您好,我们在使用MMWCAS-DSP-EVM以及MMWCAS-RF-EVM板的时候,用mmwavestudio上位机进行雷达数据的采集,利用了master、slave1和slave3这三个通道,使用官方提供的Cascade_Configuration_MIMO_Test.lua脚本进行配置,配置成功后利用Cascade_Capture.lua脚本进行雷达数据的采集,但是上位机在采集时出现了“TDA Stop Record ACK not received!”的报错。配置成功后利用Capture脚本进行数据采集时的具体打印信息如下:
[19:03:17] Loops Remaining : 10 [19:03:17] Starting TDA ARM... [19:03:17] [RadarAPI]: ar1.TDACaptureCard_StartRecord_mult(1, 0, 0, Cascade_Capture_22xx, 0) [19:03:17] Device 0 - Configuring TDA with Width : 2000 and Height : 1536 [19:03:17] [RadarAPI]: Device 0 - setWidthAndHeight Status: Passed [19:03:17] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [19:03:17] Device 1 - Configuring TDA with Width : 0 and Height : 0 [19:03:17] [RadarAPI]: Device 1 - setWidthAndHeight Status: Passed [19:03:17] Device 2 - Configuring TDA with Width : 0 and Height : 0 [19:03:17] [RadarAPI]: Device 2 - setWidthAndHeight Status: Passed [19:03:17] Device 3 - Configuring TDA with Width : 2000 and Height : 1536 [19:03:17] [RadarAPI]: Device 3 - setWidthAndHeight Status: Passed [19:03:17] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [19:03:17] Sending Frame Periodicity of 100 to TDA.. [19:03:17] [RadarAPI]: Status: Passed. Frame Periodicity sent to TDA [19:03:17] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [19:03:17] Sending Capture Directory with name /mnt/ssd/Cascade_Capture_22xx to TDA.. [19:03:17] [RadarAPI]: Status: Passed. Capture Directory sent to TDA [19:03:17] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [19:03:17] Sending File Allocation of 0 files to TDA.. [19:03:17] [RadarAPI]: Status: Passed. File Allocation sent to TDA [19:03:17] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [19:03:17] Sending Enable Data Packaging (0 - 16-bit; 1 - 12-bit) with value of 0 to TDA.. [19:03:17] [RadarAPI]: Status: Passed. Enable Data Packaging sent to TDA [19:03:17] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [19:03:17] Sending Number of frames to capture with value of 0 to TDA.. [19:03:17] [RadarAPI]: Status: Passed. Number of frames to capture sent to TDA [19:03:17] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [19:03:17] [RadarAPI]: Status: Passed for notifying TDA about Creating Application [19:03:17] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [19:03:17] [RadarAPI]: Status: Passed for notifying TDA about Start Frame [19:03:17] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0 [19:03:17] TDA ARM Successful [19:03:17] Starting Frame Trigger sequence... [19:03:17] [RadarAPI]: ar1.StartFrame_mult(8) [19:03:18] [RadarAPI]: Status: Passed [19:03:18] Device 4 : Start Frame Successful [19:03:18] [RadarAPI]: ar1.StartFrame_mult(1) [19:03:18] [DeviceId-3] Frame start async event received! [19:03:18] [RadarAPI]: Status: Passed [19:03:18] Device 1 : Start Frame Successful [19:03:18] Capturing AWR device data to the TDA SSD... [19:03:18] [RadarAPI]: Frame Ended [19:03:18] [DeviceId-0] Frame start async event received! [19:03:18] [DeviceId-3] Frame End async event received! [19:03:18] [DeviceId-0] Frame End async event received! [19:03:18] Status: Passed for notifying TDA about Stop Frame [19:03:20] Capture sequence completed... [19:03:22] Loops Remaining : 9 [19:03:22] Starting TDA ARM... [19:03:22] [RadarAPI]: ar1.TDACaptureCard_StartRecord_mult(1, 0, 0, Cascade_Capture_22xx, 0) [19:03:22] Device 0 - Configuring TDA with Width : 2000 and Height : 1536 [19:03:22] [RadarAPI]: Device 0 - setWidthAndHeight Status: Passed [19:03:22] Device 1 - Configuring TDA with Width : 0 and Height : 0 [19:03:22] [RadarAPI]: Device 1 - setWidthAndHeight Status: Passed [19:03:22] Device 2 - Configuring TDA with Width : 0 and Height : 0 [19:03:22] [RadarAPI]: Device 2 - setWidthAndHeight Status: Passed [19:03:22] Device 3 - Configuring TDA with Width : 2000 and Height : 1536 [19:03:22] [RadarAPI]: Device 3 - setWidthAndHeight Status: Passed [19:03:22] Sending Frame Periodicity of 100 to TDA.. [19:03:22] [RadarAPI]: Status: Passed. Frame Periodicity sent to TDA [19:03:25] TDA Stop Record ACK not received! [19:03:25] Frame Periodicity Response from Capture Card timed out!! [19:03:25] TDA ARM Failed [19:03:25] [19:03:25] ***Script completed successfully.***
我们对板子的部分地区进行了重新焊接,想知道出现这种情况的原因是什么呢?具体是板子的哪一部分模块可能出了问题呢?
