[参考译文] TDA4VM:如何在 ethfw 中配置 VLAN
Guru**** 2541810 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1223661/tda4vm-how-to-configure-vlans-in-ethfw
器件型号:TDA4VM
您好,TI 专家
配置 VLAN 时遇到问题
我运行的是软件版本 SDK-8.6-j721e。
我阅读了文档 [常见问题解答] TDA4VM:如何配置 CPSW 5G/9G ALE -处理器论坛-处理器- TI E2E 支持论坛
根据说明文件中的参考,我为端口3和主机配置了一个 VLAN,为端口5配置了另一个 VLAN。
将端口3连接到测试机、将端口5连接到 PC。 测试机发送多播数据包并使用板上的 tcpdump 函数捕获多播数据包。 然后、可以使用 Wireshark 捕获 PC 上的数据包。
如何配置 port5以过滤来自不同 VLAN 端口的数据包,并在端口 VLAN 相同时正确转发数据包?
这是我的 VLAN 配置代码
 * Copyright (c) 2020 Texas Instruments Incorporated
 * All rights reserved not granted herein.
 * Limited License.
 * Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive
 * license under copyrights and patents it now or hereafter owns or controls to make,
 * have made, use, import, offer to sell and sell ("Utilize") this software subject to the
 * terms herein.  With respect to the foregoing patent license, such license is granted
 * solely to the extent that any such patent is necessary to Utilize the software alone.
 * The patent license shall not apply to any combinations which include this software,
 * other than combinations with devices manufactured by or for TI ("TI Devices").
 * No hardware patent is licensed hereunder.
 * Redistributions must preserve existing copyright notices and reproduce this license
 * (including the above copyright notice and the disclaimer and (if applicable) source
 * code license limitations below) in the documentation and/or other materials provided
 * with the distribution
 * Redistribution and use in binary form, without modification, are permitted provided
 * that the following conditions are met:
 * *       No reverse engineering, decompilation, or disassembly of this software is
 * permitted with respect to any software provided in binary form.
 * *       any redistribution and use are licensed by TI for use only with TI Devices.
 * *       Nothing shall obligate TI to provide you with source code for the software
 * licensed and provided to you in object code.
 * If software source code is provided to you, modification and redistribution of the
 * source code are permitted provided that the following conditions are met:
 * *       any redistribution and use of the source code, including any resulting derivative
 * works, are licensed by TI for use only with TI Devices.
 * *       any redistribution and use of any object code compiled from the source code
 * and any resulting derivative works, are licensed by TI for use only with TI Devices.
 * Neither the name of Texas Instruments Incorporated nor the names of its suppliers
 * may be used to endorse or promote products derived from this software without
 * specific prior written permission.
 * DISCLAIMER.
 * THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS
 * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
 * IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT,
 * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
 * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
 * OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
 * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
 * OF THE POSSIBILITY OF SUCH DAMAGE.
#include "app_ethfw_priv.h"
/*                            Global Variables                                */
#if defined(SAFERTOS)
#define ETHAPP_LWIP_TASK_STACKSIZE      (16U * 1024U)
#define ETHAPP_LWIP_TASK_STACKALIGN     ETHAPP_LWIP_TASK_STACKSIZE
#else
#define ETHAPP_LWIP_TASK_STACKSIZE      (4U * 1024U)
#define ETHAPP_LWIP_TASK_STACKALIGN     (32U)
#endif
static uint8_t gEthAppLwipStackBuf[ETHAPP_LWIP_TASK_STACKSIZE] __attribute__ ((section(".bss:taskStackSection"))) __attribute__((aligned(ETHAPP_LWIP_TASK_STACKALIGN)));
/* lwIP features that EthFw relies on */
#ifndef LWIP_IPV4
#error "LWIP_IPV4 is not enabled"
#endif
#ifndef LWIP_NETIF_STATUS_CALLBACK
#error "LWIP_NETIF_STATUS_CALLBACK is not enabled"
#endif
#ifndef LWIP_NETIF_LINK_CALLBACK
#error "LWIP_NETIF_LINK_CALLBACK is not enabled"
#endif
/* DHCP or static IP */
#define ETHAPP_LWIP_USE_DHCP            (1)
#if !ETHAPP_LWIP_USE_DHCP
#define ETHFW_SERVER_IPADDR(addr)       IP4_ADDR((addr), 192,168,1,200)
#define ETHFW_SERVER_GW(addr)           IP4_ADDR((addr), 192,168,1,1)
#define ETHFW_SERVER_NETMASK(addr)      IP4_ADDR((addr), 255,255,255,0)
#endif
/* BridgeIf configuration parameters */
#define ETHAPP_LWIP_BRIDGE_MAX_PORTS (4U)
#define ETHAPP_LWIP_BRIDGE_MAX_DYNAMIC_ENTRIES (32U)
#define ETHAPP_LWIP_BRIDGE_MAX_STATIC_ENTRIES (8U)
/* BridgeIf port IDs
 * Used for creating CoreID to Bridge PortId Map
#define ETHAPP_BRIDGEIF_PORT1_ID        (1U)
#define ETHAPP_BRIDGEIF_PORT2_ID        (2U)
#define ETHAPP_BRIDGEIF_CPU_PORT_ID     BRIDGEIF_MAX_PORTS
/* Inter-core netif IDs */
#define ETHAPP_NETIF_IC_MCU2_0_MCU2_1_IDX   (0U)
#define ETHAPP_NETIF_IC_MCU2_0_A72_IDX      (1U)
#define ETHAPP_NETIF_IC_MAX_IDX             (2U)
/* Max length of shared mcast address list */
#define ETHAPP_MAX_SHARED_MCAST_ADDR        (8U)
/* Required size of the MAC address pool (specific to the TI EVM configuration):
 *  1 x MAC address for Ethernet Firmware
 *  2 x MAC address for mpu1_0 virtual switch and MAC-only ports (Linux, 1 for QNX)
 *  2 x MAC address for mcu2_1 virtual switch and MAC-only ports (RTOS)
 *  1 x MAC address for mcu2_1 virtual switch port (AUTOSAR) */
#define ETHAPP_MAC_ADDR_POOL_SIZE           (6U)
#define TEST_VID_A72                    (100U)
static EthAppObj gEthAppObj =
    .enetType = ENET_CPSW_9G,
    .hEthFw = NULL,
    .hUdmaDrv = NULL,
    .instId   = 0U,
static Enet_MacPort gEthAppPorts[] =
#if defined(SOC_J721E)
    /* On J721E EVM to use all 8 ports simultaneously, we use below configuration
       RGMII Ports - 1,3,4,8. QSGMII ports - 2,5,6,7 */
    ENET_MAC_PORT_1, /* RGMII */
    ENET_MAC_PORT_3, /* RGMII */
    ENET_MAC_PORT_4, /* RGMII */
    ENET_MAC_PORT_8, /* RGMII */
    ENET_MAC_PORT_2, /* QSGMII main */
    ENET_MAC_PORT_5, /* QSGMII sub */
    ENET_MAC_PORT_6, /* QSGMII sub */
#if defined(ENABLE_QSGMII_PORTS)
    // ENET_MAC_PORT_2, /* QSGMII main */
    // ENET_MAC_PORT_5, /* QSGMII sub */
    // ENET_MAC_PORT_6, /* QSGMII sub */
    ENET_MAC_PORT_7, /* QSGMII sub */
#endif
#elif defined(SOC_J784S4)
    ENET_MAC_PORT_1, /* QSGMII main */
    ENET_MAC_PORT_3, /* QSGMII sub */
    ENET_MAC_PORT_4, /* QSGMII sub */
#endif
static EthFw_VirtPortCfg gEthApp_virtPortCfg[] =
        .remoteCoreId = IPC_MPU1_0,
        .portId       = ETHREMOTECFG_SWITCH_PORT_0,
        .remoteCoreId = IPC_MCU2_1,
        .portId       = ETHREMOTECFG_SWITCH_PORT_1,
        .portId       = ETHREMOTECFG_MAC_PORT_2,
        .portId       = ETHREMOTECFG_MAC_PORT_4,
static EthFw_VirtPortCfg gEthApp_autosarVirtPortCfg[] =
static sys_sem_t gEthApp_lwipMainTaskSemObj;
#endif
/*                          Function Declarations                             */
static void EthApp_lwipMain(void *a0,
                            void *a1);
static void EthApp_initLwip(void *arg);
static void EthApp_initNetif(void);
static void EthApp_netifStatusCb(struct netif *netif);
static int32_t EthApp_initEthFw(void);
static void EthApp_startSwInterVlan(char *recvBuff,
                                    char *sendBuff);
static void EthApp_startHwInterVlan(char *recvBuff,
                                    char *sendBuff);
static int32_t EthApp_addRemoteCoreStaticCfg(Enet_Handle hEnet,
                                             uint32_t coreId,
                                             uint32_t flowId);
static void EthApp_delRemoteCoreStaticCfg(Enet_Handle hEnet,
                                          uint32_t coreId,
                                          uint32_t flowId);
#if defined(ETHAPP_ENABLE_INTERCORE_ETH)
static void EthApp_filterAddMacSharedCb(const uint8_t *mac_address,
                                        const uint8_t hostId);
static void EthApp_filterDelMacSharedCb(const uint8_t *mac_address,
/* Array to store coreId to lwip bridge portId map */
static uint8_t gEthApp_lwipBridgePortIdMap[IPC_MAX_PROCS];
/* Shared multicast address table */
typedef struct
    /*! Shared Mcast address */
    uint8_t macAddr[ENET_MAC_ADDR_LEN];
    /*! lwIP Bridge port mask */
    bridgeif_portmask_t portMask;
} EthApp_SharedMcastAddrTable;
/* Must not exceed ETHAPP_MAX_SHARED_MCAST_ADDR entries */
static EthApp_SharedMcastAddrTable gEthApp_sharedMcastAddrTable[] =
        /* MCast IP ADDR: 224.0.0.1 */
        .macAddr = {0x01,0x00,0x5E,0x00,0x00,0x01},
        .portMask= 0U,
        /* MCast IP ADDR: 224.0.0.251 */
        .macAddr = {0x01,0x00,0x5E,0x00,0x00,0xFB},
        .portMask= 0U,
        /* MCast IP ADDR: 224.0.0.252 */
        .macAddr = {0x01,0x00,0x5E,0x00,0x00,0xFC},
        .portMask= 0U,
        .macAddr = {0x33,0x33,0x00,0x00,0x00,0x01},
        .portMask= 0U,
        .macAddr = {0x33,0x33,0xFF,0x1D,0x92,0xC2},
        .portMask= 0U,
        .macAddr = {0x01,0x80,0xC2,0x00,0x00,0x00},
        .portMask= 0U,
        .macAddr = {0x01,0x80,0xC2,0x00,0x00,0x03},
        .portMask= 0U,
    {   /* TestMac IP ADDR: 224.0.0.252 */
        .macAddr = {0x01, 0x00, 0x5e, 0x1, 0x1, 0x01},
        .portMask= 0U,
#endif
/* List of multicast addresses reserved for EthFw. Currently, this list is populated
 * only with PTP related multicast addresses which are used by the test PTP stack
 * used by EthFw.
