Other Parts Discussed in Thread: AWR2944, AWR2243
我们参考《基于AWR2944的汽车雷达DDMA波形设计》文档4.2.中的方式验证AWR2243的移相器精度。我们希望每一次以2pi / 16 步进进行移相,结果是错误的,但是以2pi / 8进行移相,结果却是正确的。
如上图所示,为移相2派 / 16的Heatmap, 静止目标不移相多普勒索引应该是257,移相32个格子的多普勒索引预期为257 - 32 = 225 ,测出来却是481
如上图所以,为移相4派/ 16的Heatmap,静止目标位置为257-32*2 = 193,符合预期
我们无法确定哪里出了问题,想请教有什么排查办法?
下面是我们的配置文件:
1.单天线移相2pi / 16
# #cgu_mmwave_radar_config # # #Global configuration #Advanced frame test enable/disable; 1 - Advanced frame; 0 - Legacy frame #Continuous mode test enable/disable; 1 - Enable; 0 - Disable #Dynamic chirp test enable/disable; 1 - Enable; 0 - Disable; This should not be enabled if Advanced chirp test is enabled #Dynamic profile test enable/disable; 1 - Enable; 0 - Disable #Advanced chirp test enable/disable; 1 - Enable; 0 - Disable; The legacy chirp API is not required if this is enabled #Firmware download enable/disable; 1 - Enable; 0 - Disable #Calibration enable/disable; To perform calibration store/restore; 1 - Enable; 0 - Disable #Calibration Store/Restore; If CalibEnable = 1, then whether to store/restore; 1 - Store; 0 - Restore #Cascade device map; 1 - Master ; 2 - Slave1 ; 4 - Slave2 ; 8 - Slave3 # LinkAdvanceFrameTest=1; temp_enable=0; temp_monitoringtime=1000; LinkContModeTest=0; LinkDynChirpTest=0; LinkDynProfileTest=0; LinkAdvChirpTest=0; EnableFwDownload=1; CalibEnable=0; CalibStoreRestore=1; CascadeDeviceMap=15; #END # #power on master arguments, please modify if needed. #rlClientCbs_t: crcType 0:16Bit/1:32Bit/2:64Bit, ackTimeout # crcType=0; ackTimeout=1000; #END # #channel config parameters, please modify if needed. #rlChanCfg_t # channelTx=7; channelRx=15; cascading=0; #END # #ADC out config parameters, please modify if needed. #rlAdcOutCfg_t # adcBits=2; adcFormat=1; #END # #DATA format config parameters, please modify if needed. #rlDevDataFmtCfg_t # rxChanEn=15; adcBitsD=2; adcFmt=1; iqSwapSel=0; chInterleave=0; #END # #Low power config Paramters, please modify if needed. #rlLowPowerModeCfg_t # anaCfg=0; lpAdcMode=0; #END # #Data Path config parameters, please modify if needed #rlDevDataPathCfg_t # intfSel=1; transferFmtPkt0=6; transferFmtPkt1=0; cqConfig=2; cq0TransSize=64; cq1TransSize=64; cq2TransSize=64; #END # #LVDS clock config parameters, please modify if needed #rlDevDataPathClkCfg_t # laneClk=1; dataRate=2; #END # #SET HSI clock parameters, please modify if needed. #rlDevHsiClk_t # hsiClk=5 #END # #LANE config parameters, please modify if needed. #rlDevLaneEnable_t # laneEn=15; #END # #LVDS Lane Config parameters, please modify if needed. #rlDevLvdsLaneCfg_t # laneFmtMap=0; laneParamCfg=0; #END # #CSI2 Lane Config parameters, please modify if needed. #rlDevCsi2Cfg_t # lanePosPolSel=218145; #END # #Programmable Filter config parameters, please modify if needed. #rlRfProgFiltConf_t # profileId=0; coeffStartIdx=0; progFiltLen=14; progFiltFreqShift=100; #END # #Profile config parameters, please modify if needed. #rlProfileCfg_t # profileId=0; pfVcoSelect=2; startFreqConst=1491308088; idleTimeConst=200; adcStartTimeConst=279; rampEndTime=6000; txOutPowerBackoffCode=0; txPhaseShifter=0; freqSlopeConst=28; txStartTime=0; numAdcSamples=512; digOutSampleRate=9230; hpfCornerFreq1=3; hpfCornerFreq2=2; rxGain=48; #END # #Profile config parameters, please modify if needed. #rlProfileCfg_t # profileId=1; pfVcoSelect=2; startFreqConst=1491308088; idleTimeConst=200; adcStartTimeConst=273; rampEndTime=5070; txOutPowerBackoffCode=0; txPhaseShifter=0; freqSlopeConst=33; txStartTime=0; numAdcSamples=512; digOutSampleRate=10875; hpfCornerFreq1=3; hpfCornerFreq2=2; rxGain=48; #END # #Profile config parameters, please modify if needed. #rlProfileCfg_t # profileId=2; pfVcoSelect=2; startFreqConst=1491308088; idleTimeConst=200; adcStartTimeConst=270; rampEndTime=1643; txOutPowerBackoffCode=0; txPhaseShifter=0; freqSlopeConst=231; txStartTime=0; numAdcSamples=256; digOutSampleRate=19000; hpfCornerFreq1=3; hpfCornerFreq2=2; rxGain=48; #END # #Profile config parameters, please modify if needed. #rlProfileCfg_t # profileId=3; pfVcoSelect=2; startFreqConst=1491308088; idleTimeConst=200; adcStartTimeConst=269; rampEndTime=1776; txOutPowerBackoffCode=0; txPhaseShifter=0; freqSlopeConst=211; txStartTime=0; numAdcSamples=256; digOutSampleRate=17310; hpfCornerFreq1=3; hpfCornerFreq2=2; rxGain=48; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=0; chirpEndIdx=0; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=1; chirpEndIdx=1; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=4; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=2; chirpEndIdx=2; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=3; chirpEndIdx=3; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=4; chirpEndIdx=4; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=5; chirpEndIdx=5; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=4; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=6; chirpEndIdx=6; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=7; chirpEndIdx=7; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=8; chirpEndIdx=8; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=9; chirpEndIdx=9; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=10; chirpEndIdx=10; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=11; chirpEndIdx=11; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=12; chirpEndIdx=12; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=13; chirpEndIdx=13; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=14; chirpEndIdx=14; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=15; chirpEndIdx=15; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=16; chirpEndIdx=16; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=17; chirpEndIdx=17; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=18; chirpEndIdx=18; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=19; chirpEndIdx=19; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=20; chirpEndIdx=20; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=21; chirpEndIdx=21; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=22; chirpEndIdx=22; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=23; chirpEndIdx=23; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=24; chirpEndIdx=24; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=3; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=25; chirpEndIdx=25; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=3; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=26; chirpEndIdx=26; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=3; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=27; chirpEndIdx=27; