您好、
该问题可能发生了启动500次的1次。 我的项目中只有这一个中断。
设置如下:
acqps = 28; //75ns
EALLOW;
AdcaRegs.ADCSOC0CTL.bit.CHSEL = 1; //SOC0 will convert on channel 1
AdcaRegs.ADCSOC1CTL.bit.CHSEL = 4; //SOC1 will convert on channel 4
AdcaRegs.ADCSOC2CTL.bit.CHSEL = 3; //SOC2 will convert on channel 3
AdcaRegs.ADCSOC3CTL.bit.CHSEL = 2; //SOC3 will convert on channel 2
AdcaRegs.ADCSOC4CTL.bit.CHSEL = 5; //SOC4 will convert on channel 5
AdcaRegs.ADCSOC0CTL.bit.ACQPS = acqps; //sample is acqps + 1 SYSCLK cycles
AdcaRegs.ADCSOC1CTL.bit.ACQPS = acqps; //sample is acqps + 1 SYSCLK cycles
AdcaRegs.ADCSOC2CTL.bit.ACQPS = acqps; //sample is acqps + 1 SYSCLK cycles
AdcaRegs.ADCSOC3CTL.bit.ACQPS = acqps; //sample is acqps + 1 SYSCLK cycles
AdcaRegs.ADCSOC4CTL.bit.ACQPS = acqps; //sample is acqps + 1 SYSCLK cycles
AdcaRegs.ADCSOC5CTL.bit.ACQPS = acqps; //sample is acqps + 1 SYSCLK cycles
AdcaRegs.ADCINTSEL1N2.bit.INT1E = 1; //enable INT1 flag
AdcaRegs.ADCINTSEL1N2.bit.INT2E = 1; //enable INT2 flag
AdcaRegs.ADCINTSEL3N4.bit.INT3E = 0; //disable INT3 flag
AdcaRegs.ADCINTSEL3N4.bit.INT4E = 0; //disable INT4 flag
AdcaRegs.ADCINTSEL1N2.bit.INT1SEL = 2; //end of SOC2 will set INT1 flag
AdcaRegs.ADCINTSEL1N2.bit.INT2SEL = 4; //end of SOC4 will set INT2 flag
AdcaRegs.ADCINTFLGCLR.bit.ADCINT1 = 1; //make sure INT1 flag is cleared
AdcaRegs.ADCINTFLGCLR.bit.ADCINT2 = 1; //make sure INT2 flag is cleared
// Trigger source
AdcaRegs.ADCSOC0CTL.bit.TRIGSEL = 5; //ePWM1, ADCSOCA
AdcaRegs.ADCSOC1CTL.bit.TRIGSEL = 5; //ePWM1, ADCSOCA
AdcaRegs.ADCSOC2CTL.bit.TRIGSEL = 5; //ePWM1, ADCSOCA
AdcaRegs.ADCSOC3CTL.bit.TRIGSEL = 5; //ePWM1, ADCSOCA
AdcaRegs.ADCSOC4CTL.bit.TRIGSEL = 5; //ePWM1, ADCSOCA
AdcaRegs.ADCSOC5CTL.bit.TRIGSEL = 5; //ePWM1, ADCSOCA
CpuSysRegs.PCLKCR0.bit.TBCLKSYNC = 0; // Stop all the TB clocks
// The clock source of EPWM is EPWMCLK
//The setting of EPWM1
EPwm1Regs.TBSTS.all=0;
EPwm1Regs.TBPHS.bit.TBPHS=0;
EPwm1Regs.TBCTR=0;
EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Master module, don't load the TBCTR from TBPHS
EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO; // sync flow-through
EPwm1Regs.CMPCTL.all=0; //Set the control register of Counter compare module
//Counter compare B- in shadow mode
//Counter compare A- in shadow mode
//Load compare register B at TBCTR = 0x0000
//Load compare register A at TBCTR = 0x0000
//EPwm1Regs.CMPCTL.all=0x05; //Set the control register of Counter compare module
