Hi, Ti
I would like to ask you a question. I am debugging ub960-ub953-imx390 now. The sensor has been loaded successfully, but how to capture pictures or video streams? Can you tell me some commands?
IMX390 Camera 0 detected device = /dev/video-imx390-cam0 name = imx390 format = [fmt:SRGGB12_1X12/1936x1100 field: none] subdev_id = /dev/v4l-imx390-subdev0 isp_required = yes ldc_required = yes
Media controller API version 6.1.80 Media device information ------------------------ driver j721e-csi2rx model TI-CSI2RX serial bus info platform:4500000.ticsi2rx hw revision 0x1 driver version 6.1.80 Device topology - entity 1: 4500000.ticsi2rx (17 pads, 17 links, 1 route) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev0 routes: 0/0 -> 2/0 [ACTIVE] pad0: Sink [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] <- "cdns_csi2rx.4504000.csi-bridge":1 [ENABLED,IMMUTABLE] pad1: Source -> "4500000.ticsi2rx context 0":0 [ENABLED,IMMUTABLE] pad2: Source [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] -> "4500000.ticsi2rx context 1":0 [ENABLED,IMMUTABLE] pad3: Source -> "4500000.ticsi2rx context 2":0 [ENABLED,IMMUTABLE] pad4: Source -> "4500000.ticsi2rx context 3":0 [ENABLED,IMMUTABLE] pad5: Source -> "4500000.ticsi2rx context 4":0 [ENABLED,IMMUTABLE] pad6: Source -> "4500000.ticsi2rx context 5":0 [ENABLED,IMMUTABLE] pad7: Source -> "4500000.ticsi2rx context 6":0 [ENABLED,IMMUTABLE] pad8: Source -> "4500000.ticsi2rx context 7":0 [ENABLED,IMMUTABLE] pad9: Source -> "4500000.ticsi2rx context 8":0 [ENABLED,IMMUTABLE] pad10: Source -> "4500000.ticsi2rx context 9":0 [ENABLED,IMMUTABLE] pad11: Source -> "4500000.ticsi2rx context 10":0 [ENABLED,IMMUTABLE] pad12: Source -> "4500000.ticsi2rx context 11":0 [ENABLED,IMMUTABLE] pad13: Source -> "4500000.ticsi2rx context 12":0 [ENABLED,IMMUTABLE] pad14: Source -> "4500000.ticsi2rx context 13":0 [ENABLED,IMMUTABLE] pad15: Source -> "4500000.ticsi2rx context 14":0 [ENABLED,IMMUTABLE] pad16: Source -> "4500000.ticsi2rx context 15":0 [ENABLED,IMMUTABLE] - entity 19: cdns_csi2rx.4504000.csi-bridge (5 pads, 2 links, 1 route) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev1 routes: 0/0 -> 1/0 [ACTIVE] pad0: Sink [stream:0 fmt:SRGGB12_1X12/1936x1100 field:none] <- "ds90ub960 5-003d":4 [ENABLED,IMMUTABLE] pad1: Source [stream:0 fmt:SRGGB12_1X12/1936x1100 field:none] -> "4500000.ticsi2rx":0 [ENABLED,IMMUTABLE] pad2: Source pad3: Source pad4: Source - entity 25: ds90ub960 5-003d (6 pads, 2 links, 1 route) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev2 routes: 0/0 -> 4/0 [ACTIVE] pad0: Sink [stream:0 fmt:SRGGB12_1X12/1936x1100 field:none] <- "ds90ub953 5-0044":1 [ENABLED,IMMUTABLE] pad1: Sink pad2: Sink pad3: Sink pad4: Source [stream:0 fmt:SRGGB12_1X12/1936x1100 field:none] -> "cdns_csi2rx.4504000.csi-bridge":0 [ENABLED,IMMUTABLE] pad5: Source - entity 34: ds90ub953 5-0044 (2 pads, 2 links, 1 route) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev3 routes: 0/0 -> 1/0 [ACTIVE] pad0: Sink [stream:0 fmt:SRGGB12_1X12/1936x1100 field:none] <- "imx390 7-001a":0 [ENABLED,IMMUTABLE] pad1: Source [stream:0 fmt:SRGGB12_1X12/1936x1100 field:none] -> "ds90ub960 5-003d":0 [ENABLED,IMMUTABLE] - entity 39: imx390 7-001a (1 pad, 1 link, 2 routes) type V4L2 subdev subtype Sensor flags 0 device node name /dev/v4l-subdev4 routes: 0/0 -> 0/0 [ACTIVE] 0/0 -> 0/1 [INACTIVE] pad0: Source [stream:0 fmt:SRGGB12_1X12/1920x1290@1/30 field:none colorspace:smpte170m] -> "ds90ub953 5-0044":0 [ENABLED,IMMUTABLE] - entity 45: 4500000.ticsi2rx context 0 (1 pad, 1 link, 0 route) type Node subtype V4L flags 0 device node name /dev/video2 pad0: Sink <- "4500000.ticsi2rx":1 [ENABLED,IMMUTABLE] - entity 51: 4500000.ticsi2rx context 1 (1 pad, 1 link, 0 route) type Node subtype V4L flags 0 device node name /dev/video3 pad0: Sink <- "4500000.ticsi2rx":2 [ENABLED,IMMUTABLE] - entity 57: 4500000.ticsi2rx context 2 (1 pad, 1 link, 0 route) type Node subtype V4L flags 0 device node name /dev/video4 pad0: Sink <- "4500000.ticsi2rx":3 [ENABLED,IMMUTABLE] - entity 63: 4500000.ticsi2rx context 3 (1 pad, 1 link, 0 route) type Node subtype V4L flags 0 device node name /dev/video5 pad0: Sink <- "4500000.ticsi2rx":4 [ENABLED,IMMUTABLE] - entity 69: 4500000.ticsi2rx context 4 (1 pad, 1 link, 0 route) type Node subtype V4L flags 0 device node name /dev/video6 pad0: Sink <- "4500000.ticsi2rx":5 [ENABLED,IMMUTABLE] - entity 75: 4500000.ticsi2rx context 5 (1 pad, 1 link, 0 route) type Node subtype V4L flags 0 device node name /dev/video7 pad0: Sink <- "4500000.ticsi2rx":6 [ENABLED,IMMUTABLE] - entity 81: 4500000.ticsi2rx context 6 (1 pad, 1 link, 0 route) type Node subtype V4L flags 0 device node name /dev/video8 pad0: Sink <- "4500000.ticsi2rx":7 [ENABLED,IMMUTABLE] - entity 87: 4500000.ticsi2rx context 7 (1 pad, 1 link, 0 route) type Node subtype V4L flags 0 device node name /dev/video9 pad0: Sink <- "4500000.ticsi2rx":8 [ENABLED,IMMUTABLE] - entity 93: 4500000.ticsi2rx context 8 (1 pad, 1 link, 0 route) type Node subtype V4L flags 0 device node name /dev/video10 pad0: Sink <- "4500000.ticsi2rx":9 [ENABLED,IMMUTABLE] - entity 99: 4500000.ticsi2rx context 9 (1 pad, 1 link, 0 route) type Node subtype V4L flags 0 device node name /dev/video11 pad0: Sink <- "4500000.ticsi2rx":10 [ENABLED,IMMUTABLE] - entity 105: 4500000.ticsi2rx context 10 (1 pad, 1 link, 0 route) type Node subtype V4L flags 0 device node name /dev/video12 pad0: Sink <- "4500000.ticsi2rx":11 [ENABLED,IMMUTABLE] - entity 111: 4500000.ticsi2rx context 11 (1 pad, 1 link, 0 route) type Node subtype V4L flags 0 device node name /dev/video13 pad0: Sink <- "4500000.ticsi2rx":12 [ENABLED,IMMUTABLE] - entity 117: 4500000.ticsi2rx context 12 (1 pad, 1 link, 0 route) type Node subtype V4L flags 0 device node name /dev/video14 pad0: Sink <- "4500000.ticsi2rx":13 [ENABLED,IMMUTABLE] - entity 123: 4500000.ticsi2rx context 13 (1 pad, 1 link, 0 route) type Node subtype V4L flags 0 device node name /dev/video15 pad0: Sink <- "4500000.ticsi2rx":14 [ENABLED,IMMUTABLE] - entity 129: 4500000.ticsi2rx context 14 (1 pad, 1 link, 0 route) type Node subtype V4L flags 0 device node name /dev/video16 pad0: Sink <- "4500000.ticsi2rx":15 [ENABLED,IMMUTABLE] - entity 135: 4500000.ticsi2rx context 15 (1 pad, 1 link, 0 route) type Node subtype V4L flags 0 device node name /dev/video17 pad0: Sink <- "4500000.ticsi2rx":16 [ENABLED,IMMUTABLE]
