Ti工程师,你好!
我使用mmwave_studio_03_00_00_14里面自带的Advanced_Chirp_Example.LUA,发现采集不到数据,这个问题怎么解决?????
Ti工程师,你好!
I ran into the same problem before, it usually happens when the mmWave Studio version doesn’t match the board firmware. For AWR2243BOOST, 03.01.04.04 isn’t compatible. Try using 02.01.xx or the firmware that came with your board.
Also double-check your COM ports and make sure the DCA1000 is connected before running sensorStart(). That fixed the “no file” error for me.
