Part Number: CC2340R5
subdir_rules.mk:16: recipe for target 'build-426767009' failed
**** Build of configuration Debug for project watchdog_LP_EM_CC2340R5_nortos_ticlang ****
"C:\\ti\\ccs1240\\ccs\\utils\\bin\\gmake" -k -j 12 all -O
Building file: "../watchdog.syscfg"
Invoking: SysConfig
"C:/ti/sysconfig_1.19.0/sysconfig_cli.bat" -s "C:/ti/simplelink_lowpower_f3_sdk_7_40_00_64/.metadata/product.json" --script "C:/Users/86557/workspace_v12/watchdog_LP_EM_CC2340R5_nortos_ticlang/watchdog.syscfg" -o "syscfg" --compiler ticlang
Invalid argument '-s': File "C:\ti\simplelink_lowpower_f3_sdk_7_40_00_64\.metadata\product.json" does not exist
gmake: *** [build-426767009] Error 1
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
从上周开始一直尝试编译、更换编译环境,更换了ccs1260
CCS Theia安装卸载,
安装ccs1260 还是问题依旧,
更换成ccs1240 还是编译错误,
都是直接导入simplelink_lowpower_f3_sdk_7_40_00_64__win.zip 解压
所有工程都没有中文目录
这个信息有帮助吗
选不了1.81 实际已经安装了1.81
你好,仔细看了一下和你的工具截图差异比较大,请问这些会影响吗
这里已经安装了sysconfig_1.18.1,但是工程里面还是提示Product SysConfig v1.18.1 is not currently installed. A compatible version 1.17.0 will be used.
已经安装了