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=3; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=0; chirpEndIdx=0; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=1; chirpEndIdx=1; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=2; chirpEndIdx=2; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=3; chirpEndIdx=3; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=4; chirpEndIdx=4; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=5; chirpEndIdx=5; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=6; chirpEndIdx=6; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=7; chirpEndIdx=7; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=8; chirpEndIdx=8; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=9; chirpEndIdx=9; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=10; chirpEndIdx=10; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=11; chirpEndIdx=11; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=12; chirpEndIdx=12; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=13; chirpEndIdx=13; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=14; chirpEndIdx=14; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=15; chirpEndIdx=15; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=16; chirpEndIdx=16; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=17; chirpEndIdx=17; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=18; chirpEndIdx=18; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=19; chirpEndIdx=19; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=20; chirpEndIdx=20; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=21; chirpEndIdx=21; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=22; chirpEndIdx=22; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=23; chirpEndIdx=23; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=24; chirpEndIdx=24; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=6; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=25; chirpEndIdx=25; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=6; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=26; chirpEndIdx=26; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=6; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=27; chirpEndIdx=27; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=6; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=0; chirpEndIdx=0; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=1; chirpEndIdx=1; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=2; chirpEndIdx=2; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=3; chirpEndIdx=3; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=4; chirpEndIdx=4; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=5; chirpEndIdx=5; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=6; chirpEndIdx=6; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=7; chirpEndIdx=7; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=8; chirpEndIdx=8; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=9; chirpEndIdx=9; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=10; chirpEndIdx=10; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=11; chirpEndIdx=11; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=12; chirpEndIdx=12; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=13; chirpEndIdx=13; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=14; chirpEndIdx=14; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=15; chirpEndIdx=15; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=16; chirpEndIdx=16; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=17; chirpEndIdx=17; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=18; chirpEndIdx=18; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=19; chirpEndIdx=19; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=20; chirpEndIdx=20; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=21; chirpEndIdx=21; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=22; chirpEndIdx=22; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=23; chirpEndIdx=23; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=24; chirpEndIdx=24; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=6; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=25; chirpEndIdx=25; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=6; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=26; chirpEndIdx=26; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=6; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=27; chirpEndIdx=27; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=6; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=0; chirpEndIdx=0; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=4; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=1; chirpEndIdx=1; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=2; chirpEndIdx=2; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=3; chirpEndIdx=3; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=4; chirpEndIdx=4; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=4; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=5; chirpEndIdx=5; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=6; chirpEndIdx=6; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=7; chirpEndIdx=7; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=8; chirpEndIdx=8; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=9; chirpEndIdx=9; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=10; chirpEndIdx=10; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=11; chirpEndIdx=11; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=12; chirpEndIdx=12; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=13; chirpEndIdx=13; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=14; chirpEndIdx=14; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=15; chirpEndIdx=15; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=16; chirpEndIdx=16; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=17; chirpEndIdx=17; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=18; chirpEndIdx=18; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=19; chirpEndIdx=19; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=20; chirpEndIdx=20; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=21; chirpEndIdx=21; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=22; chirpEndIdx=22; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=23; chirpEndIdx=23; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=24; chirpEndIdx=24; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=3; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=25; chirpEndIdx=25; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