I use the yavta -c Fcapture -s 1936x1100 -f SRGGB12 /dev/video2 command to report a kernel crash,Can you help me to see what the problem is, I have delayed for a long time
yavta -c -Fcapture -s 1936x1100 -f SRGGB12 /dev/video2 Device /dev/video2 opened. Device `j721e-csi2rx' on `platform:4510000.ticsi2rx' (driver 'j721e-csi2rx') supports video, capture, without mplanes. Video format set: SRGGB12 (32314752) 1936x1100 (stride 3872) field none buffer size 4259200 Video format: SRGGB12 (32314752) 1936x1100 (stride 3872) field none buffer size 4259200 8 buffers requested. [ 66.517857] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000010 Buffer 0/0 mapped at address 0xffffa9110000. length: 4259200 o[ 66.527940] Mem abort info: ffset: 4259840 timestamp type/source: mono/EoF Buffer 1/0 mappe[ 66.536276] ESR = 0x0000000096000006 d at address 0xffffa8d00000. length: 4259200 offset: 8519680 ti[ 66.545560] EC = 0x25: DABT (current EL), IL = 32 bits mestamp type/source: mono/EoF Buffer 2/0 mapped at address 0xff[ 66.556404] SET = 0, FnV = 0 ffa88f0000. length: 4259200 offset: 12779520 timestamp type/sou[ 66.564995] EA = 0, S1PTW = 0 rce: mono/EoF Buffer 3/0 mapped at address 0xffffa84e0000. len[ 66.573675] FSC = 0x06: level 2 translation fault gth: 4259200 offset: 17039360 timestamp type/source: mono/EoF B[ 66.584083] Data abort info: uffer 4/0 mapped at address 0xffffa80d0000. length: 4259200 off[ 66.592501] ISV = 0, ISS = 0x00000006 set: 21299200 timestamp type/source: mono/EoF Buffer 5/0 mapped[ 66.601891] CM = 0, WnR = 0 at address 0xffffa7cc0000. length: 4259200 offset: 25559040 ti[ 66.610387] user pgtable: 4k pages, 48-bit VAs, pgdp=00000008ad95f000 mestamp type/source: mono/EoF Buffer 6/0 mapped at address 0xff[ 66.622354] [0000000000000010] pgd=08000008ae91b003, p4d=08000008ae91b003, pud=08000008b72a2003, pmd=0000000000000000 ffa78b0000. length: 4259200 offset: 29818880 timestamp type/sou[ 66.638682] Internal error: Oops: 0000000096000006 [#1] PREEMPT SMP [ 66.650261] Modules linked in: imx390 xhci_plat_hcd pci_endpoint_test ds90ub953 ti_am335x_adc kfifo_buf irq_pruss_intc cdns_csi2rx pru_rproc rpmsg_ctrl rpmsg_char cdns_pltfrm omap_rng cdns3 cdns_usb_common snd_soc_j721e_evm crct10dif_ce display_connector phy_can_transceiver overlay cfg80211 bluetooth ecdh_generic ecc ti_k3_r5_remoteproc rfkill k3_j72xx_bandgap pruss ti_am335x_tscadc cdns_mhdp8546 tidss drm_display_helper vxd_dec vxe_enc j721e_csi2rx drm_dma_helper videobuf2_dma_sg ds90ub960 videobuf2_dma_contig drm_kms_helper v4l2_mem2mem videobuf2_memops v4l2_fwnode syscopyarea ti_j721e_ufs videobuf2_v4l2 sysfillrect pvrsrvkm(O) i2c_atr ti_k3_dsp_remoteproc sysimgblt v4l2_async videobuf2_common fb_sys_fops sa2ul virtio_rpmsg_bus rpmsg_ns videodev ti_k3_common snd_soc_davinci_mcasp m_can_platform cdns_dphy_rx snd_soc_pcm3168a_i2c m_can snd_soc_ti_udma mc snd_soc_pcm3168a pci_j721e_host snd_soc_ti_edma can_dev snd_soc_ti_sdma pci_j721e pcie_cadence_host pcie_cadence rti_wdt cdns3_ti [ 66.650379] ina2xx optee_rng rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6 [ 66.745739] CPU: 0 PID: 1812 Comm: yavta Tainted: G O 