 * Note: Must not exceed ETHFW_RSVD_MCAST_LIST_LEN */
static uint8_t gEthApp_rsvdMcastAddrTable[][ENET_MAC_ADDR_LEN] =
    /* PTP - Peer delay messages */
        0x01, 0x80, 0xc2, 0x00, 0x00, 0x0E,
    /* PTP - Non peer delay messages */
        0x01, 0x1b, 0x19, 0x00, 0x00, 0x00,
static struct netif netif;
static struct netif netif_ic[ETHAPP_NETIF_IC_MAX_IDX];
static uint32_t netif_ic_state[IC_ETH_MAX_VIRTUAL_IF] =
    IC_ETH_IF_MCU2_0_MCU2_1,
    IC_ETH_IF_MCU2_1_MCU2_0,
    IC_ETH_IF_MCU2_0_A72
static struct netif netif_bridge;
bridgeif_initdata_t bridge_initdata;
#endif /* ETHAPP_ENABLE_INTERCORE_ETH */
void appEthFwEarlyInit()
    SemaphoreP_Params semParams;
    /* Create semaphore used to synchronize EthFw and NDK init.
     * EthFw opens the CPSW driver which is required by NDK during NIMU
     * initialization, hence EthFw init must complete first.
     * Currently, there is no control over NDK initialization time and its
     * task runs right away after BIOS_start() hence causing a race
     * condition with EthFw init */
    SemaphoreP_Params_init(&semParams);
    semParams.mode = SemaphoreP_Mode_BINARY;
    gEthAppObj.hInitSem = SemaphoreP_create(0, &semParams);
int32_t appEthFwInit()
    int32_t status = ETHAPP_OK;
    uint32_t flags = 0U;
    appLogPrintf("ETHFW: Init ... !!!\n");
    gEthAppObj.coreId = EnetSoc_getCoreId();
    /* Board related initialization */
    flags |= ETHFW_BOARD_GESI_ENABLE;
    flags |= ETHFW_BOARD_QENET_ENABLE;
#endif
    flags |= (ETHFW_BOARD_QENET_ENABLE | ETHFW_BOARD_SERDES_CONFIG);
#endif
    status = EthFwBoard_init(flags);
    if (status != ENET_SOK)
        appLogPrintf("ETHFW: Board initialization failed\n");
    /* Open UDMA driver */
    if (status == ENET_SOK)
        gEthAppObj.hUdmaDrv = appUdmaGetObj();
        if (gEthAppObj.hUdmaDrv == NULL)
            appLogPrintf("ETHFW: ERROR: failed to open UDMA driver\n");
            status = -1;
    /* Initialize Ethernet Firmware */
    if (status == ETHAPP_OK)
        status = EthApp_initEthFw();
    /* Initialize lwIP */
        TaskP_Params taskParams;
        TaskP_Params_init(&taskParams);
        taskParams.priority  = DEFAULT_THREAD_PRIO;
        taskParams.stack     = &gEthAppLwipStackBuf[0];
        taskParams.stacksize = sizeof(gEthAppLwipStackBuf);
        taskParams.name      = "lwIP main loop";
        taskParams.userData  = &gEthApp_lwipMainTaskSemObj;
#endif
        TaskP_create(&EthApp_lwipMain, &taskParams);
        appLogPrintf("ETHFW: Init ... DONE !!!\n");
    else
        appLogPrintf("ETHFW: Init ... ERROR !!!\n");
    return status;
int32_t appEthFwDeInit()
    int32_t status = 0;
    EthFw_deinit(gEthAppObj.hEthFw);
    return status;
int32_t appEthFwRemoteServerInit()
    int32_t status;
    appLogPrintf("ETHFW: Remove server Init ... !!!\n");
    /* Initialize the Remote Config server (CPSW Proxy Server) */
    status = EthFw_initRemoteConfig(gEthAppObj.hEthFw);
        appLogPrintf("ETHFW: Remove server Init ... ERROR (%d) !!! \n", status);
    else
        appLogPrintf("ETHFW: Remove server Init ... DONE !!!\n");
    return status;
void LwipifEnetAppCb_getHandle(LwipifEnetAppIf_GetHandleInArgs *inArgs,
                               LwipifEnetAppIf_GetHandleOutArgs *outArgs)
    /* Wait for EthFw to be initialized */
    SemaphoreP_pend(gEthAppObj.hInitSem, SemaphoreP_WAIT_FOREVER);
    EthFwCallbacks_lwipifCpswGetHandle(inArgs, outArgs);
    /* Save host port MAC address */
    EnetUtils_copyMacAddr(&gEthAppObj.hostMacAddr[0U],
                          &outArgs->rxInfo[0U].macAddr[0U]);
void LwipifEnetAppCb_releaseHandle(LwipifEnetAppIf_ReleaseHandleInfo *releaseInfo)
    EthFwCallbacks_lwipifCpswReleaseHandle(releaseInfo);
    EthFw_Version ver;
    EthFw_Config ethFwCfg;
    Cpsw_Cfg *cpswCfg = &ethFwCfg.cpswCfg;
    EnetUdma_Cfg dmaCfg;
    EnetRm_MacAddressPool *pool = &cpswCfg->resCfg.macList;
    uint32_t poolSize;
    int32_t i;
    /* Set EthFw config params */
    EthFw_initConfigParams(gEthAppObj.enetType, &ethFwCfg);
    dmaCfg.rxChInitPrms.dmaPriority = UDMA_DEFAULT_RX_CH_DMA_PRIORITY;
    dmaCfg.hUdmaDrv = gEthAppObj.hUdmaDrv;
    cpswCfg->dmaCfg = (void *)&dmaCfg;
    /* Populate MAC address pool */
    poolSize = EnetUtils_min(ENET_ARRAYSIZE(pool->macAddress), ETHAPP_MAC_ADDR_POOL_SIZE);
    pool->numMacAddress = EthFwBoard_getMacAddrPool(pool->macAddress, poolSize);
    /* Set hardware port configuration parameters */
    ethFwCfg.ports = &gEthAppPorts[0];
    ethFwCfg.numPorts = ARRAY_SIZE(gEthAppPorts);
    ethFwCfg.setPortCfg = EthFwBoard_setPortCfg;
    /* Set virtual port configuration parameters */
    ethFwCfg.virtPortCfg  = &gEthApp_virtPortCfg[0];
    ethFwCfg.numVirtPorts = ARRAY_SIZE(gEthApp_virtPortCfg);
    /* Set AUTOSAR virtual port configuration parameters */
    ethFwCfg.autosarVirtPortCfg  = &gEthApp_autosarVirtPortCfg[0];
    ethFwCfg.numAutosarVirtPorts = ARRAY_SIZE(gEthApp_autosarVirtPortCfg);
    /* CPTS_RFT_CLK is sourced from MAIN_SYSCLK0 (500MHz) */
    cpswCfg->cptsCfg.cptsRftClkFreq = CPSW_CPTS_RFTCLK_FREQ_500MHZ;
    /* Overwrite config params with those for hardware interVLAN */
    EthHwInterVlan_setOpenPrms(&ethFwCfg.cpswCfg);
    /* Set static configuration functions */
    ethFwCfg.addStaticCfg = &EthApp_addRemoteCoreStaticCfg;
    ethFwCfg.delStaticCfg = &EthApp_delRemoteCoreStaticCfg;
    if (ARRAY_SIZE(gEthApp_sharedMcastAddrTable) > ETHAPP_MAX_SHARED_MCAST_ADDR)
        appLogPrintf("ETHFW error: No. of shared mcast addr cannot exceed %d\n",
                    ETHAPP_MAX_SHARED_MCAST_ADDR);
        status = ETHAPP_ERROR;
    else
        for (i = 0U; i < ARRAY_SIZE(gEthApp_sharedMcastAddrTable); i++)
            EnetUtils_copyMacAddr(&ethFwCfg.sharedMcastCfg.macAddrList[i][0],
                                  &gEthApp_sharedMcastAddrTable[i].macAddr[0]);
        ethFwCfg.sharedMcastCfg.numMacAddr = ARRAY_SIZE(gEthApp_sharedMcastAddrTable);
        ethFwCfg.sharedMcastCfg.filterAddMacSharedCb = EthApp_filterAddMacSharedCb;
        ethFwCfg.sharedMcastCfg.filterDelMacSharedCb = EthApp_filterDelMacSharedCb;
#endif
