Other Parts Discussed in Thread: AWR2243
我在设置的过程中没有报错,但是在点击DCA1000 ARM和Triger Frame后板子没有采集到数据,输出如下所示:
GM: Constructor
GM: Thu Dec 23 21:58:54 2021
RSTD.Transmit("/Settings")
[21:58:56]
[21:58:56] ### Running Startup script: "C:\ti\mmwave_studio_03_00_00_14\mmWaveStudio\Scripts\Startup.lua" ###
[21:58:56] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[21:58:56] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[21:58:56] Scripter ignored: Attempt to UnBuild() again or before Build.
[21:58:56] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_03_00_00_14\\mmWaveStudio\\Clients\\\\LabClient.dll")
[21:58:56] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[21:58:56] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[21:58:56] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[21:58:56] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[21:58:56] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[21:58:56] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_03_00_00_14\\mmWaveStudio\\RunTime\\SAL.dll")
[21:58:56] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[21:58:56] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[21:58:56] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[21:58:56] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[21:58:56] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[21:58:56] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[21:58:56] RSTD.Transmit("/")
[21:58:56] RSTD.SaveSettings(): Settings saved to "C:\Users\li137\AppData\Roaming\RSTD\config.xml"
[21:58:56] RSTD.Build()
[21:58:56] RSTD.AL_Build()
[21:58:56] RSTD.AL_LoadXml()
[21:58:56] RSTD.AL_Init()
[21:58:56] RSTD.Clients_Build()
[21:58:56] GM: Init
[21:58:56] GM: Loaded 'C:\ti\mmwave_studio_03_00_00_14\mmWaveStudio\Clients\\LabClient.dll'
[21:58:56] GM: 1 Guest (s) init
[21:58:56] GM: 1 Module(s) init
[21:58:56] GM: 2 Tab (s) init
[21:58:56] RSTD.Client_LoadXml()
[21:58:57] [RadarAPI]: ar1.selectRadarMode(0)
[21:58:58] [RadarAPI]: Status: Passed
[21:58:58] Matlab Runtime Engine is installed
[21:58:58] [RadarAPI]: Starting Matlab Engine..
[21:59:33] [RadarAPI]: Matlab Engine Started!
[21:59:36] [RadarAPI]: ar1.selectCascadeMode(0)
[21:59:36] [RadarAPI]: Status: Passed
[21:59:36] [RadarAPI]: ar1.LoadSettings('C:\Users\li137\AppData\Roaming\RSTD\ar1gui.ini')
[21:59:36] TESTING = false
[21:59:37] RstdNet: Port 2777: Listening..
[21:59:37]
[21:59:37] ***Script completed successfully.***
[21:59:43] [RadarAPI]: ar1.GetCaptureCardDllVersion()
[21:59:43] [RadarAPI]: Sending dll_version command to DCA1000
[21:59:43] DLL Version : 1.0
[21:59:43] [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
[21:59:43] [RadarAPI]: Status: Passed
[21:59:46] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[21:59:46] [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 0, 1, 2, 3, 30)
[21:59:46] [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
[21:59:47] [RadarAPI]: Sending fpga command to DCA1000
[21:59:47] Invalid lvdsMode value (0). [error -4016]
[21:59:47] [RadarAPI]: Sending record command to DCA1000
[21:59:47] Configure Record command : Success
[21:59:47] [RadarAPI]: ar1.GetCaptureCardFPGAVersion()
[21:59:47] [RadarAPI]: Sending fpga_version command to DCA1000
[21:59:47]
[21:59:47] FPGA Version : 2.8 [Record]
[21:59:47]
[21:59:51] [RadarAPI]: Opening Gpio Control Port()
[21:59:51] [RadarAPI]: Status: Passed
[21:59:52] [RadarAPI]: Opening Board Control Port()
[21:59:52] [RadarAPI]: Status: Passed
[21:59:53] [RadarAPI]: ar1.FullReset()
[21:59:53] [RadarAPI]: Status: Passed
[21:59:54] [RadarAPI]: Closing Board Control Port()
[21:59:54] [RadarAPI]: Status: Passed
[21:59:54] [RadarAPI]: Closing Gpio Control Port()
[21:59:54] [RadarAPI]: ar1.SOPControl(2)
[21:59:56] [RadarAPI]: ar1.Connect(3,921600,1000)
[21:59:59] [RadarAPI]: Warning: Connected with baudrate 115200
[22:00:00] [RadarAPI]: Warning: Disconnected existing BaudRate
[22:00:00] [RadarAPI]: Warning: Trying to connect with baudrate 921600
[22:00:02] [RadarAPI]: ar1.Calling_IsConnected()
[22:00:03] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[22:00:03] [RadarAPI]: Status: Passed
[22:00:03] [RadarAPI]: ar1.deviceVariantSelection("XWR2243")
[22:00:03] [RadarAPI]: ar1.frequencyBandSelection("77G")
[22:00:03] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[22:00:03] Device Status : XWR2243/ASIL-B/SOP:2/ES:1.1
[22:00:03] [RadarAPI]: ar1.SaveSettings('C:\Users\li137\AppData\Roaming\RSTD\ar1gui.ini')
[22:00:06] [RadarAPI]: ar1.DownloadBSSFw("C:\\ti\\mmwave_studio_03_00_00_14\\rf_eval_firmware\\AWR2243_ES1_1\\radarss\\xwr22xx_radarss.bin")
[22:00:07] [RadarAPI]: Downloading BSS Patch RPRC Binary..
