cc2630接收协调器命令代码不执行而且断点打不上的问题
Other Parts Discussed in Thread: CC2630
switch(pMsg->hdr.event)
     case zstackmsg_CmdIDs_AF_INCOMING_MSG_IND:
// Process incoming data messages
zstackmsg_afIncomingMsgInd_t *pInd =
(zstackmsg_afIncomingMsgInd_t *)pMsg;
Switch_processAfIncomingMsgInd( &(pInd->req) );
break;
为什么这段代码不起作用呢
  • 把IAR的optimize level調成low 或者是medium 再試試
  • 数据包是否已经传入进来?抓个包看一下
  • 今天又重新打断点调试看了下,原来协调器这端数据就没发送成功, 会执行到int suc=0;。为什么协调器广播发送数据到终端会失败呢?(禁用了EZ_MODE).
    zclReportCmd_t *pReportCmd;
    pReportCmd = osal_mem_alloc( sizeof(zclReportCmd_t) + sizeof(zclReport_t) );
    if ( pReportCmd != NULL )
    pReportCmd->numAttr = 1;
    pReportCmd->attrList[0].attrID = ATTRID_MS_TEMPERATURE_MEASURED_VALUE;
    pReportCmd->attrList[0].dataType = ZCL_DATATYPE_INT16;
    pReportCmd->attrList[0].attrData = (void *)(&zclSampleTemperatureSensor_MeasuredValue);
    afAddrType_t dstAddr;
    dstAddr.addrMode = (afAddrMode_t)AddrBroadcast;
    dstAddr.addr.shortAddr = 0xFFFF;
    dstAddr.endPoint = 20;
    dstAddr.panId = 0x8888;
    if(zcl_SendReportCmd( SWITCH_EP, &dstAddr,
    ZCL_CLUSTER_ID_MS_TEMPERATURE_MEASUREMENT,
    pReportCmd, ZCL_FRAME_SERVER_CLIENT_DIR, TRUE, ztsTransID++ )==ZSuccess)
    int suc=1;
    else
    int suc=0;
    osal_mem_free( pReportCmd );
    int suc=1;
    else
    int suc=0;
  • CC2630 ZED如果是休眠狀態下是收不到广播的、發送信息給ZED建議用单播
