我的 SPI (使用 SSI0)示例代码在 TI Launchpad 上工作。 请参阅以下代码
#include <stdbool.h> #include <stdint.h> #include <inc/hw_types.h> #include <inc/hw_ssi.h> #include "inc/hw_memmap.h" #include <driverlib/gpio.h> #include "driverlib/pin_map.h" #include "driverlib/ssi.h" #include "driverlib/sysctl.h" #include "driverlib/uart.h" #include "utils/uartstdio.h" #include <string.h> //#include "main.h" // Number of bytes to Send. // //***************************************************************************** #define NUM_SSI_DATA 4 #define HB_ENABLE 0x0080 #define HB_CONFIG 0x0002 #ifdef DEBUG void __error__(char *pcFilename, uint32_t ui32Line) { } #endif uint32_t ui32SysClocks; //***************************************************************************** // // This function sets up UART0 to be used for a console to display information // as the example is running. // //***************************************************************************** void InitConsole(void) { SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA); GPIOPinConfigure(GPIO_PA0_U0RX); GPIOPinConfigure(GPIO_PA1_U0TX); GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1); UARTStdioConfig(0, 9600, ui32SysClocks); } void InitSPI0(void){ SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI0); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA); GPIOPinTypeGPIOOutput(GPIO_PORTA_BASE, GPIO_PIN_3|GPIO_PIN_2|GPIO_PIN_4); GPIOPinTypeGPIOInput(GPIO_PORTA_BASE, GPIO_PIN_5); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOM); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB); GPIOPinTypeGPIOOutput(GPIO_PORTM_BASE, GPIO_PIN_5); GPIOPadConfigSet(GPIO_PORTM_BASE, GPIO_PIN_5, GPIO_STRENGTH_12MA, GPIO_PIN_TYPE_STD_WPU ); GPIOPinWrite(GPIO_PORTM_BASE, GPIO_PIN_5, GPIO_PIN_5);//PULL UP GPIOPinTypeGPIOOutput(GPIO_PORTB_BASE, GPIO_PIN_4); GPIOPadConfigSet(GPIO_PORTB_BASE, GPIO_PIN_4, GPIO_STRENGTH_12MA, GPIO_PIN_TYPE_STD_WPU ); GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_4, GPIO_PIN_4);//PULL UP GPIOPinConfigure(GPIO_PA2_SSI0CLK); GPIOPinConfigure(GPIO_PA3_SSI0FSS); GPIOPinConfigure(GPIO_PA4_SSI0XDAT0);//Tx GPIOPinConfigure(GPIO_PA5_SSI0XDAT1);//Rx GPIOPinTypeSSI(GPIO_PORTA_BASE, GPIO_PIN_5 | GPIO_PIN_4 | GPIO_PIN_3 | GPIO_PIN_2); //SSIConfigSetExpClk(SSI0_BASE, ui32SysClocks, SSI_FRF_MOTO_MODE_2, SSI_MODE_MASTER, 40000000, 16); //SSIConfigSetExpClk(SSI0_BASE, ui32SysClocks, SSI_FRF_MOTO_MODE_0, SSI_MODE_MASTER, 1500000, 16); SSIConfigSetExpClk(SSI0_BASE, ui32SysClocks, SSI_FRF_MOTO_MODE_1, SSI_MODE_MASTER, 1500000, 16);//negative edge triggered } void SPI_write(const uint8_t* dataBuffer, uint8_t count){ while(count--){ SSIDataPut(SSI0_BASE, *dataBuffer++); } while(SSIBusy(SSI0_BASE)); } //***************************************************************************** //Main function Entry. // //***************************************************************************** int main(void) { bool pDO_Status[24]; uint8_t ui8Do_Source_Sink; // spiConfigbus stSpiConfig; // i2cConfigbus stI2cConfig; uint16_t aui16SpiTxBuffer[2]; uint16_t aui16SpiRxBuffer[2][2]; uint8_t aui8I2cTxBuffer[3]; uint8_t aui8I2cRxBuffer[3]; uint8_t i; uint8_t dataTX[4] = {0x40, 0x4F, 0x4F, 0x04}; //uint8_t dataTX = 0x40; uint8_t count; //ui32SysClocks = SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ | SYSCTL_OSC_MAIN | SYSCTL_USE_PLL | SYSCTL_CFG_VCO_240), 120000000); ui32SysClocks = SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ | SYSCTL_OSC_MAIN | SYSCTL_USE_PLL | SYSCTL_CFG_VCO_480), 120000000); InitConsole(); UARTprintf("SPI -> Master to Slave\n"); UARTprintf("SPI Bit_Rate: 16-bit\n\n"); InitSPI0(); SSIEnable(SSI0_BASE); // GPIOPinWrite(GPIO_PORTM_BASE, GPIO_PIN_5, GPIO_PIN_5); //enable dataTX[0] = (HB_ENABLE << 0 )| (HB_CONFIG << 0);//output high SysCtlDelay(100); SPI_write(dataTX, 1); SysCtlDelay(100);//delay of } UARTprintf("Done transferring the data\r\n"); UARTprintf("----------------------------------------------------------------------"); UARTprintf("\r\n\n"); while(1); }
但当我根据我的要求(使用 SSI3)对其进行修改时、它在 Launchpad 上不起作用。 请参见下面针对 SSI3修改的代码。
#include <stdbool.h> #include <stdint.h> #include <inc/hw_types.h> #include <inc/hw_ssi.h> #include "inc/hw_memmap.h" #include <driverlib/gpio.h> #include "driverlib/pin_map.h" #include "driverlib/ssi.h" #include "driverlib/sysctl.h" #include "driverlib/uart.h" #include "utils/uartstdio.h" #include <string.h> //#include "main.h" // Number of bytes to Send. // //***************************************************************************** #define NUM_SSI_DATA 4 #define HB_ENABLE 0x0080 #define HB_CONFIG 0x0002 #ifdef DEBUG void __error__(char *pcFilename, uint32_t ui32Line) { } #endif uint32_t ui32SysClocks; //***************************************************************************** // // This function sets up UART0 to be used for a console to display information // as the example is running. // //***************************************************************************** void InitConsole(void) { SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA); GPIOPinConfigure(GPIO_PA0_U0RX); GPIOPinConfigure(GPIO_PA1_U0TX); GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1); UARTStdioConfig(0, 9600, ui32SysClocks); } void InitSPI0(void){ SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI0); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA); GPIOPinTypeGPIOOutput(GPIO_PORTA_BASE, GPIO_PIN_3|GPIO_PIN_2|GPIO_PIN_4); GPIOPinTypeGPIOInput(GPIO_PORTA_BASE, GPIO_PIN_5); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOM); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB); GPIOPinTypeGPIOOutput(GPIO_PORTM_BASE, GPIO_PIN_5); GPIOPadConfigSet(GPIO_PORTM_BASE, GPIO_PIN_5, GPIO_STRENGTH_12MA, GPIO_PIN_TYPE_STD_WPU ); GPIOPinWrite(GPIO_PORTM_BASE, GPIO_PIN_5, GPIO_PIN_5);//PULL UP GPIOPinTypeGPIOOutput(GPIO_PORTB_BASE, GPIO_PIN_4); GPIOPadConfigSet(GPIO_PORTB_BASE, GPIO_PIN_4, GPIO_STRENGTH_12MA, GPIO_PIN_TYPE_STD_WPU ); GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_4, GPIO_PIN_4);//PULL UP GPIOPinConfigure(GPIO_PA2_SSI0CLK); GPIOPinConfigure(GPIO_PA3_SSI0FSS); GPIOPinConfigure(GPIO_PA4_SSI0XDAT0);//Tx GPIOPinConfigure(GPIO_PA5_SSI0XDAT1);//Rx GPIOPinTypeSSI(GPIO_PORTA_BASE, GPIO_PIN_5 | GPIO_PIN_4 | GPIO_PIN_3 | GPIO_PIN_2); //SSIConfigSetExpClk(SSI0_BASE, ui32SysClocks, SSI_FRF_MOTO_MODE_2, SSI_MODE_MASTER, 40000000, 16); //SSIConfigSetExpClk(SSI0_BASE, ui32SysClocks, SSI_FRF_MOTO_MODE_0, SSI_MODE_MASTER, 1500000, 