Dear teams,
Always thanks for your help! Could you help me and give some comment.
Customers have already bought 947 , but I found some errors on GUI.
Best Regards,
Rookie
Hello, please follow the below steps to try:
1) Click on USB2ANY/Aardvark Setup, a new window will open.
2) Chose the existing device, in the left hand side box, and click Remove.
3) Under “Select a Daughter Board" search for the required device profile, in this case DS90UB947, and click “Add” and then “Ok”.
Dear Kailyn,
The 947 can’t connect to ALP is solved. Because the DS90Ux947Q EVB board not with a 12 VDC power supply.
Best Regards,
Rookie