//Load compare register B at TBCTR = PRD
//Load compare register A at TBCTR = PRD
EPwm1Regs.CMPA.bit.CMPA = 0; //Clear compare register A & B
EPwm1Regs.CMPB.bit.CMPB = 0;
EPwm1Regs.AQCTLA.all=0x90; // 0b10010000,
// EPWMxA = 0 when CTR=CMPA and counter inc
// EPWMxA = 1 when CTR=CMPA and counter dec
EPwm1Regs.AQCTLB.all=0x900; // 0b100100000000
// EPWMxB = 0 when CTR=CMPB and counter inc
// EPWMxB = 1 when CTR=CMPB and counter dec
EPwm1Regs.AQSFRC.all=0;
EPwm1Regs.AQCSFRC.all=0;
//EPwm1Regs.DBCTL.all=0;
//DB clocked at TBCLK default
EPwm1Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE; //Deadtime enable for EPWMA and EPWMB
EPwm1Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC; //EPWMxB is inverted, complementary output
EPwm1Regs.DBCTL.bit.IN_MODE = DBA_ALL; //The EPWMxA is selected as the only source
EPwm1Regs.DBCTL.bit.SHDWDBFEDMODE = 1; //1: FED Shadow Mode
EPwm1Regs.DBCTL.bit.SHDWDBREDMODE = 1; //1: RED Shadow Mode
EPwm1Regs.DBFED.bit.DBFED = 10; // Setting deadtime 10ns*10, = 100ns
EPwm1Regs.DBRED.bit.DBRED = 10;
EPwm1Regs.ETSEL.all=0; // Interrupt disable
EPwm1Regs.ETFLG.all=0;
EPwm1Regs.ETCLR.all=0;
EPwm1Regs.ETFRC.all=0;
// SOCA for
EPwm1Regs.ETSEL.bit.SOCAEN = 1; // Enable SOCA to trigger Seq1
EPwm1Regs.ETSEL.bit.SOCASEL = ET_CTR_ZERO; // SOCA at zero
EPwm1Regs.ETPS.bit.SOCAPRD = ET_1ST; // Generate SOCA every event
// SOCB for
//EPwm1Regs.ETSEL.bit.SOCBEN = 1; // Enable SOCB to trigger Seq1
//EPwm1Regs.ETSEL.bit.SOCBSEL = ET_CTR_PRD; // SOCB at PRD
//EPwm1Regs.ETPS.bit.SOCBPRD = ET_1ST; // Generate SOCB every event
EPwm1Regs.PCCTL.all = 0;
EPwm1Regs.TBCTL.all = 0x201A;
// Count up after synchronization event
// Set Time base control register, TBCLK = EPWMCLK
// Select the CTR = zero as the TB_SYNC_OUT
// the shadow register of PRD disabled,immediately load
// up-down-count mode
EPwm1Regs.TBPRD=SP; // load PRD register, PWM_CLK/(2*PWM_Freq)
EDIS;
EALLOW;
PieCtrlRegs.PIECTRL.bit.ENPIE = 1;
PieVectTable.ADCA1_INT = &Control_isr;
EDIS;
PieCtrlRegs.PIEIER1.bit.INTx1 = 1;
IER |= M_INT1; //Enable group 1 interrupts
// Enable global Interrupts and higher priority real-time debug events:
EINT; // Enable Global interrupt INTM
ERTM; // Enable Global real time interrupt DBGM
ADC_ISR 代码:
interrupt void Control_isr(void)
nCnt_INT_Idts++;
// Read ADC Results
// End reading
AdcaRegs.ADCINTFLGCLR.bit.ADCINT1 = 1; //clear INT1 flag
PieCtrlRegs.PIEACK.bit.ACK1 = 1; //Acknowledge group 1 interrupt
有什么问题吗?
