Other Parts Discussed in Thread: AWR1642BOOST
您好,我想咨询使用AWR1642Boost与DCA1000采集数据时无法生成bin文件该如何解决,其中mmwave studio输出错误如下
GM: Constructor
GM: Fri Nov 05 21:09:29 2021
RSTD.Transmit("/Settings")
[21:09:29]
[21:09:29] ### Running Startup script: "E:\TI\mmwave_studio_02_01_00_00\mmWaveStudio\Scripts\Startup.lua" ###
[21:09:29] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[21:09:29] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[21:09:29] Scripter ignored: Attempt to UnBuild() again or before Build.
[21:09:29] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "E:\\TI\\mmwave_studio_02_01_00_00\\mmWaveStudio\\Clients\\\\LabClient.dll")
[21:09:29] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[21:09:29] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[21:09:29] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[21:09:29] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[21:09:29] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[21:09:29] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "E:\\TI\\mmwave_studio_02_01_00_00\\mmWaveStudio\\RunTime\\SAL.dll")
[21:09:29] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[21:09:29] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[21:09:29] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[21:09:29] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[21:09:29] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[21:09:29] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[21:09:29] RSTD.Transmit("/")
[21:09:29] RSTD.SaveSettings(): Settings saved to "C:\Users\15146\AppData\Roaming\RSTD\config.xml"
[21:09:29] RSTD.Build()
[21:09:29] RSTD.AL_Build()
[21:09:29] RSTD.AL_LoadXml()
[21:09:29] RSTD.AL_Init()
[21:09:29] RSTD.Clients_Build()
[21:09:29] GM: Init
[21:09:29] GM: Loaded 'E:\TI\mmwave_studio_02_01_00_00\mmWaveStudio\Clients\\LabClient.dll'
[21:09:29] GM: 1 Guest (s) init
[21:09:29] GM: 1 Module(s) init
[21:09:29] GM: 2 Tab (s) init
[21:09:29] RSTD.Client_LoadXml()
[21:09:30] [RadarAPI]: ar1.selectRadarMode(0)
[21:09:30] [RadarAPI]: Status: Passed
[21:09:30] Matlab Runtime Engine is installed
[21:09:30] [RadarAPI]: Starting Matlab Engine..
[21:09:35] [RadarAPI]: Matlab Engine Started!
[21:09:37] [RadarAPI]: ar1.selectCascadeMode(0)
[21:09:37] [RadarAPI]: Status: Passed
[21:09:37] [RadarAPI]: ar1.LoadSettings('C:\Users\15146\AppData\Roaming\RSTD\ar1gui.ini')
[21:09:37] TESTING = false
[21:09:37] RstdNet: Port 2777: Listening..
[21:09:37]
[21:09:37] ***Script completed successfully.***
[21:09:44] [RadarAPI]: Opening Gpio Control Port()
[21:09:44] [RadarAPI]: Status: Passed
[21:09:45] [RadarAPI]: Opening Board Control Port()
[21:09:45] [RadarAPI]: Status: Passed
[21:09:46] [RadarAPI]: ar1.FullReset()
[21:09:46] [RadarAPI]: Status: Passed
[21:09:47] [RadarAPI]: Closing Board Control Port()
[21:09:47] [RadarAPI]: Status: Passed
[21:09:47] [RadarAPI]: Closing Gpio Control Port()
[21:09:47] [RadarAPI]: ar1.SOPControl(2)
[21:09:57] [RadarAPI]: ar1.Connect(3,115200,1000)
[21:09:58] [RadarAPI]: ar1.Calling_IsConnected()
[21:10:00] [RadarAPI]: ar1.SelectChipVersion("AR1642")
[21:10:00] [RadarAPI]: Status: Passed
[21:10:00] [RadarAPI]: ar1.deviceVariantSelection("XWR1642")
[21:10:00] [RadarAPI]: ar1.frequencyBandSelection("77G")
[21:10:00] [RadarAPI]: ar1.SelectChipVersion("XWR1642")
[21:10:00] Device Status : XWR1642/ASIL-B/SOP:2/ES:2
[21:10:00] [RadarAPI]: ar1.SaveSettings('C:\Users\15146\AppData\Roaming\RSTD\ar1gui.ini')
[21:10:05] [RadarAPI]: ar1.DownloadBSSFw("E:\\TI\\mmwave_studio_02_01_00_00\\rf_eval_firmware\\radarss\\xwr16xx_radarss.bin")
[21:10:05] [RadarAPI]: Downloading BSS Patch RPRC Binary..