6.1.80-ti-g2e423244f8c0 #1 [ 66.754503] Hardware name: Texas Instruments J721e EVM (DT) [ 66.760058] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 66.767001] pc : ub960_get_frame_desc+0x10c/0x360 [ds90ub960] [ 66.772741] lr : ub960_get_frame_desc+0xdc/0x360 [ds90ub960] [ 66.852856] Call trace: [ 66.855289] ub960_get_frame_desc+0x10c/0x360 [ds90ub960] [ 66.860675] csi2rx_get_frame_desc+0x80/0xc0 [cdns_csi2rx] [ 66.866149] ti_csi2rx_get_vc+0x104/0x124 [j721e_csi2rx] [ 66.871449] ti_csi2rx_start_streaming+0x120/0x290 [j721e_csi2rx] [ 66.877528] vb2_start_streaming+0x68/0x15c [videobuf2_common] [ 66.883352] vb2_core_streamon+0x90/0x190 [videobuf2_common] [ 66.889000] vb2_ioctl_streamon+0x5c/0xb0 [videobuf2_v4l2] [ 66.894478] v4l_streamon+0x24/0x30 [videodev] [ 66.898933] __video_do_ioctl+0x18c/0x3dc [videodev] [ 66.903903] video_usercopy+0x21c/0x6d0 [videodev] [ 66.908699] video_ioctl2+0x18/0x30 [videodev] [ 66.913148] v4l2_ioctl+0x40/0x60 [videodev] [ 66.917425] __arm64_sys_ioctl+0xa8/0xf0 [ 66.921341] invoke_syscall+0x48/0x114 [ 66.925079] el0_svc_common.constprop.0+0xd4/0xfc [ 66.929768] do_el0_svc+0x20/0x30 [ 66.933070] el0_svc+0x28/0xa0 [ 66.936114] el0t_64_sync_handler+0xbc/0x140 [ 66.940371] el0t_64_sync+0x18c/0x190 [ 66.944023] Code: 6b070007 1a8020fa 8b1a0ec0 f9405401 (f9400820) [ 66.950099] ---[ end trace 0000000000000000 ]--- rce: mono/EoF Buffer 7/0 mapped at address 0xffffa74a0000.
Looking forward to your reply very much!
请参考这个FAQ,
FAQs — Processor SDK Linux for Edge AI Documentation
如果使用的J721EXCPXEVM,请参考
PROCESSOR-SDK-LINUX-SK-TDA4VM Software development kit (SDK) | TI.com
您好,Alice
我是想适配ox03c10,在imx390的驱动上修改为ox03c10的驱动,我按照您提供的FAQ中的方式,在最后一步test camera中,执行./apps_python/app_edgeai.py configs/imx390_cam_example.yaml,没有成功,log如下:
libtidl_onnxrt_EP loaded 0x23835740 Final number of subgraphs created are : 1, - Offloaded Nodes - 283, Total Nodes - 283 APP: Init ... !!! MEM: Init ... !!! MEM: Initialized DMA HEAP (fd=5) !!! MEM: Init ... Done !!! IPC: Init ... !!! IPC: Init ... Done !!! REMOTE_SERVICE: Init ... !!! REMOTE_SERVICE: Init ... Done !!! 1209.955756 s: GTC Frequency = 200 MHz APP: Init ... Done !!! 1209.955836 s: VX_ZONE_INIT:Enabled 1209.955843 s: VX_ZONE_ERROR:Enabled 1209.955849 s: VX_ZONE_WARNING:Enabled 1209.956414 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-0 1209.956536 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-1 1209.956629 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-2 1209.956720 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-3 1209.956729 s: VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!! 1209.957249 s: VX_ZONE_INIT:[tivxHostInitLocal:101] Initialization Done for HOST !!! ==========[INPUT PIPELINE(S)]========== [PIPE-0] v4l2src device=/dev/video-imx390-cam0 io-mode=5 pixel-aspect-ratio=None ! queue leaky=2 ! capsfilter caps="video/x-bayer, width=(int)1936, height=(int)1100, format=(string)rggb12;" ! tiovxisp dcc-isp-file=/opt/imaging/imx390/linear/dcc_viss.bin sensor-name=SENSOR_SONY_IMX390_UB953_D3 format-msb=11 ! capsfilter caps="video/x-raw, format=(string)NV12;" ! tiovxldc dcc-file=/opt/imaging/imx390/linear/dcc_ldc.bin sensor-name=SENSOR_SONY_IMX390_UB953_D3 ! capsfilter caps="video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080;" ! tiovxmultiscaler name=split_01 split_01. ! queue ! capsfilter caps="video/x-raw, width=(int)1280, height=(int)720;" ! tiovxdlcolorconvert out-pool-size=4 ! capsfilter caps="video/x-raw, format=(string)RGB;" ! appsink max-buffers=2 drop=True name=sen_0 split_01. ! queue ! capsfilter caps="video/x-raw, width=(int)1168, height=(int)748;" ! tiovxmultiscaler target=1 ! capsfilter caps="video/x-raw, width=(int)416, height=(int)416;" ! tiovxdlpreproc out-pool-size=4 data-type=3 tensor-format=1 ! capsfilter caps="application/x-tensor-tiovx;" ! appsink max-buffers=2 drop=True name=pre_0 ==========[OUTPUT PIPELINE]========== appsrc do-timestamp=True format=3 block=True name=post_0 ! tiovxdlcolorconvert ! capsfilter caps="video/x-raw, format=(string)NV12, width=(int)1280, height=(int)720;" ! queue ! mosaic_0.sink_0 tiovxmosaic target=1 background=/tmp/background_0 name=mosaic_0 src::pool-size=4 sink_0::startx="<320>" sink_0::starty="<150>" sink_0::widths="<1280>" sink_0::heights="<720>" ! capsfilter caps="video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080;" ! queue ! tiperfoverlay title=IMX390 Camera ! kmssink sync=False max-lateness=5000000 qos=True processing-deadline=15000000 driver-name=tidss connector-id=40 plane-id=31 force-modesetting=True +--------------------------------------------------------------------------+ | IMX390 Camera | +--------------------------------------------------------------------------+ +--------------------------------------------------------------------------+ | Input Src: /dev/video-imx390-cam0 | | Model Name: ONR-OD-8200-yolox-nano-lite-mmdet-coco-416x416 | | Model Type: detection | +--------------------------------------------------------------------------+ +--------------------------------------------------------------------------+ +--------------------------------------------------------------------------+ | IMX390 Camera | +--------------------------------------------------------------------------+ +--------------------------------------------------------------------------+ | Input Src: /dev/video-imx390-cam0 | | Model Name: ONR-OD-8200-yolox-nano-lite-mmdet-coco-416x416 | | Model Type: detection | +--------------------------------------------------------------------------+ +--------------------------------------------------------------------------+ 1212.507568 s: VX_ZONE_WARNING:[vxReleaseContext:1325] Found a reference 0xffffafe138e0 of type 00000817 at external count 1, internal count 0, releasing it 1212.507631 s: VX_ZONE_WARNING:[vxReleaseContext:1327] Releasing reference (name=raw_image_115) now as a part of garbage collection 1212.507645 s: VX_ZONE_WARNING:[vxReleaseContext:1325] Found a reference 0xffffaff11f58 of type 00000813 at external count 1, internal count 0, releasing it 1212.507652 s: VX_ZONE_WARNING:[vxReleaseContext:1327] Releasing reference (name=object_array_116) now as a part of garbage collection 1212.508258 s: VX_ZONE_WARNING:[vxReleaseContext:1325] Found a reference 0xffffaff12100 of type 00000813 at external count 1, internal count 0, releasing it 1212.508266 