1、Probability error occurs during power-on. Indicator DS1 is red on (hardware error occurs)
2、When the configuration program is loaded through the upper computer, the indicator DS1 is red on
In a word, the board is unstable and the error rate is very high. Please confirm whether it can be returned and replaced. Thank you!
It has been confirmed that there is no problem with the power supply, or the error is still reported. Because there is a problem with the new one, the seller asked us to find TI's engineer to confirm the quality problem and contact Mouser to return and replace the goods. thank you
