Defaulting to current folder
    read_test_image_raw : Unable to open file .//img_test.raw
    app_create_viss : sensor_dcc_id = 233
    Invalid DCC size for VISS. Disabling DCC
    Invalid DCC size for 2A. Disabling DCC
    Enabling LDC
    Creating LDC
    Invalid DCC size for LDC. Disabling DCC
    [MCU2_0]    878.042906 s:  VX_ZONE_WARNING:[tivxVpacVissCreate:377] VISS H3A output is not generated due to DCC not being enabled
    [MCU2_0]    878.049650 s:  VX_ZONE_WARNING:[tivxAewbCreate:1073] No DCC buffer passed. Disabling 2A
    Scaler is enabled
       878.067566 s: ISS: Starting sensor [AR0147-MAX96705_UYUV] ... !!!
    [MCU2_0]    878.068205 s:  Error writing 0x1 to UB960 register 0x4c
    [MCU2_0]    878.068285 s:  UB960 Error: Reg Write Failed for regAddr 4c, cnt = 0
    [MCU2_0]    878.068469 s: Error writing 0x1 to UB960 register 0x4c
    [MCU2_0]    878.068540 s:  UB960 Error: Reg Write Failed for regAddr 4c, cnt = 0
    [MCU2_0]    878.068652 s: Error writing 0x1 to UB960 register 0x4c
    [MCU2_0]    878.068714 s:  UB960 Error: Reg Write Failed for regAddr 4c, cnt = 0
       878.078793 s: ISS: Starting sensor [AR0147-MAX96705_UYUV] failed !!!
    Failed to start sensor AR0147-MAX96705_UYUV
    Defaulting to file test mode
    get_dcc_dir_size : Could not open directory or directory is empty /opt/vision_apps/dcc/AR0147-MAX96705_UYUV/wdr
     Demo : Single Camera w/ 2A
     p: Print performance statistics
     s: Save Sensor RAW, VISS Output and H3A output images to File System
     e: Export performance statistics
     u: Update DCC from File System
     x: Exit
     Enter Choice:
    Unsupported command
     x: Exit
     Enter Choice: [MCU2_0]    878.078477 s: Error writing 0x3 to UB960 register 0x33
    [MCU2_0]    878.078549 s:  UB960 Error: Reg Write Failed for regAddr 33, cnt = 0
    [MCU2_0]    878.078610 s: Error : Failed to start sensor at channel Id 0
    [MCU2_0]    878.581780 s: Warning : h_skip = 0. Setting to 1 to avoid divide by zero error
    [MCU2_0]    878.581872 s: Warning : v_skip = 0. Setting to 1 to avoid divide by zero error
    [MCU2_0]    878.581954 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    878.582013 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    878.614231 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    878.614307 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    878.647217 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    878.647295 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    878.680211 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    878.680286 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    878.713206 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    878.713279 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    878.746190 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    878.746272 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    878.779207 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    878.779281 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    878.812220 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    878.812292 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    878.845210 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    878.845283 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    878.878194 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    878.878272 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    878.911221 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    878.911297 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    878.944225 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    878.944299 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    878.977204 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    878.977276 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.010227 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.010304 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.043201 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.043282 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.076212 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.076289 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.109226 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.109304 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.142222 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.142294 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.175212 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.175285 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.208223 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.208297 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.241205 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.241282 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.274207 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.274276 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.307222 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.307294 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.340207 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.340284 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.373208 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.373286 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.406238 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.406312 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.439202 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.439275 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.472205 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.472279 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.505221 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.505295 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.538205 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.538281 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.571224 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.571299 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.604237 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.604311 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.637223 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.637301 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.670290 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.670511 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.703299 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.703504 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.736239 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.736320 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.769225 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.769302 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.802231 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.802304 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.835210 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.835285 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.868265 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.868340 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.901304 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.901523 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.934308 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.934525 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    879.967207 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    879.967280 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    880.000215 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    880.000289 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    880.033208 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    880.033282 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    880.066201 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    880.066272 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    880.099223 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    880.099300 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    880.132213 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    880.132285 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    880.165218 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    880.165294 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    880.198212 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    880.198284 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    880.231210 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    880.231281 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    880.264203 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    880.264281 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    880.297248 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    880.297326 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    880.330222 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    880.330294 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    880.363202 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    880.363278 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    880.396222 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    880.396299 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    880.429205 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    880.429281 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    880.462217 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    880.462291 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    880.495222 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    880.495296 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    880.528201 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    880.528273 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    880.561209 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    880.561284 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    880.594223 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    880.594299 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    [MCU2_0]    880.627201 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    880.627272 s:  VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffffffff
    ^C
    Clean up and exit while handling signal 2
    Application did not[  873.921216] virtio_rpmsg_bus virtio3: msg received with no recipient
     close some rpmsg_char devices
    [MCU2_0]    880.660227 s:  VX_ZONE_ERROR:[AWB_TI_process:1525] TI_AWB_do Returned error 1
    [MCU2_0]    880.660305 s:  VX_ZONE_[  873.939985] virtio_rpmsg_bus virtio3: msg received with no recipient
    ERROR:[tivxAewbProcess:801] AWB_TI_process returned error 0xffff[  873.951579] virtio_rpmsg_bus virtio3: msg received with no recipient
    ffff
    [MCU2_0]    880.693142 s:  VX_ZONE_ERROR:[AWB_TI_process[  873.963011] virtio_rpmsg_bus virtio3: msg received with no recipient
    [MCU2_0]    880.693215 s:  [  873.974714] virtio_rpmsg_bus virtio3: msg received with no recipient
    VX_ZONE_ERROR:[tivxAewbProcess:801] AWB_TI_process returned erro[  873.986543] virtio_rpmsg_bus virtio3: msg received with no recipient
    r 0xffffffff
    从报错信息来看,是将摄像头添加的在解串器UB960下,导致无法启动。所以咨询一下如何将设摄像头配置到maxim解串器下,看到有帖子提到,但是没找到具体该如何实现?此外还有一个疑问,CSIRX相关的驱动,是否也需要做相应的改动
  • 由于支持您问题的工程师不在,请您重新发布一个新帖,将由另外的工程师为您提供支持,谢谢。
