What is the difference between tl082idr, tl082cd and tl082cm?
In the simulation, the influence of these models on the ground potential of floating ground system is very different
Hello, do you mean the pspice model of TL082X and simulated with TINA?
I find that they have the same pspice model of TL082x.
In addition, TL082x have different electrical characteristics, it described in datasheet of "Electrical Characteristics" part.
Or you could attach your simulation results for analysis.
