TDA4VM: TDA4VM
Part Number: TDA4VM
您好,我这边有一个关于人脸关键点检测的模型,我将其部署在8.6的SDK上可以正常运行并能得到正确的结果,但是将其部署在8.2的SDK上的话,程序就会卡死在tivxAlgiVisionProcess这个函数中,请问这个问题可以解决吗
  • 请问是自己的板子还是TI的EVM板?能否发一下执行步骤和执行后的log信息?
  • 您好,我这边使用的是TI的EVM板,型号为J784S4XG01EVM,我的执行步骤如下:
    1. 准备好SDK 8.2和SDK 8.6的人脸关键点检测模型(PFLD)的bin文件和运行的cfg文件,bin文件为tidl_io_pfld_1.bin和tidl_net_pfld.bin,cfg文件为app_my.cfg,我已经上传到Google Drive里面了,分享链接如下
    SDK 8.2 : https://drive.google.com/file/d/1ZSKoRsou3eC7-526ZADT2MKcRb0XOaIY/view?usp=drive_link
    SDK 8.6 : https://drive.google.com/file/d/1mAoLMCnnGSjdvKkEUfxBxur28pCd6ny4/view?usp=drive_link
    2. 修改vision_apps/kernels/img_proc/c66/vx_draw_box_detections_target.c为下面内容
    #include <TI/tivx.h>
    #include <TI/tivx_img_proc.h>
    #include <TI/tivx_target_kernel.h>
    #include <tivx_kernels_target_utils.h>
    #include <utils/udma/include/app_udma.h>
    #include <utils/mem/include/app_mem.h>
    #include <tivx_draw_box_detections_host.h>
    #include "itidl_ti.h"
    #include <math.h>
    static tivx_target_kernel vx_DrawBoxDetections_kernel = NULL;
    static void drawPoints(vx_uint8 *data_ptr_1, vx_uint8 *data_ptr_2, vx_uint32 width, vx_uint32 height, vx_uint32 x_offset, vx_uint32 y_offset,
                           vx_uint32 *kp_ptr, vx_uint32 num_points, vx_uint8 dim, vx_uint8 color_map[][3]);
    static vx_float32 prob[196];
    static vx_uint32 point[196];
    #if defined(SOC_J721E) || defined(SOC_J721S2)
    #ifndef x86_64
    #if CPU_COPY    /* Not enabled - change to 1 for doing CPU copy */
    static void memcpyC66(uint8_t *restrict pOut, uint8_t *restrict pIn, int32_t size)
        int32_t remSize = size - ((size >> 3) << 3);
        int32_t i;
        for(i = 0; i < size; i+=8)
            _mem8(&pOut[i]) = _mem8(&pIn[i]);
        if(remSize > 0)
            i-=8;
            for(; i < size; i++)
                pOut[i] = pIn[i];
    #else
    static void memcpyC66(uint8_t *pOut, uint8_t *pIn, int32_t size)
        app_udma_copy_1d_prms_t prms_1d;
        appUdmaCopy1DPrms_Init(&prms_1d);
        prms_1d.dest_addr   = appMemGetVirt2PhyBufPtr((uint64_t) pOut, APP_MEM_HEAP_DDR);
        prms_1d.src_addr    = appMemGetVirt2PhyBufPtr((uint64_t) pIn, APP_MEM_HEAP_DDR);
        prms_1d.length      = (uint32_t) size;
        appUdmaCopy1D(NULL, &prms_1d);
    #endif
    #else
    #define memcpyC66 memcpy
    #endif
    #else
    #endif
    static vx_status VX_CALLBACK tivxKernelDrawBoxDetectionsCreate
        tivx_target_kernel_instance kernel,
        tivx_obj_desc_t *obj_desc[],
        vx_uint16 num_params,
        void *priv_arg
        vx_status status = VX_SUCCESS;
        uint32_t i;
        for (i = 0U; i < num_params; i ++)
            if (NULL == obj_desc[i])
                status = VX_FAILURE;
                break;
        return(status);
    static vx_status VX_CALLBACK tivxKernelDrawBoxDetectionsDelete(
        tivx_target_kernel_instance kernel, tivx_obj_desc_t *obj_desc[],
        vx_uint16 num_params, void *priv_arg)
        uint32_t i;
                break;
        return (status);
    static vx_status VX_CALLBACK tivxKernelDrawBoxDetectionsProcess
        void *priv_arg
        vx_int32 i;
                break;
        if (VX_SUCCESS == status)
            tivx_obj_desc_user_data_object_t* config_desc;
            void * config_target_ptr = NULL;
