[参考译文] TPS1663:散热焊盘尺寸
Guru**** 2928980 points
Other Parts Discussed in Thread: TPS1663
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/845409/tps1663-thermal-pad-size
器件型号:TPS1663
尊敬的团队:
该器件的散热焊盘尺寸是多少?
我在数据表中找不到它
BR
Kevin
