Does its I2S slave mode support 3-wire digital audio interface (no MCLK required)?We want to use the GPIO1 as a interupt signal to MCU for voice-activated application.
We need two channel balance analog input so there is no any GPIO remain for voice-activated interupt signal output,So we want to check if the ADC I2S slave mode whether support 3-wire digital audio interface (no MCLK required)? If so then we can use GPIO1 for interupt.
Will He
Thanks!
Hi
In master mode we are going to use MCLK, but in SLAVE mode I didn't find clear instructions. Due to the special circumstances of your project, we did not find the relevant application. In order to better solve your problem, please post on the English forum to consult the product line experts and let them help you analyze how to configure it.
Please post on our English E2E support forums via the following link to connect with our product line experts: https://e2e.ti.com/p/addpost