=3; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=26; chirpEndIdx=26; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=3; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=27; chirpEndIdx=27; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=3; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=0; chirpEndIdxph=0; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=1; chirpEndIdxph=1; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=2; chirpEndIdxph=2; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=3; chirpEndIdxph=3; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=4; chirpEndIdxph=4; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=5; chirpEndIdxph=5; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=6; chirpEndIdxph=6; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=7; chirpEndIdxph=7; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=8; chirpEndIdxph=8; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=9; chirpEndIdxph=9; tx0PhaseShiftph=16; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=10; chirpEndIdxph=10; tx0PhaseShiftph=32; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=11; chirpEndIdxph=11; tx0PhaseShiftph=48; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=12; chirpEndIdxph=12; tx0PhaseShiftph=64; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=13; chirpEndIdxph=13; tx0PhaseShiftph=80; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=14; chirpEndIdxph=14; tx0PhaseShiftph=96; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=15; chirpEndIdxph=15; tx0PhaseShiftph=112; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=16; chirpEndIdxph=16; tx0PhaseShiftph=128; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=17; chirpEndIdxph=17; tx0PhaseShiftph=144; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=18; chirpEndIdxph=18; tx0PhaseShiftph=160; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=19; chirpEndIdxph=19; tx0PhaseShiftph=176; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=20; chirpEndIdxph=20; tx0PhaseShiftph=192; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=21; chirpEndIdxph=21; tx0PhaseShiftph=208; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=22; chirpEndIdxph=22; tx0PhaseShiftph=224; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=23; chirpEndIdxph=23; tx0PhaseShiftph=240; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=24; chirpEndIdxph=24; tx0PhaseShiftph=152; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=25; chirpEndIdxph=25; tx0PhaseShiftph=180; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=26; chirpEndIdxph=26; tx0PhaseShiftph=204; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=27; chirpEndIdxph=27; tx0PhaseShiftph=232; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=0; chirpEndIdxph=0; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=1; chirpEndIdxph=1; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=2; chirpEndIdxph=2; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=3; chirpEndIdxph=3; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=4; chirpEndIdxph=4; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=5; chirpEndIdxph=5; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=6; chirpEndIdxph=6; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=7; chirpEndIdxph=7; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=8; chirpEndIdxph=8; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=9; chirpEndIdxph=9; tx0PhaseShiftph=0; tx1PhaseShiftph=76; tx2PhaseShiftph=52; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=10; chirpEndIdxph=10; tx0PhaseShiftph=0; tx1PhaseShiftph=152; tx2PhaseShiftph=104; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=11; chirpEndIdxph=11; tx0PhaseShiftph=0; tx1PhaseShiftph=232; tx2PhaseShiftph=152; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=12; chirpEndIdxph=12; tx0PhaseShiftph=0; tx1PhaseShiftph=52; tx2PhaseShiftph=204; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=13; chirpEndIdxph=13; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=14; chirpEndIdxph=14; tx0PhaseShiftph=0; tx1PhaseShiftph=204; tx2PhaseShiftph=52; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=15; chirpEndIdxph=15; tx0PhaseShiftph=0; tx1PhaseShiftph=24; tx2PhaseShiftph=104; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=16; chirpEndIdxph=16; tx0PhaseShiftph=0; tx1PhaseShiftph=104; tx2PhaseShiftph=152; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=17; chirpEndIdxph=17; tx0PhaseShiftph=0; tx1PhaseShiftph=180; tx2PhaseShiftph=204; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=18; chirpEndIdxph=18; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=19; chirpEndIdxph=19; tx0PhaseShiftph=0; tx1PhaseShiftph=76; tx2PhaseShiftph=52; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=20; chirpEndIdxph=20; tx0PhaseShiftph=0; tx1PhaseShiftph=152; tx2PhaseShiftph=104; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=21; chirpEndIdxph=21; tx0PhaseShiftph=0; tx1PhaseShiftph=232; tx2PhaseShiftph=152; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=22; chirpEndIdxph=22; tx0PhaseShiftph=0; tx1PhaseShiftph=52; tx2PhaseShiftph=204; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=23; chirpEndIdxph=23; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=24; chirpEndIdxph=24; tx0PhaseShiftph=0; tx1PhaseShiftph=204; tx2PhaseShiftph=52; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=25; chirpEndIdxph=25; tx0PhaseShiftph=0; tx1PhaseShiftph=24; tx2PhaseShiftph=104; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=26; chirpEndIdxph=26; tx0PhaseShiftph=0; tx1PhaseShiftph=104; tx2PhaseShiftph=152; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=27; chirpEndIdxph=27; tx0PhaseShiftph=0; tx1PhaseShiftph=180; tx2PhaseShiftph=204; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=0; chirpEndIdxph=0; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=1; chirpEndIdxph=1; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=2; chirpEndIdxph=2; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=3; chirpEndIdxph=3; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=4; chirpEndIdxph=4; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=5; chirpEndIdxph=5; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=6; chirpEndIdxph=6; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=7; chirpEndIdxph=7; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=8; chirpEndIdxph=8; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=9; chirpEndIdxph=9; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=104; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