s: VX_ZONE_WARNING:[vxReleaseContext:1327] Releasing reference (name=object_array_122) now as a part of garbage collection 1212.508859 s: VX_ZONE_WARNING:[vxReleaseContext:1325] Found a reference 0xffffaff125f8 of type 00000813 at external count 1, internal count 0, releasing it 1212.508867 s: VX_ZONE_WARNING:[vxReleaseContext:1327] Releasing reference (name=object_array_124) now as a part of garbage collection 1212.509463 s: VX_ZONE_WARNING:[vxReleaseContext:1325] Found a reference 0xffffaff127a0 of type 00000813 at external count 1, internal count 0, releasing it 1212.509472 s: VX_ZONE_WARNING:[vxReleaseContext:1327] Releasing reference (name=object_array_126) now as a part of garbage collection 1212.510066 s: VX_ZONE_WARNING:[vxReleaseContext:1325] Found a reference 0xffffaff12948 of type 00000813 at external count 1, internal count 0, releasing it 1212.510073 s: VX_ZONE_WARNING:[vxReleaseContext:1327] Releasing reference (name=object_array_128) now as a part of garbage collection 1212.510676 s: VX_ZONE_WARNING:[vxReleaseContext:1325] Found a reference 0xffffaff12af0 of type 00000813 at external count 1, internal count 0, releasing it 1212.510684 s: VX_ZONE_WARNING:[vxReleaseContext:1327] Releasing reference (name=object_array_130) now as a part of garbage collection 1212.511385 s: VX_ZONE_INIT:[tivxHostDeInitLocal:115] De-Initialization Done for HOST !!! 1212.515901 s: VX_ZONE_INIT:[tivxDeInitLocal:204] De-Initialization Done !!! APP: Deinit ... !!! REMOTE_SERVICE: Deinit ... !!! REMOTE_SERVICE: Deinit ... Done !!! IPC: Deinit ... !!! IPC: DeInit ... Done !!! MEM: Deinit ... !!! DDR_SHARED_MEM: Alloc's: 83 alloc's of 138289471 bytes DDR_SHARED_MEM: Free's : 83 free's of 138289471 bytes DDR_SHARED_MEM: Open's : 0 allocs of 0 bytes MEM: Deinit ... Done !!! APP: Deinit ... Done !!!
执行v4l2-ctl -d2 --set-fmt-video=width=1920,height=1280,pixelformat=RG12 --stream-mmap,显示:
root@j721e-evm:/opt/edgeai-gst-apps# v4l2-ctl -d2 --set-fmt-video=width=1920,height=1280,pixelformat=RG12 --stream-mmap VIDIOC_STREAMON returned -1 (Broken pipe)
执行yavta /dev/video19 -c1 -n4 -s1920x1280 -fSRGGB12 -F1.raw(video19是 /dev/video-imx390-cam0 -> /dev/video19)
Device /dev/video19 opened. Device `j721e-csi2rx' on `platform:4500000.ticsi2rx' (driver 'j721e-csi2rx') supports video, capture, without mplanes. Video format set: SRGGB12 (32314752) 1920x1280 (stride 3840) field none buffer size 4915200 Video format: SRGGB12 (32314752) 1920x1280 (stride 3840) field none buffer size 4915200 4 buffers requested. length: 4915200 offset: 0 timestamp type/source: mono/EoF Buffer 0/0 mapped at address 0xffff85c60000. length: 4915200 offset: 4915200 timestamp type/source: mono/EoF Buffer 1/0 mapped at address 0xffff857b0000. length: 4915200 offset: 9830400 timestamp type/source: mono/EoF Buffer 2/0 mapped at address 0xffff85300000. length: 4915200 offset: 14745600 timestamp type/source: mono/EoF Buffer 3/0 mapped at address 0xffff84e50000. Unable to start streaming: Broken pipe (32). 4 buffers released.
请问这个原因是什么,感谢您的帮助
这种报错通常是格式不匹配, 下面的用户手册的配置您参考一下
Demo Configuration file — Processor SDK Linux for Edge AI Documentation
如前面回复,不同的评估板适用的SDK不一样。
类似的问题的帖子请参考