            tivx_obj_desc_tensor_t* input_tensor_desc;
            void * input_tensor_target_ptr = NULL;
            tivx_obj_desc_image_t* input_image_desc;
            void * input_image_target_ptr[2];
            tivx_obj_desc_image_t* output_image_desc;
            void * output_image_target_ptr[2];
            input_image_target_ptr[0] = NULL;
            input_image_target_ptr[1] = NULL;
            output_image_target_ptr[0] = NULL;
            output_image_target_ptr[1] = NULL;
            config_desc = (tivx_obj_desc_user_data_object_t *)obj_desc[TIVX_KERNEL_DRAW_BOX_DETECTIONS_CONFIGURATION_IDX];
            config_target_ptr = tivxMemShared2TargetPtr(&config_desc->mem_ptr);
            tivxMemBufferMap(config_target_ptr, config_desc->mem_size, VX_MEMORY_TYPE_HOST,VX_READ_ONLY);
            input_tensor_desc = (tivx_obj_desc_tensor_t *)obj_desc[TIVX_KERNEL_DRAW_BOX_DETECTIONS_INPUT_TENSOR_IDX];
            input_tensor_target_ptr = tivxMemShared2TargetPtr(&input_tensor_desc->mem_ptr);
            tivxMemBufferMap(input_tensor_target_ptr, input_tensor_desc->mem_size, VX_MEMORY_TYPE_HOST,VX_READ_ONLY);
            input_image_desc = (tivx_obj_desc_image_t *)obj_desc[TIVX_KERNEL_DRAW_BOX_DETECTIONS_INPUT_IMAGE_IDX];
            input_image_target_ptr[0] = tivxMemShared2TargetPtr(&input_image_desc->mem_ptr[0]);
            tivxMemBufferMap(input_image_target_ptr[0], input_image_desc->mem_size[0], VX_MEMORY_TYPE_HOST,VX_READ_ONLY);
            if(input_image_desc->mem_ptr[1].shared_ptr != 0)
                input_image_target_ptr[1] = tivxMemShared2TargetPtr(&input_image_desc->mem_ptr[1]);
                tivxMemBufferMap(input_image_target_ptr[1], input_image_desc->mem_size[1], VX_MEMORY_TYPE_HOST,VX_READ_ONLY);
            output_image_desc = (tivx_obj_desc_image_t *)obj_desc[TIVX_KERNEL_DRAW_BOX_DETECTIONS_OUTPUT_IMAGE_IDX];
            output_image_target_ptr[0] = tivxMemShared2TargetPtr(&output_image_desc->mem_ptr[0]);
            tivxMemBufferMap(output_image_target_ptr[0], output_image_desc->mem_size[0], VX_MEMORY_TYPE_HOST,VX_WRITE_ONLY);
            if(output_image_desc->mem_ptr[1].shared_ptr != 0)
                output_image_target_ptr[1] = tivxMemShared2TargetPtr(&output_image_desc->mem_ptr[1]);
                tivxMemBufferMap(output_image_target_ptr[1], output_image_desc->mem_size[1], VX_MEMORY_TYPE_HOST,VX_WRITE_ONLY);
            if(output_image_desc->mem_size[0] == input_image_desc->mem_size[0])
                memcpyC66(output_image_target_ptr[0], input_image_target_ptr[0], output_image_desc->mem_size[0]);
            if(output_image_desc->mem_size[1] == input_image_desc->mem_size[1])
                memcpyC66(output_image_target_ptr[1], input_image_target_ptr[1], output_image_desc->mem_size[1]);
            tivxDrawBoxDetectionsParams *params;
            params = (tivxDrawBoxDetectionsParams *)config_target_ptr;
            vx_uint32 point_num = 0;
            for (i = 0; i < 196; i++)
                prob[i] = ((vx_float32)(((vx_uint16 *)input_tensor_target_ptr)[i])) / 16384.0;
            for (i = 0, point_num = 0; i < 98; i++, point_num++)
                point[2 * point_num] = prob[2 * i] * 448;
                point[2 * point_num + 1] = prob[2 * i + 1] * 448;
            drawPoints((vx_uint8 *)output_image_target_ptr[0], (vx_uint8 *)output_image_target_ptr[1], 448, 448,
