Other Parts Discussed in Thread: DP83822I
DP83822I芯片是不是通过拉低hardware reset管脚就可以将所有寄存器恢复为默认值?
是恢复到strap设置的默认状态。此时需要保证MCU不会影响strap引脚电平。MCU接口IO设为输入状态。
将寄存器恢复到默认值两种方法:
1. hardware reset: 通过RESET:引脚拉低: This pin is an active low reset input that initializes or reinitializes all the internal registers of the PHY。
2.Software reset:通过配置寄存器0x001F bit[15]=1 reset , This bit is self cleared and has the same effect as Hardware reset pin
