Part Number: AM625
Building the Linux userspace RPMsg example#
Note
These steps were tested on Ubuntu 18.04. Later versions of Ubuntu may need different steps.
Access source code in the git repo here. rproc_id is defined at include/rproc_id.h.
Build the Linux Userspace example for Linux RPMsg by following the steps in the top-level README:
Download the git repo
Install GNU autoconf, GNU automake, GNU libtool, and v8 compiler as per the README
Perform the Build Steps as per the README
请提供有效下载方法。