        if (ARRAY_SIZE(gEthApp_rsvdMcastAddrTable) > ETHFW_RSVD_MCAST_LIST_LEN)
            appLogPrintf("ETHFW error: No. of rsvd mcast addr cannot exceed %d\n",
                         ETHFW_RSVD_MCAST_LIST_LEN);
        else
            for (i = 0U; i < ARRAY_SIZE(gEthApp_rsvdMcastAddrTable); i++)
                EnetUtils_copyMacAddr(&ethFwCfg.rsvdMcastCfg.macAddrList[i][0],
                                      &gEthApp_rsvdMcastAddrTable[i][0]);
            ethFwCfg.rsvdMcastCfg.numMacAddr = ARRAY_SIZE(gEthApp_rsvdMcastAddrTable);
    /* Initialize the EthFw */
        gEthAppObj.hEthFw = EthFw_init(gEthAppObj.enetType, &ethFwCfg);
        if (gEthAppObj.hEthFw == NULL)
            appLogPrintf("ETHFW: failed to initialize the firmware\n");
    /* Get and print EthFw version */
        EthFw_getVersion(gEthAppObj.hEthFw, &ver);
        appLogPrintf("ETHFW Version   : %d.%02d.%02d\n", ver.major, ver.minor, ver.rev);
        appLogPrintf("ETHFW Build Date: %s %s, %s\n", ver.month, ver.date, ver.year);
        appLogPrintf("ETHFW Build Time: %s:%s:%s\n", ver.hour, ver.min, ver.sec);
        appLogPrintf("ETHFW Commit SHA: %s\n\n", ver.commitHash);
    /* Post semaphore so that lwip or NIMU/NDK can continue with their initialization */
        SemaphoreP_post(gEthAppObj.hInitSem);
    return status;
/* lwIP callbacks (exact name required) */
bool EthFwCallbacks_isPortLinked(struct netif *netif,
                                 Enet_Handle hEnet)
    bool linked = false;
    uint32_t i;
    /* Report port linked as long as any port owned by EthFw is up */
    for (i = 0U; (i < ARRAY_SIZE(gEthAppPorts)) && !linked; i++)
        linked = EnetAppUtils_isPortLinkUp(hEnet,
                                           gEthAppObj.coreId,
                                           gEthAppPorts[i]);
    return linked;
                            void *a1)
    err_t err;
    sys_sem_t initSem;
    appUtilsTaskInit();
    /* initialize lwIP stack and network interfaces */
    err = sys_sem_new(&initSem, 0);
    LWIP_ASSERT("failed to create initSem", err == ERR_OK);
    LWIP_UNUSED_ARG(err);
    tcpip_init(EthApp_initLwip, &initSem);
    /* we have to wait for initialization to finish before
     * calling update_adapter()! */
    sys_sem_wait(&initSem);
    sys_sem_free(&initSem);
#if (LWIP_SOCKET || LWIP_NETCONN) && LWIP_NETCONN_SEM_PER_THREAD
    netconn_thread_init();
#endif
    sys_sem_t *initSem;
    LWIP_ASSERT("arg != NULL", arg != NULL);
    initSem = (sys_sem_t*)arg;
    /* init randomizer again (seed per thread) */
    srand((unsigned int)sys_now()/1000);
    /* init network interfaces */
    EthApp_initNetif();
    sys_sem_signal(initSem);
    ip4_addr_t ipaddr, netmask, gw;
#if ETHAPP_LWIP_USE_DHCP
    err_t err;
#endif
    ip4_addr_set_zero(&gw);
    ip4_addr_set_zero(&ipaddr);
    ip4_addr_set_zero(&netmask);
    appLogPrintf("Starting lwIP, local interface IP is dhcp-enabled\n");
#else /* ETHAPP_LWIP_USE_DHCP */
    ETHFW_SERVER_GW(&gw);
    ETHFW_SERVER_IPADDR(&ipaddr);
    ETHFW_SERVER_NETMASK(&netmask);
    appLogPrintf("Starting lwIP, local interface IP is %s\n", ip4addr_ntoa(&ipaddr));
#endif /* ETHAPP_LWIP_USE_DHCP */
    /* Create Enet LLD ethernet interface */
    netif_add(&netif, NULL, NULL, NULL, NULL, LWIPIF_LWIP_init, tcpip_input);
    /* Create inter-core virtual ethernet interface: MCU2_0 <-> MCU2_1 */
    netif_add(&netif_ic[ETHAPP_NETIF_IC_MCU2_0_MCU2_1_IDX], NULL, NULL, NULL,
              (void*)&netif_ic_state[IC_ETH_IF_MCU2_0_MCU2_1],
              LWIPIF_LWIP_IC_init, tcpip_input);
    /* Create inter-core virtual ethernet interface: MCU2_0 <-> A72 */
    netif_add(&netif_ic[ETHAPP_NETIF_IC_MCU2_0_A72_IDX], NULL, NULL, NULL,
              (void*)&netif_ic_state[IC_ETH_IF_MCU2_0_A72],
    /* Create bridge interface */
    bridge_initdata.max_ports = ETHAPP_LWIP_BRIDGE_MAX_PORTS;
    bridge_initdata.max_fdb_dynamic_entries = ETHAPP_LWIP_BRIDGE_MAX_DYNAMIC_ENTRIES;
    bridge_initdata.max_fdb_static_entries = ETHAPP_LWIP_BRIDGE_MAX_STATIC_ENTRIES;
    EnetUtils_copyMacAddr(&bridge_initdata.ethaddr.addr[0U], &gEthAppObj.hostMacAddr[0U]);
    netif_add(&netif_bridge, &ipaddr, &netmask, &gw, &bridge_initdata, bridgeif_init, netif_input);
    /* Add all netifs to the bridge and create coreId to bridge portId map */
    bridgeif_add_port(&netif_bridge, &netif);
    gEthApp_lwipBridgePortIdMap[IPC_MCU2_0] = ETHAPP_BRIDGEIF_CPU_PORT_ID;
    bridgeif_add_port(&netif_bridge, &netif_ic[0]);
    gEthApp_lwipBridgePortIdMap[IPC_MCU2_1] = ETHAPP_BRIDGEIF_PORT1_ID;
    bridgeif_add_port(&netif_bridge, &netif_ic[1]);
    gEthApp_lwipBridgePortIdMap[IPC_MPU1_0] = ETHAPP_BRIDGEIF_PORT2_ID;
    /* Set bridge interface as the default */
    netif_set_default(&netif_bridge);
#else
    netif_add(&netif, &ipaddr, &netmask, &gw, NULL, LWIPIF_LWIP_init, tcpip_input);
    netif_set_default(&netif);
#endif
    netif_set_status_callback(netif_default, EthApp_netifStatusCb);
    dhcp_set_struct(netif_default, &gEthAppObj.dhcpNetif);
    netif_set_up(&netif);
    netif_set_up(&netif_ic[ETHAPP_NETIF_IC_MCU2_0_MCU2_1_IDX]);
    netif_set_up(&netif_ic[ETHAPP_NETIF_IC_MCU2_0_A72_IDX]);
    netif_set_up(&netif_bridge);
#else
    netif_set_up(netif_default);
#endif
    err = dhcp_start(netif_default);
    if (err != ERR_OK)
        appLogPrintf("Failed to start DHCP: %d\n", err);
    Enet_MacPort macPort = ENET_MAC_PORT_1;
    int32_t status;
    if (netif_is_up(netif))
        const ip4_addr_t *ipAddr = netif_ip4_addr(netif);
        appLogPrintf("Added interface '%c%c%d', IP is %s\n",
                     netif->name[0], netif->name[1], netif->num, ip4addr_ntoa(ipAddr));
        if (ipAddr->addr != 0)
            gEthAppObj.hostIpAddr = lwip_ntohl(ip_addr_get_ip4_u32(ipAddr));
            /* MAC port used for PTP */
            macPort = ENET_MAC_PORT_3;
            /* Initialize and enable PTP stack */
            EthFw_initTimeSyncPtp(gEthAppObj.hostIpAddr,
                                  ENET_BIT(ENET_MACPORT_NORM(macPort)));
            /* Assign functions that are to be called based on actions in GUI.
