[参考译文] TPS23882B:规格检查
Guru**** 2531210 points
Other Parts Discussed in Thread: TPS23731, TPS2378
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1556960/tps23882b-spec-check
器件型号:TPS23882B
主题中讨论的其他器件:TPS2378、TPS23731
你(们)好
您能帮助推荐一款可以替代 LT4275B 的产品吗?
谢谢你。
https://www.analogue.com/media/en/technical-documentation/data-sheets/4275f.pdf
