DCA1000EVM: The orange light of DCA1000EVM is not on
Part Number: DCA1000EVM
Hello!
I was using DCA1000EVM + IWR6843ODS to collect data before, DCA1000EVM uses power adapter to supply power directly, and it has been working normally before. However, when I try to use DCA1000EVM here today, I found that I can't use the Ethernet port to connect, the green light of DCA1000EVM Ethernet port is on normally, but the orange light is not on. May I ask what is the problem?
Your sincerely