[22:00:07] [RadarAPI]: ar1.GetBSSFwVersion()
[22:00:07] [RadarAPI]: BSSFwVersion:(02.02.00.13 (07/03/20))
[22:00:08] [RadarAPI]: ar1.GetBSSPatchFwVersion()
[22:00:08] [RadarAPI]: BSSPatchFwVersion:(02.02.02.06 (12/08/20))
[22:00:11] [RadarAPI]: ar1.DownloadMSSFw("C:\\ti\\mmwave_studio_03_00_00_14\\rf_eval_firmware\\AWR2243_ES1_1\\masterss\\xwr22xx_masterss.bin")
[22:00:11] [RadarAPI]: Downloading MSS RPRC Binary..
[22:00:14] [RadarAPI]: ar1.GetMSSFwVersion()
[22:00:14] [RadarAPI]: MSSFwVersion:(02.02.02.00 (29/07/20))
[22:00:17] [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
[22:00:17] [RadarAPI]: Status: Passed
[22:00:17] MSS power up done async event received!
[22:00:20] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[22:00:20] [RadarAPI]: Status: Passed
[22:00:20] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[22:00:21] Device Status : XWR2243/ASIL-B/SOP:2/ES:1.1
[22:00:21] [RadarAPI]: ar1.RfEnable()
[22:00:21] BSS power up done async event received!
[22:00:21] [RadarAPI]: Status: Passed
[22:00:21] [RadarAPI]: ar1.GetMSSFwVersion()
[22:00:21] [RadarAPI]: MSSFwVersion:(02.02.02.00 (29/07/20))
[22:00:22] [RadarAPI]: ar1.GetBSSFwVersion()
[22:00:22] [RadarAPI]: BSSFwVersion:(02.02.00.13 (07/03/20))
[22:00:23] [RadarAPI]: ar1.GetBSSPatchFwVersion()
[22:00:23] [RadarAPI]: BSSPatchFwVersion:(02.02.02.06 (12/08/20))
[22:00:33] [RadarAPI]: ar1.ChanNAdcConfig(1, 1, 0, 1, 1, 1, 1, 2, 1, 0)
[22:00:33] [RadarAPI]: Status: Passed
[22:00:35] [RadarAPI]: ar1.LPModConfig(0, 0)
[22:00:36] [RadarAPI]: Status: Passed
[22:00:37] [RadarAPI]: ar1.RfInit()
[22:00:38] RF Init async event received!
[22:00:38] [RadarAPI]: Status: Passed
[22:00:38] [RadarAPI]: Time stamp, Temperture: 16860,35; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1;
[22:00:42] [RadarAPI]: ar1.DataPathConfig(513, 1216644097, 0)
[22:00:43] [RadarAPI]: Status: Passed
[22:00:44] [RadarAPI]: ar1.LvdsClkConfig(1, 1)
[22:00:44] [RadarAPI]: Status: Passed
[22:00:46] [RadarAPI]: ar1.LVDSLaneConfig(0, 1, 1, 1, 1, 1, 0, 0)
[22:00:46] [RadarAPI]: Status: Passed
[22:00:51] [RadarAPI]: ar1.ProfileConfig(0, 77, 100, 6, 60, 0, 0, 0, 0, 0, 0, 29.982, 0, 256, 10000, 0, 0, 94)
[22:00:51] [RadarAPI]: Status: Passed
[22:00:53] [RadarAPI]: ar1.ChirpConfig(0, 0, 0, 0, 0, 0, 0, 1, 0, 0)
[22:00:53] [RadarAPI]: Status: Passed
[22:00:56] Test Source Already Disabled...!!!
[22:00:56] [RadarAPI]: ar1.DisableTestSource(0)
[22:00:56] [RadarAPI]: Status: Passed
[22:00:56] [RadarAPI]: ar1.FrameConfig(0, 0, 8, 128, 40, 0, 1)
[22:00:58] [RadarAPI]: ar1.CaptureCardConfig_StartRecord("C:\\ti\\mmwave_studio_03_00_00_14\\mmWaveStudio\\PostProc\\adc_data.bin", 1)
[22:00:58] [RadarAPI]: Sending start_record command to DCA1000
[22:00:58] Invalid lvdsMode value (0). [error -4016]
[22:01:02] [RadarAPI]: ar1.StartFrame()
[22:01:02] [RadarAPI]: Status: Passed
[22:01:02] Frame start async event received!
[22:01:02] [RadarAPI]: Frame Ended
[22:01:02] Frame End async event received!
[22:01:06] [RadarAPI]: ar1.StartMatlabPostProc("C:\\ti\\mmwave_studio_03_00_00_14\\mmWaveStudio\\PostProc\\adc_data.bin")
[22:01:06] [RadarAPI]: No of files Captured: 0, Total no of frames for each device : 8
[22:01:06] Error : The number of files captured is zero!
