请教一下,我有一个节点用的是2538,预编译了WDT_IN_PM1,在编译的时候提示WatchDogEnable未定义,然后我添加了头文件#include"watchdog.h",还是未定义,请问是什么原因
把附件這兩個檔案加到你的專案再試試
* Filename: watchdog.c
* Revised: $Date: 2013-04-04 15:31:10 +0200 (Thu, 04 Apr 2013) $
* Revision: $Revision: 9634 $
* Description: Driver for the Watchdog Timer Module.
* Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
//! \addtogroup watchdog_api
#include "hw_ints.h"
#include "hw_memmap.h"
#include "hw_smwdthrosc.h"
#include "debug.h"
#include "interrupt.h"
#include "watchdog.h"
//! Enables the watchdog timer
//! \param ui32Interval is the timer interval setting.
//! This function sets the timer interval and enables the watchdog timer.
//! A timeout causes a chip reset.
//! The \e ui32Interval argument must be only one of the following values:
//! \b WATCHDOG_INTERVAL_32768, \b WATCHDOG_INTERVAL_8192,
//! \b WATCHDOG_INTERVAL_512, \b WATCHDOG_INTERVAL_64.
//! \sa WatchdogDisable()
//! \return None
void
WatchdogEnable(uint32_t ui32Interval)
uint32_t ui32Regval;
// Check the arguments.
ASSERT(ui32Interval == WATCHDOG_INTERVAL_32768 ||
ui32Interval == WATCHDOG_INTERVAL_8192 ||
ui32Interval == WATCHDOG_INTERVAL_512 ||
ui32Interval == WATCHDOG_INTERVAL_64);
// Disable Timer to set interval
HWREG(SMWDTHROSC_WDCTL) &= ~SMWDTHROSC_WDCTL_EN;
ui32Regval = HWREG(SMWDTHROSC_WDCTL);
ui32Regval &= ~SMWDTHROSC_WDCTL_INT_M;
ui32Regval |= ui32Interval;
HWREG(SMWDTHROSC_WDCTL) = ui32Regval;
// Enable the watchdog timer module.
ui32Regval &= ~0x4;
ui32Regval |= SMWDTHROSC_WDCTL_EN;
//! Clear watch dog timer
//! This function clears the watch dog timer.
//! Timer must be enabled for the clear operation to take effect.
//! \return None
void
WatchdogClear(void)
uint32_t ui32Reg1;
uint32_t ui32Reg2;
// Write 0xA followed by 0x5 to CLR field
// (0x5 also clears in timer mode)
ui32Reg1 = HWREG(SMWDTHROSC_WDCTL);
ui32Reg1 &= ~SMWDTHROSC_WDCTL_CLR_M;
ui32Reg2 = ui32Reg1 | (0x5 << SMWDTHROSC_WDCTL_CLR_S);
ui32Reg1 |= 0xa << SMWDTHROSC_WDCTL_CLR_S;
// The following two writes must happen within 0.5 cycle of WDT clock!
// for clear to actually happen.
// Note: might need to "safe guard" this zone by disabling interrupts.
HWREG(SMWDTHROSC_WDCTL) = ui32Reg1;
HWREG(SMWDTHROSC_WDCTL) = ui32Reg2;
// Close the Doxygen group.