             * These cannot be dynamically pushed to function pointer array, as the
             * index is used in GUI as command */
            EnetCfgServer_fxn_table[9] = &EthApp_startSwInterVlan;
            EnetCfgServer_fxn_table[10] = &EthApp_startHwInterVlan;
            /* Start Configuration server */
            status = EnetCfgServer_init(gEthAppObj.enetType, gEthAppObj.instId);
            EnetAppUtils_assert(ENET_SOK == status);
            /* Start the software-based interVLAN routing */
            EthSwInterVlan_setupRouting(gEthAppObj.enetType, ETH_SWINTERVLAN_TASK_PRI);
    else
        appLogPrintf("Removed interface '%c%c%d'\n", netif->name[0], netif->name[1], netif->num);
/* Functions called from Config server library based on selection from GUI */
                                    char *sendBuff)
    EnetCfgServer_InterVlanConfig *pInterVlanCfg;
    int32_t status;
    if (recvBuff != NULL)
        pInterVlanCfg = (EnetCfgServer_InterVlanConfig *)recvBuff;
        status = EthSwInterVlan_addClassifierEntries(pInterVlanCfg);
                                    char *sendBuff)
        EthHwInterVlan_setupRouting(gEthAppObj.enetType, pInterVlanCfg);
/* Application callback function to handle addition of a shared mcast
 * address in the ALE */
    uint8_t idx = 0;
    struct eth_addr ethaddr;
    bool matchFound = false;
    int32_t errVal = 0;
    /* Search the mac_address in the shared mcast addr table */
    for (idx = 0; idx < ARRAY_SIZE(gEthApp_sharedMcastAddrTable); idx++)
        if (EnetUtils_cmpMacAddr(mac_address,
                    &gEthApp_sharedMcastAddrTable[idx].macAddr[0]))
            matchFound = true;
            /* Read and update stored port mask */
            portMask = gEthApp_sharedMcastAddrTable[idx].portMask;
            portMask |= (0x01 << gEthApp_lwipBridgePortIdMap[hostId]);
            gEthApp_sharedMcastAddrTable[idx].portMask = portMask;
            /* Update bridge fdb entry for this mac_address */
            EnetUtils_copyMacAddr(&ethaddr.addr[0U], mac_address);
            /* There will be a delay between removing existing FDB entry
             * and adding the updated one. During this time, multicast
             * packets will be flodded to all the bridge ports
            bridgeif_fdb_remove(&netif_bridge, &ethaddr);
            errVal = bridgeif_fdb_add(&netif_bridge,
                                      &ethaddr,
                                      gEthApp_sharedMcastAddrTable[idx].portMask);
            if (errVal)
                appLogPrintf("addMacSharedCb: bridgeif_fdb_add failed (%d)\n", errVal);
            /* The array should have unique mcast addresses,
             * so no other match is expected
            break;
    if (!matchFound)
        appLogPrintf("addMacSharedCb: Address not found\n");
/* Application callback function to handle deletion of a shared mcast
 * address from the ALE */
    uint8_t idx = 0;
    int32_t errVal = 0;
            matchFound = true;
            portMask &= ~(0x01 << gEthApp_lwipBridgePortIdMap[hostId]);
            if (gEthApp_sharedMcastAddrTable[idx].portMask)
                                          &ethaddr,
            if (errVal)
                appLogPrintf("delMacSharedCb: bridgeif_fdb_add failed (%d)\n", errVal);
            break;
    if (!matchFound)
        appLogPrintf("delMacSharedCb: Address not found\n");
#endif
static int32_t EthApp_addMpu10StaticCfg(Enet_Handle hEnet,
                                        uint32_t coreId,
                                        uint32_t flowId)
    const uint8_t mcastAddr[ENET_MAC_ADDR_LEN] = {0x01, 0x99, 0xc2, 0x00, 0x01, 0x0E};
    CpswAle_SetPolicerEntryInArgs polInArgs;
    CpswAle_SetPolicerEntryOutArgs polOutArgs;
    CpswAle_SetMcastEntryInArgs mcastInArgs;
    Enet_IoctlPrms prms;
    uint32_t entry;
    int32_t status;
#if 1
    CpswAle_VlanEntryInfo inArgs;
    uint32_t outArgs;
    /* Add VLAN entry */
    memset(&inArgs, 0U, sizeof (CpswAle_VlanEntryInfo));
    inArgs.vlanIdInfo.vlanId = TEST_VID_A72;
    inArgs.vlanIdInfo.tagType = ENET_VLAN_TAG_TYPE_INNER;
    inArgs.vlanMemberList = (1 << CPSW_ALE_MACPORT_TO_ALEPORT(ENET_MAC_PORT_3)) | \
                            CPSW_ALE_HOST_PORT_MASK;
    inArgs.unregMcastFloodMask = (1 << CPSW_ALE_MACPORT_TO_ALEPORT(ENET_MAC_PORT_3)) | \
    inArgs.regMcastFloodMask = (1 << CPSW_ALE_MACPORT_TO_ALEPORT(ENET_MAC_PORT_3)) | \
    inArgs.forceUntaggedEgressMask = 0;
    inArgs.noLearnMask = 0U;
    inArgs.vidIngressCheck = true;
    inArgs.limitIPNxtHdr = false;
    inArgs.disallowIPFrag = false;
    ENET_IOCTL_SET_INOUT_ARGS(&prms, &inArgs, &outArgs);
    status = Enet_ioctl(hEnet, gEthAppObj.coreId, CPSW_ALE_IOCTL_ADD_VLAN, &prms);
        appLogPrintf("%s() failed ADD_VLAN ioctl failed: %d\n", __func__, status);
    inArgs.vlanIdInfo.vlanId = (TEST_VID_A72+10);
    inArgs.vlanMemberList = (1 << CPSW_ALE_MACPORT_TO_ALEPORT(ENET_MAC_PORT_5));
    inArgs.unregMcastFloodMask = (1 << CPSW_ALE_MACPORT_TO_ALEPORT(ENET_MAC_PORT_5));
    inArgs.regMcastFloodMask = (1 << CPSW_ALE_MACPORT_TO_ALEPORT(ENET_MAC_PORT_5));
#endif
    polInArgs.policerMatch.policerMatchEnMask = 0U;
    /* Add policer entry for port 1 and dstmac */
    polInArgs.policerMatch.policerMatchEnMask = CPSW_ALE_POLICER_MATCH_PORT;
    polInArgs.policerMatch.portNum = CPSW_ALE_MACPORT_TO_ALEPORT(ENET_MAC_PORT_1);
    polInArgs.policerMatch.portIsTrunk = false;
    polInArgs.policerMatch.policerMatchEnMask |= CPSW_ALE_POLICER_MATCH_MACDST;
    polInArgs.policerMatch.dstMacAddrInfo.portNum = CPSW_ALE_HOST_PORT_NUM;
    polInArgs.policerMatch.dstMacAddrInfo.addr.vlanId = 0;
    EnetUtils_copyMacAddr(&polInArgs.policerMatch.dstMacAddrInfo.addr.addr[0], &mcastAddr[0]);
    polInArgs.threadIdEn = true;
    polInArgs.threadId   = flowId;
    polInArgs.peakRateInBitsPerSec   = 0U;
    polInArgs.commitRateInBitsPerSec = 0U;
    ENET_IOCTL_SET_INOUT_ARGS(&prms, &polInArgs, &polOutArgs);
    status = Enet_ioctl(hEnet, gEthAppObj.coreId, CPSW_ALE_IOCTL_SET_POLICER, &prms);
        appLogPrintf("Failed to register PORT1 | MACDST policer: %d\n", status);
    /* Add policer entry for port 6 and dstmac */
        memset(&polInArgs, 0U, sizeof (polInArgs));
        polInArgs.policerMatch.portNum = CPSW_ALE_MACPORT_TO_ALEPORT(ENET_MAC_PORT_5);
        polInArgs.policerMatch.policerMatchEnMask |= CPSW_ALE_POLICER_MATCH_IVLAN;
        polInArgs.policerMatch.ivlanId = (TEST_VID_A72+10);
            appLogPrintf("Failed to register PORT3 | MACDST policer: %d\n", status);
    /* Add policer entry for port 3 and dstmac */
        polInArgs.policerMatch.portNum = CPSW_ALE_MACPORT_TO_ALEPORT(ENET_MAC_PORT_3);
        polInArgs.policerMatch.ivlanId = (TEST_VID_A72);
    /* Add multicast entry with port mask: host port, MAC port 1 and MAC port 3 */
        mcastInArgs.addr.vlanId = 0U;
        EnetUtils_copyMacAddr(&mcastInArgs.addr.addr[0], &mcastAddr[0]);
        mcastInArgs.info.super    = false;
        mcastInArgs.info.fwdState = CPSW_ALE_FWDSTLVL_FWD;
        mcastInArgs.info.portMask = (CPSW_ALE_HOST_PORT_MASK |
                                     CPSW_ALE_MACPORT_TO_PORTMASK(ENET_MAC_PORT_1) |
                                     CPSW_ALE_MACPORT_TO_PORTMASK(ENET_MAC_PORT_5) |
                                     CPSW_ALE_MACPORT_TO_PORTMASK(ENET_MAC_PORT_3));
        mcastInArgs.info.numIgnBits = 0U;
        ENET_IOCTL_SET_INOUT_ARGS(&prms, &mcastInArgs, &entry);
        status = Enet_ioctl(hEnet, gEthAppObj.coreId, CPSW_ALE_IOCTL_ADD_MCAST, &prms);
            appLogPrintf("Failed to add mcast ports: %d\n", status);
    return status;
static void EthApp_delMpu10StaticCfg(Enet_Handle hEnet,
                                     uint32_t coreId,
                                     uint32_t flowId)
    const uint8_t mcastAddr[ENET_MAC_ADDR_LEN] = {0x01, 0x80, 0xc2, 0x00, 0x01, 0x0E};
    CpswAle_DelPolicerEntryInArgs polInArgs;
    int32_t status;
    /* Delete policer entry for port 1 and dstmac */
    polInArgs.policerMatch.dstMacAddrInfo.addr.vlanId = 0U;
    polInArgs.aleEntryMask = CPSW_ALE_POLICER_MATCH_PORT;
    ENET_IOCTL_SET_IN_ARGS(&prms, &polInArgs);
    status = Enet_ioctl(hEnet, gEthAppObj.coreId, CPSW_ALE_IOCTL_DEL_POLICER, &prms);
        appLogPrintf("Failed to delete PORT1 | MACDST policer: %d\n", status);
    /* Delete policer entry for port 6 and dstmac */
            appLogPrintf("Failed to delete PORT3 | MACDST policer: %d\n", status);
    /* Delete policer entry for port 3 and dstmac */
        polInArgs.policerMatch.ivlanId = TEST_VID_A72;
                                             uint32_t coreId,
                                             uint32_t flowId)
    int32_t status = ENET_SOK;
    switch (coreId)
        case IPC_MPU1_0:
            appLogPrintf("Add static config for mpu1_0\n");
            status = EthApp_addMpu10StaticCfg(hEnet, coreId, flowId);
            break;
        default:
            break;
    return status;
                                          uint32_t coreId,
                                          uint32_t flowId)
    switch (coreId)
        case IPC_MPU1_0:
            appLogPrintf("Delete static config for mpu1_0\n");
            EthApp_delMpu10StaticCfg(hEnet, coreId, flowId);
            break;
        default:
            break;
    Sudheer、请优先查看这张票证、并向客户提供一些建议以供其试用。 谢谢。
    您好,TI 专家
    我不知道如何在 ethfw 中配置 VLAN 的访问功能。 我设置了女警察。 portIsTrunk 设置为 false,但发送时不会删除已发送数据包的 VLAN 标记。 我该怎么办
    将数据包从一个端口转发到另一个端口取决于目标 MAC 地址。
    在您的情况下,您将配置端口3和端口5的多播 MAC 地址。 这就是通过连接到端口5的 PC 中的端口3从测试机发送数据包的原因。
    您只能注册端口3的多播地址,然后在端口5上看不到数据包。
    苏德黑尔
    您好!,
    如果我只为端口3配置多播 MAC 地址、端口5将无法看到数据、因为 MAC 地址被过滤、而不是 VLAN。我想知道如何使用 VLAN 过滤来转发数据包。
    例如,如果端口3的 VLAN ID 设置为10和30,端口5的 VLAN ID 设置为20和30。 如果端口3接收到来自 VLAN 10的数据包,则端口5不会转发数据包。 如果端口3接收到来自 VLAN 30的数据包,则端口5将正确转发端口。
    在这里我发现了另一个问题,例如,如果将端口3的 VLAN 设置为100,端口3通常可以从 VLAN 100发送和接收数据包。 然后,如果将端口5的 VLAN 设置为100,端口5通常可以从 VLAN 100接收数据包。端口3不能通过 VLAN 100发送或接收数据包。 如何解决该问题?
