Other Parts Discussed in Thread: UNIFLASH
1、根据文档使用uniflash生成scr.der文件,但文档没有描述ca.der、client.der、private.key这三个文件如何生成,那这三个文件怎么获取
2、AP这边的服务器怎么搭建可以测试这个功能
1、文档这么写的
• Client Authentication
If the server requires client authentication, the following files are required:
– Private Key – Station (client) RSA private key file in PEM format
– Client Certificate – Certificate of the client, given by the authenticating network (has the public key
matches to the private key) in PEM format
• Server Authentication
The SimpleLink Wi-Fi device requires server authentication by default and the following file is required:
Server Root CA file – This file must be in PEM format. The demand for server authentication can
be canceled through the WLAN setting. Canceling this authentication is valid for a single manual
connection only.
Those files must be programmed with the following names:
• Root CA – sys/cert/ca.der
• Client certificate – sys/cert/client.der
• Private key – sys/cert/private.key
文件系统里需要der格式,那前面那段客户端证书私钥和服务器端根证书又说必须是pem格式
我不知道需要哪种证书啊,所以问你们,感觉这里矛盾,还是有其他意思
2、那Uniflash -> tools ->sign file的Private Key File不是要这个私钥吗