=10; chirpEndIdxph=10; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=204; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=11; chirpEndIdxph=11; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=52; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=12; chirpEndIdxph=12; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=152; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=13; chirpEndIdxph=13; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=14; chirpEndIdxph=14; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=104; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=15; chirpEndIdxph=15; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=204; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=16; chirpEndIdxph=16; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=52; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=17; chirpEndIdxph=17; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=152; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=18; chirpEndIdxph=18; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=19; chirpEndIdxph=19; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=104; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=20; chirpEndIdxph=20; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=204; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=21; chirpEndIdxph=21; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=52; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=22; chirpEndIdxph=22; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=152; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=23; chirpEndIdxph=23; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=24; chirpEndIdxph=24; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=104; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=25; chirpEndIdxph=25; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=204; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=26; chirpEndIdxph=26; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=52; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=27; chirpEndIdxph=27; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=152; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=0; chirpEndIdxph=0; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=1; chirpEndIdxph=1; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=2; chirpEndIdxph=2; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=3; chirpEndIdxph=3; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=4; chirpEndIdxph=4; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=5; chirpEndIdxph=5; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=6; chirpEndIdxph=6; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=7; chirpEndIdxph=7; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=8; chirpEndIdxph=8; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=9; chirpEndIdxph=9; tx0PhaseShiftph=180; tx1PhaseShiftph=152; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=10; chirpEndIdxph=10; tx0PhaseShiftph=104; tx1PhaseShiftph=52; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=11; chirpEndIdxph=11; tx0PhaseShiftph=24; tx1PhaseShiftph=204; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=12; chirpEndIdxph=12; tx0PhaseShiftph=204; tx1PhaseShiftph=104; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=13; chirpEndIdxph=13; tx0PhaseShiftph=128; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=14; chirpEndIdxph=14; tx0PhaseShiftph=52; tx1PhaseShiftph=152; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=15; chirpEndIdxph=15; tx0PhaseShiftph=232; tx1PhaseShiftph=52; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=16; chirpEndIdxph=16; tx0PhaseShiftph=152; tx1PhaseShiftph=204; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=17; chirpEndIdxph=17; tx0PhaseShiftph=76; tx1PhaseShiftph=104; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=18; chirpEndIdxph=18; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=19; chirpEndIdxph=19; tx0PhaseShiftph=180; tx1PhaseShiftph=152; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=20; chirpEndIdxph=20; tx0PhaseShiftph=104; tx1PhaseShiftph=52; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=21; chirpEndIdxph=21; tx0PhaseShiftph=24; tx1PhaseShiftph=204; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=22; chirpEndIdxph=22; tx0PhaseShiftph=204; tx1PhaseShiftph=104; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=23; chirpEndIdxph=23; tx0PhaseShiftph=128; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=24; chirpEndIdxph=24; tx0PhaseShiftph=52; tx1PhaseShiftph=152; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=25; chirpEndIdxph=25; tx0PhaseShiftph=232; tx1PhaseShiftph=52; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=26; chirpEndIdxph=26; tx0PhaseShiftph=152; tx1PhaseShiftph=204; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=27; chirpEndIdxph=27; tx0PhaseShiftph=76; tx1PhaseShiftph=104; tx2PhaseShiftph=0; #END # #Frame configuration parameters, please modify if needed. #rlFrameCfg_t # chirpStartIdxFCF=0; chirpEndIdxFCF=11; frameCount=0; loopCount=64; periodicity=40000000; triggerDelay=0; numAdcSamples=512; triggerSelect=1; #END # #Advance Frame configuration parameters, please modify if needed. numOfSubFrames=4; forceProfile=0; numFrames=0; loopBackCfg=0; triggerSelect=1; frameTrigDelay=0; #end # #4th sub Frame configuration parameters, please modify if needed. forceProfileIdx=0; chirpStartIdxAF=24; numOfChirps=4; numLoops=128; burstPeriodicity=2200000; chirpStartIdxOffset=0; numOfBurst=1; numOfBurstLoops=1; subFramePeriodicity=2200000; numAdcSamplesAF=512 numChirpsInDataPacket=1 #end # #3rd sub Frame configuration parameters, please modify if needed. forceProfileIdx=0; chirpStartIdxAF=8; numOfChirps=16; numLoops=32; burstPeriodicity=2000000; chirpStartIdxOffset=0; numOfBurst=1; numOfBurstLoops=1; subFramePeriodicity=2000000; numAdcSamplesAF=512 numChirpsInDataPacket=1 #end # #2nd sub Frame configuration parameters, please modify if needed. forceProfileIdx=0; chirpStartIdxAF=4; numOfChirps=4; numLoops=128; burstPeriodicity=5600000; chirpStartIdxOffset=0; numOfBurst=1; numOfBurstLoops=1; subFramePeriodicity=5600000; numAdcSamplesAF=1024 numChirpsInDataPacket=1 #end # #1st sub Frame configuration parameters, please modify if needed. forceProfileIdx=0; chirpStartIdxAF=0; numOfChirps=4; numLoops=128; burstPeriodicity=6600000; chirpStartIdxOffset=0; numOfBurst=1; numOfBurstLoops=1; subFramePeriodicity=6600000; numAdcSamplesAF=1024 numChirpsInDataPacket=1 #end
2. 单天线移相 4pi / 16