    您能否分享 ALE & Policer 条目供我们参考、请参阅 常见问题解答 [如何打印 ALE 条目]以收集 ALE 表。
    苏德黑尔
    这是 ALE 表。 我首先为端口3添加了一个50的 VLAN ID,然后为端口5添加了一个50的 VLAN ID
    root@j7-evm:/opt/vision_apps# ./hirain_ale.out add-pvid pvid 50 port 3
    APP: Init ... !!!
    MEM: Init ... !!!
    MEM: Initialized DMA HEAP (fd=4) !!!
    MEM: Init ... Done !!!
    IPC: Init ... !!!
    IPC: Init ... Done !!!
    REMOTE_SERVICE: Init ... !!!
    REMOTE_SERVICE: Init ... Done !!!
         0.000000 s: GTC Frequency = 0 MHz
    APP: Init ... Done !!!
         0.000000 s:  VX_ZONE_INIT:Enabled
         0.000000 s:  VX_ZONE_ERROR:Enabled
         0.000000 s:  VX_ZONE_WARNING:Enabled
         0.000000 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
         0.000000 s:  VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!!
         0.000000 s:  VX_ZONE_INIT:[tivxHostDeInitLocal:107] De-Initialization Done for HOST !!!
    [MCU2_0]     71.723423 s: HirainMainR5FRemoteServiceHandler()  ADD_VLAN ioctl success: 0,id:50,port:3,list:9
    [MCU2_0]     71.723532 s: HIRAIN_CMD_CPSW9G_PVID_TEST exec end!
         0.000000 s:  VX_ZONE_INIT:[tivxDeInitLocal:193] De-Initialization Done !!!
    APP: Deinit ... !!!
    REMOTE_SERVICE: Deinit ... !!!
    REMOTE_SERVICE: Deinit ... Done !!!
    IPC: Deinit ... !!!
    IPC: DeInit ... Done !!!
    MEM: Deinit ... !!!
    DDR_SHARED_MEM: Alloc's: 0 alloc's of 0 bytes
    DDR_SHARED_MEM: Free's : 0 free's  of 0 bytes
    DDR_SHARED_MEM: Open's : 0 allocs  of 0 bytes
    DDR_SHARED_MEM: Total size: 536870912 bytes
    MEM: Deinit ... Done !!!
    APP: Deinit ... Done !!!
    root@j7-evm:/opt/vision_apps# ./hirain_ale.out add-pvid pvid 50 port 5
    APP: Init ... !!!
    MEM: Init ... !!!
    IPC: Init ... !!!
    [MCU2_0]     78.107303 s: HirainMainR5FRemoteServiceHandler()  ADD_VLAN ioctl success: 0,id:50,port:5,list:21
    [MCU2_0]     78.107421 s: HIRAIN_CMD_CPSW9G_PVID_TEST exec end!
    APP: Deinit ... !!!
    IPC: Deinit ... !!!
    MEM: Deinit ... !!!
    root@j7-evm:/opt/vision_apps# ./hirain_ale.out 9g
    APP: Init ... !!!
    MEM: Init ... !!!
    IPC: Init ... !!!
    APP: Deinit ... !!!
    [MCU2_0]     85.089130 s: ---------------------------------------------
    [MCU2_0]     85.089207 s: -------CPSWnG ALE TABLE----------------------
    [MCU2_0]     85.089248 s: ---------------------------------------------
    [MCU2_0]     85.089284 s: ---------------------------------------------
    [MCU2_0]     85.089317 s:  Entry 0 - VLAN INNER
    [MCU2_0]     85.089347 s: ---------------------------------------------
    [MCU2_0]     85.089380 s: ENTRY_TYPE        = 2
    [MCU2_0]     85.089407 s: IVLAN_ID           = 50
    [MCU2_0]     85.089436 s: NO FRAG           = 0
    [MCU2_0]     85.089463 s: REG_MCAST_FLOOD   = 511
    [MCU2_0]     85.089491 s: VLAN FWD Untagged Egress = 256
    [MCU2_0]     85.089521 s: LMT NEXT HDR      = 0
    [MCU2_0]     85.089549 s: UNREG_MCAST_FLOOD = 511
    [MCU2_0]     85.089577 s: VLAN_MEMBER_LIST  = 33
    [MCU2_0]     85.089605 s: ---------------------------------------------
    [MCU2_0]     85.089636 s:  Entry 1 - VLAN INNER
    [MCU2_0]     85.089662 s: ---------------------------------------------
    [MCU2_0]     85.089692 s: ENTRY_TYPE        = 2
    [MCU2_0]     85.089718 s: IVLAN_ID           = 300
    [MCU2_0]     85.089746 s: NO FRAG           = 0
    [MCU2_0]     85.089773 s: REG_MCAST_FLOOD   = 511
    [MCU2_0]     85.089800 s: VLAN FWD Untagged Egress = 511
    [MCU2_0]     85.089829 s: LMT NEXT HDR      = 0
    [MCU2_0]     85.089857 s: UNREG_MCAST_FLOOD = 0
    [MCU2_0]     85.089885 s: VLAN_MEMBER_LIST  = 511
    [MCU2_0]     85.089912 s: ---------------------------------------------
    [MCU2_0]     85.089942 s:  Entry 2 - VLAN INNER
    [MCU2_0]     85.089968 s: ---------------------------------------------
    [MCU2_0]     85.089998 s: ENTRY_TYPE        = 2
    [MCU2_0]     85.090024 s: IVLAN_ID           = 1
    [MCU2_0]     85.090051 s: NO FRAG           = 0
    [MCU2_0]     85.090141 s: REG_MCAST_FLOOD   = 363
    [MCU2_0]     85.090173 s: VLAN FWD Untagged Egress = 107
    [MCU2_0]     85.090206 s: LMT NEXT HDR      = 0
    [MCU2_0]     85.090233 s: UNREG_MCAST_FLOOD = 0
    [MCU2_0]     85.090260 s: VLAN_MEMBER_LIST  = 363
    [MCU2_0]     85.090288 s: ---------------------------------------------
    [MCU2_0]     85.090319 s:  Entry 3 - VLAN INNER
    [MCU2_0]     85.090345 s: ---------------------------------------------
    [MCU2_0]     85.090374 s: ENTRY_TYPE        = 2
    [MCU2_0]     85.090400 s: IVLAN_ID           = 0
    [MCU2_0]     85.090426 s: NO FRAG           = 0
    [MCU2_0]     85.090452 s: REG_MCAST_FLOOD   = 21
    [MCU2_0]     85.090478 s: VLAN FWD Untagged Egress = 277
    [MCU2_0]     85.090507 s: LMT NEXT HDR      = 0
    [MCU2_0]     85.090534 s: UNREG_MCAST_FLOOD = 21
    [MCU2_0]     85.090560 s: VLAN_MEMBER_LIST  = 21
    [MCU2_0]     85.090587 s: ---------------------------------------------
    [MCU2_0]     85.090618 s:  Entry 4 - VLAN INNER
    [MCU2_0]     85.090644 s: ---------------------------------------------
    [MCU2_0]     85.090673 s: ENTRY_TYPE        = 2
    [MCU2_0]     85.090698 s: IVLAN_ID           = 406
    [MCU2_0]     85.090725 s: NO FRAG           = 0
    [MCU2_0]     85.090751 s: REG_MCAST_FLOOD   = 511
    [MCU2_0]     85.090778 s: VLAN FWD Untagged Egress = 511
    [MCU2_0]     85.090807 s: LMT NEXT HDR      = 0
    [MCU2_0]     85.090833 s: UNREG_MCAST_FLOOD = 0
    [MCU2_0]     85.090859 s: VLAN_MEMBER_LIST  = 511
    [MCU2_0]     85.090886 s: ---------------------------------------------
    [MCU2_0]     85.090916 s:  Entry 5 - Multicast
    [MCU2_0]     85.090944 s: ---------------------------------------------
    [MCU2_0]     85.090974 s: PORT_MASK        = 1ff
    [MCU2_0]     85.091002 s: SUPER            = 0
    [MCU2_0]     85.091029 s: MCAST IGNORE BITS= 0
    [MCU2_0]     85.091095 s: MCAST_FWD_STATE  = 0
    IPC: Deinit ... !!!
    [MCU2_0]     85.091134 s: ENTRY_TYPE       = 1
    [MCU2_0]     85.091163 s: MULTICAST_ADDR   = ffff ffffffff
    [MCU2_0]     85.091198 s: ---------------------------------------------
    [MCU2_0]     85.091227 s:  Entry 6 - Multicast
    [MCU2_0]     85.091254 s: ---------------------------------------------
    [MCU2_0]     85.091283 s: PORT_MASK        = 1ff
    [MCU2_0]     85.091310 s: SUPER            = 0
    [MCU2_0]     85.091335 s: MCAST IGNORE BITS= 0
    [MCU2_0]     85.091360 s: MCAST_FWD_STATE  = 0
    [MCU2_0]     85.091386 s: ENTRY_TYPE       = 1
    [MCU2_0]     85.091411 s: MULTICAST_ADDR   = 100 5e7f0001
    [MCU2_0]     85.091445 s: ---------------------------------------------
    [MCU2_0]     85.091474 s:  Entry 7 - Multicast
    [MCU2_0]     85.091501 s: ---------------------------------------------
    [MCU2_0]     85.091530 s: PORT_MASK        = 1ff
    [MCU2_0]     85.091558 s: SUPER            = 0
    [MCU2_0]     85.091585 s: MCAST IGNORE BITS= 0
    [MCU2_0]     85.091611 s: MCAST_FWD_STATE  = 0
    [MCU2_0]     85.091637 s: ENTRY_TYPE       = 1
    [MCU2_0]     85.091664 s: MULTICAST_ADDR   = 100 5e303401
    [MCU2_0]     85.091697 s: ---------------------------------------------
    [MCU2_0]     85.091728 s:  Entry 8 - Multicast
    [MCU2_0]     85.091755 s: ---------------------------------------------
    [MCU2_0]     85.091786 s: PORT_MASK        = 1ff
    [MCU2_0]     85.091813 s: SUPER            = 0
    [MCU2_0]     85.091841 s: MCAST IGNORE BITS= 0
    [MCU2_0]     85.091867 s: MCAST_FWD_STATE  = 0
    [MCU2_0]     85.091894 s: ENTRY_TYPE       = 1
    [MCU2_0]     85.091920 s: MULTICAST_ADDR   = 100 5e010101
    [MCU2_0]     85.091952 s: ---------------------------------------------
    [MCU2_0]     85.091982 s:  Entry 9 - Unicast
    [MCU2_0]     85.092007 s: ---------------------------------------------
    [MCU2_0]     85.092036 s: TRUNK            = 0
    [MCU2_0]     85.092095 s: PORT_NUMBER      = 0
    [MCU2_0]     85.092134 s: BLOCK            = 0
    [MCU2_0]     85.092165 s: SECURE           = 1
    [MCU2_0]     85.092192 s: TOUCH            = 0
    [MCU2_0]     85.092221 s: AGEABLE          = 0
    [MCU2_0]     85.092248 s: ENTRY_TYPE       = 1
    [MCU2_0]     85.092274 s: UNICAST_ADDR     = 70ff 761d92c3
    [MCU2_0]     85.092308 s: ---------------------------------------------
    [MCU2_0]     85.092337 s:  Entry 11 - Unicast
    [MCU2_0]     85.092363 s: ---------------------------------------------
    [MCU2_0]     85.092392 s: TRUNK            = 0
    [MCU2_0]     85.092418 s: PORT_NUMBER      = 0
    MEM: Deinit ... !!!
