Other Parts Discussed in Thread: CC1352P7
你好,我这边SDK使用08_30_01_01 ,协调器使用zc_thermostat_LP_CC1352P7_4_tirtos7_ticlang ,终端设备使用zed_temperaturesensor_LP_CC1352P7_4_tirtos7_ticlang。终端设备加入网络时一直处于zstack_DevState_DEV_END_DEVICE状态,像请教一下如何解决,或者协调器如何关闭信任认证功能。
zstack_DevState_DEV_END_DEVICE是已加入网络的终端设备的正确状态。
* Device States for the Network Information Read response (@ref
* zstack_sysNwkInfoReadRsp_t) and the
* Device State Change indication (@ref zstack_devStateChangeInd_t).
typedef enum
/** Initialized - not started automatically */
zstack_DevState_HOLD = 0,
/** Initialized - not connected to anything */
zstack_DevState_INIT = 1,
/** Discovering PAN's to join */
zstack_DevState_NWK_DISC = 2,
/** Joining a PAN */
zstack_DevState_NWK_JOINING = 3,
* ReJoining a PAN in secure mode scanning in current channel,
* only for end devices
zstack_DevState_NWK_REJOIN_SEC_CURR_CHANNEL = 4,
/** Joined but not yet authenticated by trust center */
zstack_DevState_END_DEVICE_UNAUTH = 5,
/** Started as device after authentication */
zstack_DevState_DEV_END_DEVICE = 6,
/** Device joined, authenticated and is a router */
zstack_DevState_DEV_ROUTER = 7,
/** Started as Zigbee Coordinator */
zstack_DevState_COORD_STARTING = 8,
zstack_DevState_DEV_ZB_COORD = 9,
/** Device has lost information about its parent */
zstack_DevState_NWK_ORPHAN = 10,
/** Device is sending KeepAlive message to its parent */
zstack_DevState_NWK_KA = 11,
/** Device is waiting before trying to rejoin */
zstack_DevState_NWK_BACKOFF = 12,
* ReJoining a PAN in secure mode scanning in all channels,
zstack_DevState_NWK_REJOIN_SEC_ALL_CHANNEL = 13,
* ReJoining a PAN in unsecure mode scanning in current channel,
zstack_DevState_NWK_TC_REJOIN_CURR_CHANNEL = 14,
* ReJoining a PAN in unsecure mode scanning in all channels,
zstack_DevState_NWK_TC_REJOIN_ALL_CHANNEL = 15,
} zstack_DevState;
我不知道如何进一步协助,因为这不是问题。如果ZC将BDB_DEFAULT_TC_REQUIRE_KEY_EXCHANGE设置为FALSE,则ZED也可以将requestNewTrustCenterLinkKey设置为FALSE,然后在加入后不请求新的信任中心链接密钥。