16); SSIConfigSetExpClk(SSI0_BASE, ui32SysClocks, SSI_FRF_MOTO_MODE_1, SSI_MODE_MASTER, 1500000, 16);//negative edge triggered } void InitSPI3(void){ SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI3); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOQ); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOP); GPIOPinTypeGPIOOutput(GPIO_PORTQ_BASE, GPIO_PIN_2 | GPIO_PIN_0); GPIOPinTypeGPIOInput(GPIO_PORTQ_BASE, GPIO_PIN_3); GPIOPinTypeGPIOOutput(GPIO_PORTP_BASE, GPIO_PIN_1);//cs GPIOPinTypeGPIOOutput(GPIO_PORTM_BASE, GPIO_PIN_5); GPIOPadConfigSet(GPIO_PORTM_BASE, GPIO_PIN_5, GPIO_STRENGTH_12MA, GPIO_PIN_TYPE_STD_WPU ); GPIOPinWrite(GPIO_PORTM_BASE, GPIO_PIN_5, GPIO_PIN_5);//PULL UP // GPIOPadConfigSet(GPIO_PORTM_BASE, GPIO_PIN_5, GPIO_STRENGTH_12MA, GPIO_PIN_TYPE_STD_WPU ); // GPIOPinWrite(GPIO_PORTM_BASE, GPIO_PIN_5, GPIO_PIN_5);//PULL UP // GPIOPinTypeGPIOOutput(GPIO_PORTB_BASE, GPIO_PIN_4); GPIOPadConfigSet(GPIO_PORTP_BASE, GPIO_PIN_1, GPIO_STRENGTH_12MA, GPIO_PIN_TYPE_STD_WPU ); GPIOPinWrite(GPIO_PORTP_BASE, GPIO_PIN_1, GPIO_PIN_1);//PULL UP GPIOPinConfigure(GPIO_PQ0_SSI3CLK); //GPIOPinConfigure(GPIO_PA3_SSI0FSS); GPIOPinConfigure(GPIO_PQ2_SSI3XDAT0);//Tx GPIOPinConfigure(GPIO_PQ3_SSI3XDAT1);//Rx GPIOPinTypeSSI(GPIO_PORTQ_BASE, GPIO_PIN_0 | GPIO_PIN_3 | GPIO_PIN_2); //SSIConfigSetExpClk(SSI0_BASE, ui32SysClocks, SSI_FRF_MOTO_MODE_2, SSI_MODE_MASTER, 40000000, 16); //SSIConfigSetExpClk(SSI0_BASE, ui32SysClocks, SSI_FRF_MOTO_MODE_0, SSI_MODE_MASTER, 1500000, 16); SSIConfigSetExpClk(SSI3_BASE, ui32SysClocks, SSI_FRF_MOTO_MODE_1, SSI_MODE_MASTER, 1500000, 16);//negative edge triggered } /*void SPI_write(const uint8_t* dataBuffer, uint8_t count){ while(count--){ SSIDataPut(SSI0_BASE, *dataBuffer++); } while(SSIBusy(SSI0_BASE)); }*/ void SPI_write_SSI3(const uint8_t* dataBuffer, uint8_t count){ while(count--){ SSIDataPut(SSI3_BASE, *dataBuffer++); } while(SSIBusy(SSI3_BASE)); } //***************************************************************************** //Main function Entry. // //***************************************************************************** int main(void) { bool pDO_Status[24]; uint8_t ui8Do_Source_Sink; volatile uint32_t ui32Loop; uint16_t aui16SpiTxBuffer[2]; uint16_t aui16SpiRxBuffer[2][2]; uint8_t aui8I2cTxBuffer[3]; uint8_t aui8I2cRxBuffer[3]; uint8_t i; uint8_t dataTX[4] = {0x40, 0x4F, 0x4F, 0x04}; //uint8_t dataTX = 0x40; uint8_t count; //ui32SysClocks = SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ | SYSCTL_OSC_MAIN | SYSCTL_USE_PLL | SYSCTL_CFG_VCO_240), 120000000); ui32SysClocks = SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ | SYSCTL_OSC_MAIN | SYSCTL_USE_PLL | SYSCTL_CFG_VCO_480), 120000000); InitConsole(); UARTprintf("SPI -> Master to Slave\n"); UARTprintf("SPI Bit_Rate: 16-bit\n\n"); InitSPI3(); SSIEnable(SSI3_BASE); dataTX[0] = (HB_ENABLE << 0 )| (HB_CONFIG << 0);//output high GPIOPinWrite(GPIO_PORTP_BASE, GPIO_PIN_1, 0); SysCtlDelay(100); SPI_write_SSI3(dataTX, 1); SysCtlDelay(100);//delay of GPIOPinWrite(GPIO_PORTP_BASE, GPIO_PIN_1, GPIO_PIN_1); UARTprintf("Done transferring the data\r\n"); UARTprintf("----------------------------------------------------------------------"); UARTprintf("\r\n\n"); while(1); }
SSI3在我的原理图中用于如下所示
如果代码中有任何内容需要更改才能运行 SSI3、您能否提供指导?
Kiran