    [MCU2_0]     85.092444 s: BLOCK            = 0
    [MCU2_0]     85.092470 s: SECURE           = 1
    [MCU2_0]     85.092496 s: TOUCH            = 0
    [MCU2_0]     85.092522 s: AGEABLE          = 0
    [MCU2_0]     85.092548 s: ENTRY_TYPE       = 1
    [MCU2_0]     85.092574 s: UNICAST_ADDR     = e46 2201a202
    [MCU2_0]     85.092607 s: ---------------------------------------------
    [MCU2_0]     85.092637 s:  Entry 12 - Unicast
    [MCU2_0]     85.092663 s: ---------------------------------------------
    [MCU2_0]     85.092692 s: TRUNK            = 0
    [MCU2_0]     85.092720 s: PORT_NUMBER      = 0
    [MCU2_0]     85.092747 s: BLOCK            = 0
    [MCU2_0]     85.092773 s: SECURE           = 0
    [MCU2_0]     85.092800 s: TOUCH            = 0
    [MCU2_0]     85.092825 s: AGEABLE          = 0
    [MCU2_0]     85.092851 s: ENTRY_TYPE       = 1
    [MCU2_0]     85.092877 s: UNICAST_ADDR     = e46 2202a306
    [MCU2_0]     85.092928 s: ---------------------------------------------
    [MCU2_0]     85.092959 s:  Entry 13 - VLAN INNER
    [MCU2_0]     85.092986 s: ---------------------------------------------
    [MCU2_0]     85.093016 s: ENTRY_TYPE        = 2
    [MCU2_0]     85.093042 s: IVLAN_ID           = 100
    [MCU2_0]     85.093145 s: NO FRAG           = 0
    [MCU2_0]     85.093181 s: REG_MCAST_FLOOD   = 9
    [MCU2_0]     85.093210 s: VLAN FWD Untagged Egress = 0
    [MCU2_0]     85.093240 s: LMT NEXT HDR      = 0
    [MCU2_0]     85.093266 s: UNREG_MCAST_FLOOD = 9
    [MCU2_0]     85.093292 s: VLAN_MEMBER_LIST  = 9
    [MCU2_0]     85.093319 s: ---------------------------------------------
    [MCU2_0]     85.093349 s:  Entry 14 - VLAN INNER
    [MCU2_0]     85.093376 s: ---------------------------------------------
    [MCU2_0]     85.093405 s: ENTRY_TYPE        = 2
    [MCU2_0]     85.093431 s: IVLAN_ID           = 110
    [MCU2_0]     85.093458 s: NO FRAG           = 0
    [MCU2_0]     85.093484 s: REG_MCAST_FLOOD   = 33
    [MCU2_0]     85.093512 s: VLAN FWD Untagged Egress = 0
    [MCU2_0]     85.093541 s: LMT NEXT HDR      = 0
    [MCU2_0]     85.093569 s: UNREG_MCAST_FLOOD = 33
    [MCU2_0]     85.093595 s: VLAN_MEMBER_LIST  = 33
    [MCU2_0]     85.093624 s: ---------------------------------------------
    [MCU2_0]     85.093654 s:  Entry 15 - Multicast
    [MCU2_0]     85.093681 s: ---------------------------------------------
    [MCU2_0]     85.093712 s: PORT_MASK        = 2b
    [MCU2_0]     85.093738 s: SUPER            = 0
    [MCU2_0]     85.093764 s: MCAST IGNORE BITS= 0
    [MCU2_0]     85.093789 s: MCAST_FWD_STATE  = 0
    [MCU2_0]     85.093815 s: ENTRY_TYPE       = 1
    [MCU2_0]     85.093841 s: MULTICAST_ADDR   = 199 c200010e
    [MCU2_0]     85.093875 s: ---------------------------------------------
    [MCU2_0]     85.093905 s:  Entry 16 - VLAN OUTER
    [MCU2_0]     85.093932 s: ---------------------------------------------
    [MCU2_0]     85.093961 s: ENTRY_TYPE        = 2
    [MCU2_0]     85.093988 s: OVLAN_ID           = 110
    [MCU2_0]     85.094015 s: NO FRAG           = 0
    [MCU2_0]     85.094040 s: REG_MCAST_FLOOD   = 0
    [MCU2_0]     85.094109 s: VLAN FWD Untagged Egress = 0
    [MCU2_0]     85.094145 s: LMT NEXT HDR      = 0
    [MCU2_0]     85.094174 s: UNREG_MCAST_FLOOD = 0
    [MCU2_0]     85.094201 s: VLAN_MEMBER_LIST  = 0
    [MCU2_0]     85.094229 s: ---------------------------------------------
    [MCU2_0]     85.094260 s:  Entry 17 - VLAN OUTER
    [MCU2_0]     85.094287 s: ---------------------------------------------
    [MCU2_0]     85.094316 s: ENTRY_TYPE        = 2
    [MCU2_0]     85.094343 s: OVLAN_ID           = 100
    [MCU2_0]     85.094370 s: NO FRAG           = 0
    [MCU2_0]     85.094395 s: REG_MCAST_FLOOD   = 0
    [MCU2_0]     85.094421 s: VLAN FWD Untagged Egress = 0
    [MCU2_0]     85.094449 s: LMT NEXT HDR      = 0
    [MCU2_0]     85.094475 s: UNREG_MCAST_FLOOD = 0
    [MCU2_0]     85.094501 s: VLAN_MEMBER_LIST  = 0
    [MCU2_0]     85.094528 s: ---------------------------------------------
    [MCU2_0]     85.094558 s:  Entry 18 - Multicast
    [MCU2_0]     85.094586 s: ---------------------------------------------
    [MCU2_0]     85.094616 s: PORT_MASK        = 16b
    [MCU2_0]     85.094644 s: SUPER            = 0
    [MCU2_0]     85.094670 s: MCAST IGNORE BITS= 0
    [MCU2_0]     85.094695 s: MCAST_FWD_STATE  = 0
    [MCU2_0]     85.094721 s: ENTRY_TYPE       = 1
    [MCU2_0]     85.094747 s: MULTICAST_ADDR   = 3333 1
    [MCU2_0]     85.094778 s: ---------------------------------------------
    [MCU2_0]     85.094808 s:  Entry 19 - Multicast
    [MCU2_0]     85.094834 s: ---------------------------------------------
    [MCU2_0]     85.094865 s: PORT_MASK        = 16b
    [MCU2_0]     85.094891 s: SUPER            = 0
    [MCU2_0]     85.094917 s: MCAST IGNORE BITS= 0
    [MCU2_0]     85.094942 s: MCAST_FWD_STATE  = 0
    [MCU2_0]     85.094968 s: ENTRY_TYPE       = 1
    [MCU2_0]     85.094994 s: MULTICAST_ADDR   = 100 5e000001
    [MCU2_0]     85.095027 s: ---------------------------------------------
    [MCU2_0]     85.095090 s:  Entry 20 - Multicast
    [MCU2_0]     85.095133 s: ---------------------------------------------
    [MCU2_0]     85.095167 s: PORT_MASK        = 16b
    [MCU2_0]     85.095194 s: SUPER            = 0
    [MCU2_0]     85.095221 s: MCAST IGNORE BITS= 0
    [MCU2_0]     85.095247 s: MCAST_FWD_STATE  = 0
    [MCU2_0]     85.095273 s: ENTRY_TYPE       = 1
    [MCU2_0]     85.095298 s: MULTICAST_ADDR   = 3333 ff02a306
    [MCU2_0]     85.095331 s: ---------------------------------------------
    [MCU2_0]     85.095360 s:  Entry 21 - Multicast
    [MCU2_0]     85.095388 s: ---------------------------------------------
    [MCU2_0]     85.095417 s: PORT_MASK        = 16b
    [MCU2_0]     85.095444 s: SUPER            = 0
    [MCU2_0]     85.095469 s: MCAST IGNORE BITS= 0
    [MCU2_0]     85.095495 s: MCAST_FWD_STATE  = 0
    [MCU2_0]     85.095520 s: ENTRY_TYPE       = 1
    [MCU2_0]     85.095545 s: MULTICAST_ADDR   = 180 c2000000
    [MCU2_0]     85.095579 s: ---------------------------------------------
    [MCU2_0]     85.095608 s:  Entry 22 - Multicast
    [MCU2_0]     85.095635 s: ---------------------------------------------
    [MCU2_0]     85.095665 s: PORT_MASK        = 16b
    [MCU2_0]     85.095692 s: SUPER            = 0
    [MCU2_0]     85.095718 s: MCAST IGNORE BITS= 0
    [MCU2_0]     85.095743 s: MCAST_FWD_STATE  = 0
    [MCU2_0]     85.095768 s: ENTRY_TYPE       = 1
    [MCU2_0]     85.095794 s: MULTICAST_ADDR   = 180 c2000003
    [MCU2_0]     85.095827 s: ---------------------------------------------
    [MCU2_0]     85.095857 s:  Entry 23 - Multicast
    [MCU2_0]     85.095884 s: ---------------------------------------------
    [MCU2_0]     85.095913 s: PORT_MASK        = 16b
    [MCU2_0]     85.095941 s: SUPER            = 0
    [MCU2_0]     85.095966 s: MCAST IGNORE BITS= 0
    [MCU2_0]     85.095991 s: MCAST_FWD_STATE  = 0
    [MCU2_0]     85.096017 s: ENTRY_TYPE       = 1
