[19:31:03] Matlab Runtime Engine is installed
[19:31:03] [RadarAPI]: Starting Matlab Engine..
[19:31:03] [RadarAPI]: Error: “MatlabPostProcGui.MatlabPostProcGUIClass”的类型初始值设定项引发异常。
[19:31:03] Trace:
[19:31:03] 在 MatlabPostProcGui.MatlabPostProcGUIClass..ctor()
[19:31:03] 在 AR1xController.frmAR1Main.InitMatlabPostProcEngine(String PostProcesspath)
[19:31:03] [RadarAPI]: Error: Error occured in Matlab Initialization
[19:31:03] [RadarAPI]: Matlab Engine couldn't be Started..
[19:31:04] [RadarAPI]: ar1.selectCascadeMode(0)
[19:31:04] [RadarAPI]: Status: Passed
[19:31:04] [RadarAPI]: ar1.LoadSettings('C:\Users\38645\AppData\Roaming\RSTD\ar1gui.ini')
[19:31:04] [RadarAPI]: Error: 未将对象引用设置到对象的实例。
[19:31:04] Trace:
[19:31:04] 在 AR1xController.ScriptOps.getMatlabPostProcVersion()
[19:31:04]
[19:31:04] &&&&&&&&&&&&&&&&&&&&
[19:31:04] ***Script FAILED!***
[19:31:04] Exception message is:
[19:31:04] Can't allocate memory for MXArray from unmanaged code
mmwave studio版本为mmWave Studio 02.01.01.00,
MCR_R2015aSP1_win32_installer和Microsoft Visual C++ 2013 Redistributable package已经安装过了,为什么还会有这种问题