# #cgu_mmwave_radar_config # # #Global configuration #Advanced frame test enable/disable; 1 - Advanced frame; 0 - Legacy frame #Continuous mode test enable/disable; 1 - Enable; 0 - Disable #Dynamic chirp test enable/disable; 1 - Enable; 0 - Disable; This should not be enabled if Advanced chirp test is enabled #Dynamic profile test enable/disable; 1 - Enable; 0 - Disable #Advanced chirp test enable/disable; 1 - Enable; 0 - Disable; The legacy chirp API is not required if this is enabled #Firmware download enable/disable; 1 - Enable; 0 - Disable #Calibration enable/disable; To perform calibration store/restore; 1 - Enable; 0 - Disable #Calibration Store/Restore; If CalibEnable = 1, then whether to store/restore; 1 - Store; 0 - Restore #Cascade device map; 1 - Master ; 2 - Slave1 ; 4 - Slave2 ; 8 - Slave3 # LinkAdvanceFrameTest=1; temp_enable=0; temp_monitoringtime=1000; LinkContModeTest=0; LinkDynChirpTest=0; LinkDynProfileTest=0; LinkAdvChirpTest=0; EnableFwDownload=1; CalibEnable=0; CalibStoreRestore=1; CascadeDeviceMap=15; #END # #power on master arguments, please modify if needed. #rlClientCbs_t: crcType 0:16Bit/1:32Bit/2:64Bit, ackTimeout # crcType=0; ackTimeout=1000; #END # #channel config parameters, please modify if needed. #rlChanCfg_t # channelTx=7; channelRx=15; cascading=0; #END # #ADC out config parameters, please modify if needed. #rlAdcOutCfg_t # adcBits=2; adcFormat=1; #END # #DATA format config parameters, please modify if needed. #rlDevDataFmtCfg_t # rxChanEn=15; adcBitsD=2; adcFmt=1; iqSwapSel=0; chInterleave=0; #END # #Low power config Paramters, please modify if needed. #rlLowPowerModeCfg_t # anaCfg=0; lpAdcMode=0; #END # #Data Path config parameters, please modify if needed #rlDevDataPathCfg_t # intfSel=1; transferFmtPkt0=6; transferFmtPkt1=0; cqConfig=2; cq0TransSize=64; cq1TransSize=64; cq2TransSize=64; #END # #LVDS clock config parameters, please modify if needed #rlDevDataPathClkCfg_t # laneClk=1; dataRate=2; #END # #SET HSI clock parameters, please modify if needed. #rlDevHsiClk_t # hsiClk=5 #END # #LANE config parameters, please modify if needed. #rlDevLaneEnable_t # laneEn=15; #END # #LVDS Lane Config parameters, please modify if needed. #rlDevLvdsLaneCfg_t # laneFmtMap=0; laneParamCfg=0; #END # #CSI2 Lane Config parameters, please modify if needed. #rlDevCsi2Cfg_t # lanePosPolSel=218145; #END # #Programmable Filter config parameters, please modify if needed. #rlRfProgFiltConf_t # profileId=0; coeffStartIdx=0; progFiltLen=14; progFiltFreqShift=100; #END # #Profile config parameters, please modify if needed. #rlProfileCfg_t # profileId=0; pfVcoSelect=2; startFreqConst=1491308088; idleTimeConst=200; adcStartTimeConst=279; rampEndTime=6000; txOutPowerBackoffCode=0; txPhaseShifter=0; freqSlopeConst=28; txStartTime=0; numAdcSamples=512; digOutSampleRate=9230; hpfCornerFreq1=3; hpfCornerFreq2=2; rxGain=48; #END # #Profile config parameters, please modify if needed. #rlProfileCfg_t # profileId=1; pfVcoSelect=2; startFreqConst=1491308088; idleTimeConst=200; adcStartTimeConst=273; rampEndTime=5070; txOutPowerBackoffCode=0; txPhaseShifter=0; freqSlopeConst=33; txStartTime=0; numAdcSamples=512; digOutSampleRate=10875; hpfCornerFreq1=3; hpfCornerFreq2=2; rxGain=48; #END # #Profile config parameters, please modify if needed. #rlProfileCfg_t # profileId=2; pfVcoSelect=2; startFreqConst=1491308088; idleTimeConst=200; adcStartTimeConst=270; rampEndTime=1643; txOutPowerBackoffCode=0; txPhaseShifter=0; freqSlopeConst=231; txStartTime=0; numAdcSamples=256; digOutSampleRate=19000; hpfCornerFreq1=3; hpfCornerFreq2=2; rxGain=48; #END # #Profile config parameters, please modify if needed. #rlProfileCfg_t # profileId=3; pfVcoSelect=2; startFreqConst=1491308088; idleTimeConst=200; adcStartTimeConst=269; rampEndTime=1776; txOutPowerBackoffCode=0; txPhaseShifter=0; freqSlopeConst=211; txStartTime=0; numAdcSamples=256; digOutSampleRate=17310; hpfCornerFreq1=3; hpfCornerFreq2=2; rxGain=48; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=0; chirpEndIdx=0; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=1; chirpEndIdx=1; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=4; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=2; chirpEndIdx=2; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=3; chirpEndIdx=3; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=4; chirpEndIdx=4; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=5; chirpEndIdx=5; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=4; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=6; chirpEndIdx=6; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=7; chirpEndIdx=7; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=8; chirpEndIdx=8; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=9; chirpEndIdx=9; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=10; chirpEndIdx=10; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=11; chirpEndIdx=11; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=12; chirpEndIdx=12; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=13; chirpEndIdx=13; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=14; chirpEndIdx=14; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=15; chirpEndIdx=15; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=16; chirpEndIdx=16; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=17; chirpEndIdx=17; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=18; chirpEndIdx=18; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=19; chirpEndIdx=19; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=20; chirpEndIdx=20; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=21; chirpEndIdx=21; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=22; chirpEndIdx=22; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=23; chirpEndIdx=23; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=24; chirpEndIdx=24; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=3; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=25; chirpEndIdx=25; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=3; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=26; chirpEndIdx=26; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=3; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 1 # chirpStartIdx=27; chirpEndIdx=27; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=3; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=0; chirpEndIdx=0; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=1; chirpEndIdx=1; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=2; chirpEndIdx=2; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=3; chirpEndIdx=3; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=4; chirpEndIdx=4; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=5; chirpEndIdx=5; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=6; chirpEndIdx=6; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=7; chirpEndIdx=7; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=8; chirpEndIdx=8; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=9; chirpEndIdx=9; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=10; chirpEndIdx=10; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=11; chirpEndIdx=11; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=12; chirpEndIdx=12; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=13; chirpEndIdx=13; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=14; chirpEndIdx=14; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=15; chirpEndIdx=15; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=16; chirpEndIdx=16; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=17; chirpEndIdx=17; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=18; chirpEndIdx=18; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=19; chirpEndIdx=19; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=20; chirpEndIdx=20; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=21; chirpEndIdx=21; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=22; chirpEndIdx=22; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=23; chirpEndIdx=23; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=24; chirpEndIdx=24; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=6; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=25; chirpEndIdx=25; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=6; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=26; chirpEndIdx=26; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=6; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 2 # chirpStartIdx=27; chirpEndIdx=27; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=6; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=0; chirpEndIdx=0; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=1; chirpEndIdx=1; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=2; chirpEndIdx=2; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=3; chirpEndIdx=3; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=4; chirpEndIdx=4; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=5; chirpEndIdx=5; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=6; chirpEndIdx=6; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=7; chirpEndIdx=7; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=1; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=8; chirpEndIdx=8; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=9; chirpEndIdx=9; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=10; chirpEndIdx=10; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=11; chirpEndIdx=11; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=12; chirpEndIdx=12; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=13; chirpEndIdx=13; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=14; chirpEndIdx=14; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=15; chirpEndIdx=15; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=16; chirpEndIdx=16; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=17; chirpEndIdx=17; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=18; chirpEndIdx=18; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=19; chirpEndIdx=19; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=20; chirpEndIdx=20; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=21; chirpEndIdx=21; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=22; chirpEndIdx=22; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=23; chirpEndIdx=23; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=24; chirpEndIdx=24; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=6; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=25; chirpEndIdx=25; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=6; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=26; chirpEndIdx=26; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=6; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 4 # chirpStartIdx=27; chirpEndIdx=27; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=6; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=0; chirpEndIdx=0; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=4; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=1; chirpEndIdx=1; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=2; chirpEndIdx=2; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=3; chirpEndIdx=3; profileIdCPCFG=0; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=4; chirpEndIdx=4; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=4; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=5; chirpEndIdx=5; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=6; chirpEndIdx=6; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=7; chirpEndIdx=7; profileIdCPCFG=1; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=8; chirpEndIdx=8; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=9; chirpEndIdx=9; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=10; chirpEndIdx=10; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=11; chirpEndIdx=11; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=12; chirpEndIdx=12; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=13; chirpEndIdx=13; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=14; chirpEndIdx=14; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=15; chirpEndIdx=15; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=16; chirpEndIdx=16; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=17; chirpEndIdx=17; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=18; chirpEndIdx=18; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=19; chirpEndIdx=19; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=20; chirpEndIdx=20; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=21; chirpEndIdx=21; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=22; chirpEndIdx=22; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=23; chirpEndIdx=23; profileIdCPCFG=2; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=0; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=24; chirpEndIdx=24; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=3; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=25; chirpEndIdx=25; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=3; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=26; chirpEndIdx=26; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=3; #END # #Chirp Configuration parameters, please