Build Configuration Error: At least one Controller build component required!
Other Parts Discussed in Thread: CC2540
Dear all:
我在新建一个CC2540的 IAR的工程文件时遇到下面的问题,求教,感谢!
Fatal Error[Pe035]: #error directive: "Build Configuration Error: At least one Controller build component required!" D:\work\BleLock\code\Components\ble\include\bcomdef.h 89
  • 具体错误发生在:Total number of errors: 13
    #if !defined( CTRL_CONFIG ) || !( CTRL_CONFIG & ( ADV_NCONN_CFG | \
                                                        ADV_CONN_CFG  | \
                                                        SCAN_CFG      | \
                                                        INIT_CFG ) )
        #error "Build Configuration Error: At least one Controller build component required!"
      #endif // no Controller build components defined
    #endif