[21:10:13] [RadarAPI]: ar1.GetBSSFwVersion()
[21:10:13] [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
[21:10:14] [RadarAPI]: ar1.GetBSSPatchFwVersion()
[21:10:14] [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
[21:10:15] [RadarAPI]: ar1.DownloadMSSFw("E:\\TI\\mmwave_studio_02_01_00_00\\rf_eval_firmware\\masterss\\xwr16xx_masterss.bin")
[21:10:15] [RadarAPI]: Downloading MSS RPRC Binary..
[21:10:26] [RadarAPI]: ar1.GetMSSFwVersion()
[21:10:26] [RadarAPI]: MSSFwVersion:(01.02.05.02 (16/07/19))
[21:10:30] [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
[21:10:30] [RadarAPI]: Status: Passed
[21:10:30] MSS power up done async event received!
[21:10:32] [RadarAPI]: ar1.SelectChipVersion("AR1642")
[21:10:32] [RadarAPI]: Status: Passed
[21:10:32] [RadarAPI]: ar1.SelectChipVersion("XWR1642")
[21:10:32] Device Status : XWR1642/ASIL-B/SOP:2/ES:2
[21:10:32] [RadarAPI]: ar1.RfEnable()
[21:10:32] BSS power up done async event received!
[21:10:33] [RadarAPI]: ar1.GetMSSFwVersion()
[21:10:33] [RadarAPI]: MSSFwVersion:(01.02.05.02 (16/07/19))
[21:10:33] [RadarAPI]: ar1.GetBSSFwVersion()
[21:10:33] [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
[21:10:34] [RadarAPI]: ar1.GetBSSPatchFwVersion()
[21:10:34] [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
[21:10:45] [RadarAPI]: ar1.ChanNAdcConfig(1, 1, 0, 1, 1, 1, 1, 2, 2, 0)
[21:10:45] [RadarAPI]: Status: Passed
[21:10:46] [RadarAPI]: ar1.RfLdoBypassConfig(0x0)
[21:10:46] [RadarAPI]: Status: Passed
[21:10:48] [RadarAPI]: ar1.LPModConfig(0, 1)
[21:10:48] [RadarAPI]: Status: Passed
[21:10:56] [RadarAPI]: ar1.RfInit()
[21:10:56] RF Init async event received!
[21:10:56] [RadarAPI]: Time stamp, Temperture: 24219,40; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 0, 0; RxIQMM Status, Update: 1, 1;
[21:10:56] [RadarAPI]: Status: Passed
[21:11:01] [RadarAPI]: ar1.DataPathConfig(513, 1216644097, 0)
[21:11:01] [RadarAPI]: Status: Passed
[21:11:02] [RadarAPI]: ar1.LvdsClkConfig(1, 1)
[21:11:02] [RadarAPI]: Status: Passed
[21:11:09] [RadarAPI]: ar1.LVDSLaneConfig(0, 1, 1, 0, 0, 1, 0, 0)
[21:11:09] [RadarAPI]: Status: Passed
[21:11:16] [RadarAPI]: ar1.ProfileConfig(0, 77, 100, 6, 60, 0, 0, 0, 0, 0, 0, 29.982, 0, 256, 10000, 0, 0, 30)
[21:11:16] [RadarAPI]: Status: Passed
[21:11:18] [RadarAPI]: ar1.ChirpConfig(0, 0, 0, 0, 0, 0, 0, 1, 0, 0)
[21:11:18] [RadarAPI]: Status: Passed
[21:11:39] Test Source Already Disabled...!!!
[21:11:39] [RadarAPI]: ar1.DisableTestSource(0)
[21:11:39] [RadarAPI]: Status: Passed
[21:11:39] [RadarAPI]: ar1.FrameConfig(0, 0, 32, 128, 40, 0, 0, 1)
[21:11:45] [RadarAPI]: ar1.GetCaptureCardDllVersion()
[21:11:45] [RadarAPI]: Sending dll_version command to DCA1000
[21:11:45] DLL Version : 1.0
[21:11:45] [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
[21:11:45] [RadarAPI]: Status: Passed
[21:11:46] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[21:11:46] [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 2, 1, 2, 3, 30)
[21:11:46] [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
[21:11:46] [RadarAPI]: Sending fpga command to DCA1000
[21:11:57] [RadarAPI]:
[21:11:57] FPGA Configuration :
[21:11:57] Timeout Error! System disconnected
[21:11:57] [RadarAPI]: Sending record command to DCA1000
[21:11:58] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[21:11:58] [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 2, 1, 2, 3, 30)
[21:11:58] [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
[21:11:59] [RadarAPI]: Sending fpga command to DCA1000
[21:11:59]
[21:11:59] ConnectRFDCCard_ConfigMode(): Bind failed (Config port) : 10048
[21:11:59] Ethernet connection failed. [error -4051]
[21:11:59] [RadarAPI]: Sending record command to DCA1000