modify if needed. #rlChirpCfg_t devicemap is 8 # chirpStartIdx=27; chirpEndIdx=27; profileIdCPCFG=3; startFreqVar=0; freqSlopeVar=0; idleTimeVar=0; adcStartTimeVar=0; txEnable=3; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=0; chirpEndIdxph=0; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=1; chirpEndIdxph=1; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=2; chirpEndIdxph=2; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=3; chirpEndIdxph=3; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=4; chirpEndIdxph=4; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=5; chirpEndIdxph=5; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=6; chirpEndIdxph=6; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=7; chirpEndIdxph=7; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=8; chirpEndIdxph=8; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=9; chirpEndIdxph=9; tx0PhaseShiftph=32; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=10; chirpEndIdxph=10; tx0PhaseShiftph=64; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=11; chirpEndIdxph=11; tx0PhaseShiftph=96; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=12; chirpEndIdxph=12; tx0PhaseShiftph=128; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=13; chirpEndIdxph=13; tx0PhaseShiftph=160; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=14; chirpEndIdxph=14; tx0PhaseShiftph=192; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=15; chirpEndIdxph=15; tx0PhaseShiftph=224; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=16; chirpEndIdxph=16; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=17; chirpEndIdxph=17; tx0PhaseShiftph=32; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=18; chirpEndIdxph=18; tx0PhaseShiftph=64; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=19; chirpEndIdxph=19; tx0PhaseShiftph=96; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=20; chirpEndIdxph=20; tx0PhaseShiftph=128; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=21; chirpEndIdxph=21; tx0PhaseShiftph=160; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=22; chirpEndIdxph=22; tx0PhaseShiftph=192; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=23; chirpEndIdxph=23; tx0PhaseShiftph=224; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=24; chirpEndIdxph=24; tx0PhaseShiftph=152; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=25; chirpEndIdxph=25; tx0PhaseShiftph=180; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=26; chirpEndIdxph=26; tx0PhaseShiftph=204; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 1 # chirpStartIdxph=27; chirpEndIdxph=27; tx0PhaseShiftph=232; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=0; chirpEndIdxph=0; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=1; chirpEndIdxph=1; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=2; chirpEndIdxph=2; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=3; chirpEndIdxph=3; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=4; chirpEndIdxph=4; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=5; chirpEndIdxph=5; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=6; chirpEndIdxph=6; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=7; chirpEndIdxph=7; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=8; chirpEndIdxph=8; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=9; chirpEndIdxph=9; tx0PhaseShiftph=0; tx1PhaseShiftph=76; tx2PhaseShiftph=52; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=10; chirpEndIdxph=10; tx0PhaseShiftph=0; tx1PhaseShiftph=152; tx2PhaseShiftph=104; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=11; chirpEndIdxph=11; tx0PhaseShiftph=0; tx1PhaseShiftph=232; tx2PhaseShiftph=152; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=12; chirpEndIdxph=12; tx0PhaseShiftph=0; tx1PhaseShiftph=52; tx2PhaseShiftph=204; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=13; chirpEndIdxph=13; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=14; chirpEndIdxph=14; tx0PhaseShiftph=0; tx1PhaseShiftph=204; tx2PhaseShiftph=52; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=15; chirpEndIdxph=15; tx0PhaseShiftph=0; tx1PhaseShiftph=24; tx2PhaseShiftph=104; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=16; chirpEndIdxph=16; tx0PhaseShiftph=0; tx1PhaseShiftph=104; tx2PhaseShiftph=152; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=17; chirpEndIdxph=17; tx0PhaseShiftph=0; tx1PhaseShiftph=180; tx2PhaseShiftph=204; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=18; chirpEndIdxph=18; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=19; chirpEndIdxph=19; tx0PhaseShiftph=0; tx1PhaseShiftph=76; tx2PhaseShiftph=52; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=20; chirpEndIdxph=20; tx0PhaseShiftph=0; tx1PhaseShiftph=152; tx2PhaseShiftph=104; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=21; chirpEndIdxph=21; tx0PhaseShiftph=0; tx1PhaseShiftph=232; tx2PhaseShiftph=152; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=22; chirpEndIdxph=22; tx0PhaseShiftph=0; tx1PhaseShiftph=52; tx2PhaseShiftph=204; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=23; chirpEndIdxph=23; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=24; chirpEndIdxph=24; tx0PhaseShiftph=0; tx1PhaseShiftph=204; tx2PhaseShiftph=52; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=25; chirpEndIdxph=25; tx0PhaseShiftph=0; tx1PhaseShiftph=24; tx2PhaseShiftph=104; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=26; chirpEndIdxph=26; tx0PhaseShiftph=0; tx1PhaseShiftph=104; tx2PhaseShiftph=152; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 2 # chirpStartIdxph=27; chirpEndIdxph=27; tx0PhaseShiftph=0; tx1PhaseShiftph=180; tx2PhaseShiftph=204; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=0; chirpEndIdxph=0; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=1; chirpEndIdxph=1; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=2; chirpEndIdxph=2; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=3; chirpEndIdxph=3; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=4; chirpEndIdxph=4; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=5; chirpEndIdxph=5; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=6; chirpEndIdxph=6; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=7; chirpEndIdxph=7; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=8; chirpEndIdxph=8; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=9; chirpEndIdxph=9; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=104; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=10; chirpEndIdxph=10; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