    [MCU2_0]     85.096043 s: MULTICAST_ADDR   = 100 5e0000fc
    [MCU2_0]     85.096119 s: ---------------------------------------------
    [MCU2_0]     85.096156 s:  Entry 24 - Multicast
    [MCU2_0]     85.096186 s: ---------------------------------------------
    [MCU2_0]     85.096217 s: PORT_MASK        = 16b
    [MCU2_0]     85.096244 s: SUPER            = 0
    [MCU2_0]     85.096270 s: MCAST IGNORE BITS= 0
    [MCU2_0]     85.096296 s: MCAST_FWD_STATE  = 0
    [MCU2_0]     85.096321 s: ENTRY_TYPE       = 1
    [MCU2_0]     85.096347 s: MULTICAST_ADDR   = 3333 fb
    [MCU2_0]     85.096378 s: ---------------------------------------------
    [MCU2_0]     85.096408 s:  Entry 25 - Multicast
    [MCU2_0]     85.096434 s: ---------------------------------------------
    [MCU2_0]     85.096464 s: PORT_MASK        = 16b
    [MCU2_0]     85.096491 s: SUPER            = 0
    [MCU2_0]     85.096516 s: MCAST IGNORE BITS= 0
    [MCU2_0]     85.096542 s: MCAST_FWD_STATE  = 0
    [MCU2_0]     85.096568 s: ENTRY_TYPE       = 1
    [MCU2_0]     85.096593 s: MULTICAST_ADDR   = 100 5e0000fb
    [MCU2_0]     85.096626 s: ---------------------------------------------
    [MCU2_0]     85.096656 s:  Entry 26 - Multicast
    [MCU2_0]     85.096682 s: ---------------------------------------------
    [MCU2_0]     85.096713 s: PORT_MASK        = 16b
    [MCU2_0]     85.096739 s: SUPER            = 0
    [MCU2_0]     85.096765 s: MCAST IGNORE BITS= 0
    [MCU2_0]     85.096791 s: MCAST_FWD_STATE  = 0
    [MCU2_0]     85.096817 s: ENTRY_TYPE       = 1
    [MCU2_0]     85.096844 s: MULTICAST_ADDR   = 3333 10003
    [MCU2_0]     85.096878 s: ---------------------------------------------
    [MCU2_0]     85.096909 s:  Entry 27 - VLAN INNER
    [MCU2_0]     85.096935 s: ---------------------------------------------
    [MCU2_0]     85.096965 s: ENTRY_TYPE        = 2
    [MCU2_0]     85.096990 s: IVLAN_ID           = 50
    [MCU2_0]     85.097017 s: NO FRAG           = 0
    [MCU2_0]     85.097043 s: REG_MCAST_FLOOD   = 511
    [MCU2_0]     85.097116 s: VLAN FWD Untagged Egress = 256
    [MCU2_0]     85.097152 s: LMT NEXT HDR      = 0
    [MCU2_0]     85.097182 s: UNREG_MCAST_FLOOD = 511
    [MCU2_0]     85.097211 s: VLAN_MEMBER_LIST  = 33
    [MCU2_0]     85.098157 s: Completed analysis of 1024 ALE entries
    [MCU2_0]     85.098206 s: HIRAIN_CMD_CPSW9G_ALE_PRINT exec end!
    这是我打印的表单的代码
    #define CPSW_9G_PORT_NUM        8
    #define CPSW_2G_PORT_NUM        1
    #define WR_MEM_32(addr, data)   *(uint32_t*)(addr) = (uint32_t)(data)
    #define RD_MEM_32(addr)         *(uint32_t*)(addr)
    #include <ethremotecfg/server/include/cpsw_proxy_mac.h>
    #include <ctype.h>
    #include <stdarg.h>
    #include <stdint.h>
    #include <stdio.h>
    #include <stdlib.h>
    #define MEMORY "/dev/mem"
    #define MAIN_CTRLMMR_ENET0_CTRL         (0x00104044)
    #define CPSW_RGMII_ID_ENABLED     (0U)
    #define CPSW_RGMII_ID_DISABLED    (1U)
    #define BOARD_CPSW9G_PORT0_MAC_MODE (CPSW_MAC_MODE_RGMII)
    #define BOARD_CPSW9G_PORT0_RGMII_ID (CPSW_RGMII_ID_DISABLED)
    #define BOARD_CPSW9G_PORT1_MAC_MODE (CPSW_MAC_MODE_RGMII)
    #define BOARD_CPSW9G_PORT1_RGMII_ID (CPSW_RGMII_ID_DISABLED)
    #define BOARD_CPSW9G_PORT2_MAC_MODE (CPSW_MAC_MODE_RGMII)
    #define BOARD_CPSW9G_PORT2_RGMII_ID (CPSW_RGMII_ID_DISABLED)
    #define BOARD_CPSW9G_PORT3_MAC_MODE (CPSW_MAC_MODE_RGMII)
    #define BOARD_CPSW9G_PORT3_RGMII_ID (CPSW_RGMII_ID_DISABLED)
    #define BOARD_CPSW9G_PORT7_MAC_MODE (CPSW_MAC_MODE_RMII)
    #define CPSW_MAC_MODE_GMII       (0U)
    #define CPSW_MAC_MODE_RMII       (1U)
    #define CPSW_MAC_MODE_RGMII      (2U)
    #define CPSW_MAC_MODE_SGMII      (3U)
    #define CPSW_MAC_MODE_QSGMII     (4U)
    #define CPSW_MAC_MODE_QSGMII_SUB (6U)
    #define CPSW_2G_MAC_PORT_NUM         (1U)
    #define CPSW_5G_MAC_PORT_NUM         (4U)
    #define CPSW_9G_MAC_PORT_NUM         (8U)
    #define ALE_TBLCTL_2G              0x4603E020
    #define ALE_TBLW2_2G               0x4603E034
    #define ALE_TBLW1_2G               0x4603E038
    #define ALE_TBLW0_2G               0x4603E03C
    #define ALE_TBLCTL_9G              0x0C03E020
    #define ALE_TBLW2_9G               0x0C03E034
    #define ALE_TBLW1_9G               0x0C03E038
    #define ALE_TBLW0_9G               0x0C03E03C
    #define ALE_TABLE_DEPTH_2G         64
    #define ALE_TABLE_DEPTH_5G         512
    #define ALE_TABLE_DEPTH_9G         1024
    #define ALE_ENTRY_EMTPY         0x0
    #define ALE_ENTRY_ADDR          0x1
    #define ALE_ENTRY_VLAN          0x2
    #define ALE_ENTRY_VLAN_ADDR     0x3
    #define CPSW5G_BASE_ADDR                            (0x0C000000)
    #define CPSW9G_BASE_ADDR                            (0x0C000000)
    #define CPSW2G_BASE_ADDR                            (0x46000000)
    #define CSL_CPSW_NU_CPSW_NU_ETH_PN_MAC_CONTROL_REG                      (0x00022330U)
    #define CSL_CPSW_NU_CPSW_NU_ETH_PN_MAC_STATUS_REG                       (0x00022334U)
    /*! Macro to get bit at given bit position  */
    #define ENET_GET_BIT(val, n)            ((val & (1 << n)) >> n)
    int      fd;
    unsigned page_size, mapped_size, offset_in_page;
    void *   map_base, *virt_addr;
    int      fd;
    void cpsw_addr_read(uint32_t addr)
        int regVal = RD_MEM_32(addr);
        appLogPrintf("Read address:0x%X <-------> value:0x%08X\n", addr, regVal);
    int mdio_addr_read(uint32_t addr)
        int regVal = (int)RD_MEM_32(addr);
        return regVal;
    int mdio_addr_read_noprint(uint32_t addr)
        return regVal;
    void cpsw_addr_write_noprint(uint32_t addr, uint32_t value)
        WR_MEM_32(addr, value);
    void cpsw_addr_write(uint32_t addr, uint32_t value)
        appLogPrintf("You will write address:0x%X -------> value:0x%08X\n", addr, value);
        uint32_t regVal = RD_MEM_32(addr);
        if(regVal == value)
            appLogPrintf("Write Success!Read address:0x%X -------> value:0x%08X\n",addr, regVal);
        else
            appLogPrintf("Write Failed!Read address:0x%X -------> value:0x%08X\n",addr, regVal);
    void cpsw_print_stat_with_index_nonzero(char* regName, uint32_t portnum, uint32_t regIdx, uint32_t regAddr)
        uint32_t regVal = RD_MEM_32(regAddr);
        if (0 != regVal)
                appLogPrintf("STAT_%d_%s[%d](RegAddr:0x%08X)= 0x%X\n",portnum, regName, regIdx, regAddr, regVal);
    void cpsw_print_stat_nonzero(char* regName, uint32_t portnum, uint32_t regAddr)
        if (0 != regVal)
                appLogPrintf("STAT_%d_%s(RegAddr:0x%08X)= 0x%X\n",portnum, regName, regAddr, regVal);
    void Cpsw_ng_PrintMACCfg_local(int portBaseAddr, int cpsw2gFlag)
        int macCtrl, macStatus;
        macCtrl   = mdio_addr_read(portBaseAddr + CSL_CPSW_NU_CPSW_NU_ETH_PN_MAC_CONTROL_REG);
        macStatus = mdio_addr_read(portBaseAddr + CSL_CPSW_NU_CPSW_NU_ETH_PN_MAC_STATUS_REG);
        appLogPrintf("MAC Control \n");
        appLogPrintf(" FULLDUPLEX          = %d \n", ENET_GET_BIT(macCtrl, 0U));