                        0, 0, point, point_num, 1, &params->color_map[0]);
            tivxMemBufferUnmap(config_target_ptr, config_desc->mem_size, VX_MEMORY_TYPE_HOST, VX_READ_ONLY);
            tivxMemBufferUnmap(input_tensor_target_ptr, input_tensor_desc->mem_size, VX_MEMORY_TYPE_HOST, VX_READ_ONLY);
            tivxMemBufferUnmap(input_image_target_ptr[0], input_image_desc->mem_size[0], VX_MEMORY_TYPE_HOST, VX_READ_ONLY);
            if(input_image_target_ptr[1] != NULL)
                tivxMemBufferUnmap(input_image_target_ptr[1], input_image_desc->mem_size[1], VX_MEMORY_TYPE_HOST, VX_READ_ONLY);
            tivxMemBufferUnmap(output_image_target_ptr[0], output_image_desc->mem_size[0], VX_MEMORY_TYPE_HOST, VX_WRITE_ONLY);
            if(output_image_target_ptr[1] != NULL)
                tivxMemBufferUnmap(output_image_target_ptr[1], output_image_desc->mem_size[1], VX_MEMORY_TYPE_HOST, VX_WRITE_ONLY);
        return (status);
    void tivxAddTargetKernelDrawBoxDetections()
        vx_status status = (vx_status)VX_FAILURE;
        char target_name[TIVX_TARGET_MAX_NAME];
        vx_enum self_cpu;
        self_cpu = tivxGetSelfCpuId();
        if (self_cpu == TIVX_CPU_ID_A72_0)
            strncpy(target_name, TIVX_TARGET_A72_0, TIVX_TARGET_MAX_NAME);
            status = (vx_status)VX_SUCCESS;
        else
            status = tivxKernelsTargetUtilsAssignTargetNameDsp(target_name);
        if( (vx_status)VX_SUCCESS == status)
            vx_DrawBoxDetections_kernel = tivxAddTargetKernelByName
                                            TIVX_KERNEL_DRAW_BOX_DETECTIONS_NAME,
                                            target_name,
                                            tivxKernelDrawBoxDetectionsProcess,
                                            tivxKernelDrawBoxDetectionsCreate,
                                            tivxKernelDrawBoxDetectionsDelete,
                                            NULL,
                                            NULL
    void tivxRemoveTargetKernelDrawBoxDetections()
        status = tivxRemoveTargetKernel(vx_DrawBoxDetections_kernel);
        if (status == VX_SUCCESS)
        vx_uint8 color[3];
        vx_uint32 kp_x, kp_y;
        color[0] = color_map[0][0];
        color[1] = color_map[0][1];
        color[2] = color_map[0][2];
        vx_int32 i = 0, j = 0, k = 0;
        for (i = 0; i < num_points; i++)
            kp_x = (vx_uint32)((vx_float32)kp_ptr[2 * i]) + x_offset;
            kp_y = (vx_uint32)((vx_float32)kp_ptr[2 * i + 1]) + y_offset;
            for (j = -((dim - 1) / 2); j < ((dim + 1) / 2); j++)
                for (k = -((dim - 1) / 2); k < ((dim + 1) / 2); k++)
                    data_ptr_1[(kp_y * width) + kp_x + (j * width) + k] = color[0];
                    data_ptr_2[((kp_y + j) >> 1) * width + (kp_x + k)] = color[1];
                    data_ptr_2[((kp_y + j) >> 1) * width + (kp_x + k) + 1] = color[2];
    3. 编译SDK
    4. 我这边采用的例程是vision_apps/dl_demos/app_tidl_od,生成的可执行文件为vx_app_tidl_od.out,在EVM板上运行vx_app_tidl_od.out --cfg app_my.cfg
    5. 在SDK 8.2 上得到的LOG信息如下,此时程序卡死,
    屏幕上面显示的效果如下
  • 您好,您的问题我们需要升级到英文论坛寻求帮助,链接如下,如有答复将尽快回复您:
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1271156/tda4vm-program-gets-stuck-when-deployed-on-sdk-8-2
  • 您好,
    很抱歉回复晚了。
    您能否连接 CCS 或使用日志来检查下 C7x 内核悬空的位置?
    在 TIDL 节点过程函数中是否有挂起?