=204; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=11; chirpEndIdxph=11; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=52; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=12; chirpEndIdxph=12; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=152; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=13; chirpEndIdxph=13; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=14; chirpEndIdxph=14; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=104; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=15; chirpEndIdxph=15; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=204; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=16; chirpEndIdxph=16; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=52; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=17; chirpEndIdxph=17; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=152; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=18; chirpEndIdxph=18; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=19; chirpEndIdxph=19; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=104; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=20; chirpEndIdxph=20; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=204; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=21; chirpEndIdxph=21; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=52; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=22; chirpEndIdxph=22; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=152; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=23; chirpEndIdxph=23; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=24; chirpEndIdxph=24; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=104; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=25; chirpEndIdxph=25; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=204; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=26; chirpEndIdxph=26; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=52; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 4 # chirpStartIdxph=27; chirpEndIdxph=27; tx0PhaseShiftph=0; tx1PhaseShiftph=128; tx2PhaseShiftph=152; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=0; chirpEndIdxph=0; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=1; chirpEndIdxph=1; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=2; chirpEndIdxph=2; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=3; chirpEndIdxph=3; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=4; chirpEndIdxph=4; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=5; chirpEndIdxph=5; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=6; chirpEndIdxph=6; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=7; chirpEndIdxph=7; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=8; chirpEndIdxph=8; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=9; chirpEndIdxph=9; tx0PhaseShiftph=180; tx1PhaseShiftph=152; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=10; chirpEndIdxph=10; tx0PhaseShiftph=104; tx1PhaseShiftph=52; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=11; chirpEndIdxph=11; tx0PhaseShiftph=24; tx1PhaseShiftph=204; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=12; chirpEndIdxph=12; tx0PhaseShiftph=204; tx1PhaseShiftph=104; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=13; chirpEndIdxph=13; tx0PhaseShiftph=128; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=14; chirpEndIdxph=14; tx0PhaseShiftph=52; tx1PhaseShiftph=152; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=15; chirpEndIdxph=15; tx0PhaseShiftph=232; tx1PhaseShiftph=52; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=16; chirpEndIdxph=16; tx0PhaseShiftph=152; tx1PhaseShiftph=204; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=17; chirpEndIdxph=17; tx0PhaseShiftph=76; tx1PhaseShiftph=104; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=18; chirpEndIdxph=18; tx0PhaseShiftph=0; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=19; chirpEndIdxph=19; tx0PhaseShiftph=180; tx1PhaseShiftph=152; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=20; chirpEndIdxph=20; tx0PhaseShiftph=104; tx1PhaseShiftph=52; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=21; chirpEndIdxph=21; tx0PhaseShiftph=24; tx1PhaseShiftph=204; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=22; chirpEndIdxph=22; tx0PhaseShiftph=204; tx1PhaseShiftph=104; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=23; chirpEndIdxph=23; tx0PhaseShiftph=128; tx1PhaseShiftph=0; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=24; chirpEndIdxph=24; tx0PhaseShiftph=52; tx1PhaseShiftph=152; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=25; chirpEndIdxph=25; tx0PhaseShiftph=232; tx1PhaseShiftph=52; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=26; chirpEndIdxph=26; tx0PhaseShiftph=152; tx1PhaseShiftph=204; tx2PhaseShiftph=0; #END # #Phase Shifter Configuration parameters, please modify if needed. #rlRfPhaseShiftCfg_t devicemap is 8 # chirpStartIdxph=27; chirpEndIdxph=27; tx0PhaseShiftph=76; tx1PhaseShiftph=104; tx2PhaseShiftph=0; #END # #Frame configuration parameters, please modify if needed. #rlFrameCfg_t # chirpStartIdxFCF=0; chirpEndIdxFCF=11; frameCount=0; loopCount=64; periodicity=40000000; triggerDelay=0; numAdcSamples=512; triggerSelect=1; #END # #Advance Frame configuration parameters, please modify if needed. numOfSubFrames=4; forceProfile=0; numFrames=0; loopBackCfg=0; triggerSelect=1; frameTrigDelay=0; #end # #4th sub Frame configuration parameters, please modify if needed. forceProfileIdx=0; chirpStartIdxAF=24; numOfChirps=4; numLoops=128; burstPeriodicity=2200000; chirpStartIdxOffset=0; numOfBurst=1; numOfBurstLoops=1; subFramePeriodicity=2200000; numAdcSamplesAF=512 numChirpsInDataPacket=1 #end # #3rd sub Frame configuration parameters, please modify if needed. forceProfileIdx=0; chirpStartIdxAF=8; numOfChirps=16; numLoops=32; burstPeriodicity=2000000; chirpStartIdxOffset=0; numOfBurst=1; numOfBurstLoops=1; subFramePeriodicity=2000000; numAdcSamplesAF=512 numChirpsInDataPacket=1 #end # #2nd sub Frame configuration parameters, please modify if needed. forceProfileIdx=0; chirpStartIdxAF=4; numOfChirps=4; numLoops=128; burstPeriodicity=5600000; chirpStartIdxOffset=0; numOfBurst=1; numOfBurstLoops=1; subFramePeriodicity=5600000; numAdcSamplesAF=1024 numChirpsInDataPacket=1 #end # #1st sub Frame configuration parameters, please modify if needed. forceProfileIdx=0; chirpStartIdxAF=0; numOfChirps=4; numLoops=128; burstPeriodicity=6600000; chirpStartIdxOffset=0; numOfBurst=1; numOfBurstLoops=1; subFramePeriodicity=6600000; numAdcSamplesAF=1024 numChirpsInDataPacket=1 #end