[21:11:59]
[21:11:59] [RadarAPI]: ar1.GetCaptureCardFPGAVersion()
[21:11:59] [RadarAPI]: Sending fpga_version command to DCA1000
[21:11:59]
[21:12:01] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[21:12:01] [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 2, 1, 2, 3, 30)
[21:12:01] [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
[21:12:01] [RadarAPI]: Sending fpga command to DCA1000
[21:12:01]
[21:12:01] ConnectRFDCCard_ConfigMode(): Bind failed (Config port) : 10048
[21:12:01] Ethernet connection failed. [error -4051]
[21:12:01] [RadarAPI]: Sending record command to DCA1000
[21:12:01]
[21:12:01] [RadarAPI]: ar1.GetCaptureCardFPGAVersion()
[21:12:01] [RadarAPI]: Sending fpga_version command to DCA1000
[21:12:01]
[21:12:07] [RadarAPI]:
[21:12:07] Configure Record :
[21:12:07] Timeout Error! System disconnected
[21:12:07] [RadarAPI]: ar1.GetCaptureCardFPGAVersion()
[21:12:07] [RadarAPI]: Sending fpga_version command to DCA1000
[21:12:10] [RadarAPI]: ar1.GetCaptureCardDllVersion()
[21:12:10] [RadarAPI]: Sending dll_version command to DCA1000
[21:12:10] DLL Version : 1.0
[21:12:10] [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
[21:12:10] [RadarAPI]: Status: Passed
[21:12:17] [RadarAPI]:
[21:12:17]
[21:12:17] Unable to read FPGA Version. [error -5]
[21:12:17]
[21:12:17] [RadarAPI]: ar1.CaptureCardConfig_StartRecord("E:\\TI\\mmwave_studio_02_01_00_00\\mmWaveStudio\\PostProc\\adc_data.bin", 1)
[21:12:17] [RadarAPI]: Sending start_record command to DCA1000
[21:12:19] [RadarAPI]: ar1.StartFrame()
[21:12:19] [RadarAPI]: Status: Passed
[21:12:19] Frame start async event received!
[21:12:20] [RadarAPI]: Frame Ended
[21:12:27] [RadarAPI]:
[21:12:27] Frame End async event received!
[21:12:27] Start Record :
[21:12:27] Timeout Error! System disconnected
[21:12:31] [RadarAPI]: ar1.StartMatlabPostProc("E:\\TI\\mmwave_studio_02_01_00_00\\mmWaveStudio\\PostProc\\adc_data.bin")
[21:12:31] [RadarAPI]: No of files Captured: 0, Total no of frames for each device : 32
[21:12:31] Error : The number of files captured is zero!
[21:12:32] [RadarAPI]: ar1.StartMatlabPostProc("E:\\TI\\mmwave_studio_02_01_00_00\\mmWaveStudio\\PostProc\\adc_data.bin")
[21:12:32] [RadarAPI]: No of files Captured: 0, Total no of frames for each device : 32
[21:12:32] Error : The number of files captured is zero!
[21:12:33] [RadarAPI]: ar1.StartMatlabPostProc("E:\\TI\\mmwave_studio_02_01_00_00\\mmWaveStudio\\PostProc\\adc_data.bin")
[21:12:33] [RadarAPI]: No of files Captured: 0, Total no of frames for each device : 32
[21:12:33] Error : The number of files captured is zero!
[21:12:34] [RadarAPI]: ar1.StartMatlabPostProc("E:\\TI\\mmwave_studio_02_01_00_00\\mmWaveStudio\\PostProc\\adc_data.bin")
[21:12:34] [RadarAPI]: No of files Captured: 0, Total no of frames for each device : 32
[21:12:34] Error : The number of files captured is zero!
[21:12:35] [RadarAPI]: ar1.StartMatlabPostProc("E:\\TI\\mmwave_studio_02_01_00_00\\mmWaveStudio\\PostProc\\adc_data.bin")
[21:12:35] [RadarAPI]: No of files Captured: 0, Total no of frames for each device : 32
[21:12:35] Error : The number of files captured is zero!
[21:12:36] [RadarAPI]: ar1.StartMatlabPostProc("E:\\TI\\mmwave_studio_02_01_00_00\\mmWaveStudio\\PostProc\\adc_data.bin")
[21:12:36] [RadarAPI]: No of files Captured: 0, Total no of frames for each device : 32
[21:12:36] Error : The number of files captured is zero!
[21:15:04] [RadarAPI]: ar1.StartMatlabPostProc("E:\\TI\\mmwave_studio_02_01_00_00\\mmWaveStudio\\PostProc\\adc_data.bin")
[21:15:04] [RadarAPI]: No of files Captured: 0, Total no of frames for each device : 32
[21:15:04] Error : The number of files captured is zero!