        appLogPrintf(" LOOPBACK            = %d \n", ENET_GET_BIT(macCtrl, 1U));
        appLogPrintf(" MTEST               = %d \n", ENET_GET_BIT(macCtrl, 2U));
        appLogPrintf(" RX_FLOW_EN          = %d \n", ENET_GET_BIT(macCtrl, 3U));
        appLogPrintf(" TX_FLOW_EN          = %d \n", ENET_GET_BIT(macCtrl, 4U));
        appLogPrintf(" GMII_EN             = %d \n", ENET_GET_BIT(macCtrl, 5U));
        appLogPrintf(" TX_PACE             = %d \n", ENET_GET_BIT(macCtrl, 6U));
        appLogPrintf(" GIG                 = %d \n", ENET_GET_BIT(macCtrl, 7U));
        if (0U == cpsw2gFlag)
            appLogPrintf(" XGIG                 = %d \n", ENET_GET_BIT(macCtrl, 8U));
        appLogPrintf(" TX_SHORT_GAP_ENABLE = %d \n", ENET_GET_BIT(macCtrl, 10U));
        appLogPrintf(" CMD_IDLE            = %d \n", ENET_GET_BIT(macCtrl, 11U));
        appLogPrintf(" CRC_TYPE            = %d \n", ENET_GET_BIT(macCtrl, 12U));
            appLogPrintf(" XGMII EN            = %d \n", ENET_GET_BIT(macCtrl, 13U));
        appLogPrintf(" IFCTL_A             = %d \n", ENET_GET_BIT(macCtrl, 15U));
        appLogPrintf(" IFCTL_B             = %d \n", ENET_GET_BIT(macCtrl, 16U));
        appLogPrintf(" GIG_FORCE           = %d \n", ENET_GET_BIT(macCtrl, 17U));
        appLogPrintf(" EXT CTL_EN          = %d \n", ENET_GET_BIT(macCtrl, 18U));
        appLogPrintf(" EXT_RX_FLOW_EN      = %d \n", ENET_GET_BIT(macCtrl, 19U));
        appLogPrintf(" EXT_TX_FLOW_EN      = %d \n", ENET_GET_BIT(macCtrl, 20U));
        appLogPrintf(" TX_SHORT_GAP_LIM_EN = %d \n", ENET_GET_BIT(macCtrl, 21U));
        appLogPrintf(" RX_CEF_EN           = %d \n", ENET_GET_BIT(macCtrl, 22U));
        appLogPrintf(" RX_CSF_EN           = %d \n", ENET_GET_BIT(macCtrl, 23U));
        appLogPrintf(" RX_CMF_EN           = %d \n", ENET_GET_BIT(macCtrl, 24U));
            appLogPrintf(" EXT_EN_XGIG         = %d \n", ENET_GET_BIT(macCtrl, 25U));
        /* PN_MAC_STATUS_REG */
        appLogPrintf("MAC Status \n");
        appLogPrintf(" TX_FLOW_ACT     = %d \n", ENET_GET_BIT(macStatus, 0U));
        appLogPrintf(" RX_FLOW_ACT     = %d \n", ENET_GET_BIT(macStatus, 1U));
        appLogPrintf(" EXT_FULLDUPLEX  = %d \n", ENET_GET_BIT(macStatus, 3U));
        appLogPrintf(" EXT_GIG         = %d \n", ENET_GET_BIT(macStatus, 4U));
        appLogPrintf(" EXT_TX_FLOW_EN  = %d \n", ENET_GET_BIT(macStatus, 5U));
        appLogPrintf(" EXT_RX_FLOW_EN  = %d \n", ENET_GET_BIT(macStatus, 6U));
        appLogPrintf(" RX_PFC_FLOW_ACT = %d \n", CSL_FEXTR(macStatus, 15, 8));
        appLogPrintf(" TX_PFC_FLOW_ACT = %d \n", CSL_FEXTR(macStatus, 23, 16));
        appLogPrintf(" TORF_PRI        = %d \n", CSL_FEXTR(macStatus, 26, 24));
        appLogPrintf(" TORF            = %d \n", ENET_GET_BIT(macStatus, 27U));
        appLogPrintf(" MAC_TX_IDLE     = %d \n", ENET_GET_BIT(macStatus, 28U));
        appLogPrintf(" P_IDLE          = %d \n", ENET_GET_BIT(macStatus, 29U));
        appLogPrintf(" E_IDLE          = %d \n", ENET_GET_BIT(macStatus, 30U));
        appLogPrintf(" IDLE            = %d \n", ENET_GET_BIT(macStatus, 31U));
    void cpsw_2g_statsprint_nonzero(void)
        uint32_t i, regAddr, portnum;
        appLogPrintf("          STATS          \n");
        portnum = 0;
        appLogPrintf("--------------------------------\n");
        appLogPrintf("          PORT%d STATS          \n",portnum);
        cpsw_print_stat_nonzero("RXGOODFRAMES              ", portnum, (0x4603A000U));
        cpsw_print_stat_nonzero("RXBROADCASTFRAMES         ", portnum, (0x4603A004U));
        cpsw_print_stat_nonzero("RXMULTICASTFRAMES         ", portnum, (0x4603A008U));
        cpsw_print_stat_nonzero("RXCRCERRORS               ", portnum, (0x4603A010U));
        cpsw_print_stat_nonzero("RXOVERSIZEDFRAMES         ", portnum, (0x4603A018U));
        cpsw_print_stat_nonzero("RXUNDERSIZEDFRAMES        ", portnum, (0x4603A020U));
        cpsw_print_stat_nonzero("RXFRAGMENTS               ", portnum, (0x4603A024U));
        cpsw_print_stat_nonzero("ALE_DROP                  ", portnum, (0x4603A028U));
        cpsw_print_stat_nonzero("ALE_OVERRUN_DROP          ", portnum, (0x4603A02CU));
        cpsw_print_stat_nonzero("RXOCTETS                  ", portnum, (0x4603A030U));
        cpsw_print_stat_nonzero("TXGOODFRAMES              ", portnum, (0x4603A034U));
        cpsw_print_stat_nonzero("TXBROADCASTFRAMES         ", portnum, (0x4603A038U));
        cpsw_print_stat_nonzero("TXMULTICASTFRAMES         ", portnum, (0x4603A03CU));
        cpsw_print_stat_nonzero("TXOCTETS                  ", portnum, (0x4603A064U));
        cpsw_print_stat_nonzero("OCTETFRAMES64             ", portnum, (0x4603A068U));
        cpsw_print_stat_nonzero("OCTETFRAMES65T127         ", portnum, (0x4603A06CU));
        cpsw_print_stat_nonzero("OCTETFRAMES128T255        ", portnum, (0x4603A070U));
        cpsw_print_stat_nonzero("OCTETFRAMES256T511        ", portnum, (0x4603A074U));
        cpsw_print_stat_nonzero("OCTETFRAMES512T1023       ", portnum, (0x4603A078U));
        cpsw_print_stat_nonzero("OCTETFRAMES1024TUP        ", portnum, (0x4603A07CU));
        cpsw_print_stat_nonzero("NETOCTETS                 ", portnum, (0x4603A080U));
        cpsw_print_stat_nonzero("RX_BOTTOM_OF_FIFO_DROP    ", portnum, (0x4603A084U));
        cpsw_print_stat_nonzero("PORTMASK_DROP             ", portnum, (0x4603A088U));
        cpsw_print_stat_nonzero("RX_TOP_OF_FIFO_DROP       ", portnum, (0x4603A08CU));
        cpsw_print_stat_nonzero("ALE_RATE_LIMIT_DROP       ", portnum, (0x4603A090U));
        cpsw_print_stat_nonzero("ALE_VID_INGRESS_DROP      ", portnum, (0x4603A094U));
        cpsw_print_stat_nonzero("ALE_DA_EQ_SA_DROP         ", portnum, (0x4603A098U));
        cpsw_print_stat_nonzero("ALE_BLOCK_DROP            ", portnum, (0x4603A09CU));
        cpsw_print_stat_nonzero("ALE_SECURE_DROP           ", portnum, (0x4603A0A0U));
        cpsw_print_stat_nonzero("ALE_AUTH_DROP             ", portnum, (0x4603A0A4U));
        cpsw_print_stat_nonzero("ALE_UNKN_UNI              ", portnum, (0x4603A0A8U));
        cpsw_print_stat_nonzero("ALE_UNKN_UNI_BCNT         ", portnum, (0x4603A0ACU));
        cpsw_print_stat_nonzero("ALE_UNKN_MLT              ", portnum, (0x4603A0B0U));
        cpsw_print_stat_nonzero("ALE_UNKN_MLT_BCNT         ", portnum, (0x4603A0B4U));
        cpsw_print_stat_nonzero("ALE_UNKN_BRD              ", portnum, (0x4603A0B8U));
        cpsw_print_stat_nonzero("ALE_UNKN_BRD_BCNT         ", portnum, (0x4603A0BCU));
        cpsw_print_stat_nonzero("ALE_POL_MATCH             ", portnum, (0x4603A0C0U));
        cpsw_print_stat_nonzero("ALE_POL_MATCH_RED         ", portnum, (0x4603A0C4U));
        cpsw_print_stat_nonzero("ALE_POL_MATCH_YELLOW      ", portnum, (0x4603A0C8U));
        cpsw_print_stat_nonzero("TX_MEMORY_PROTECT_ERROR   ", portnum, (0x4603A17CU));
        portnum = 1;
        cpsw_print_stat_nonzero("RXGOODFRAMES              ", portnum, (0x4603A200U));
        cpsw_print_stat_nonzero("RXBROADCASTFRAMES         ", portnum, (0x4603A204U));
        cpsw_print_stat_nonzero("RXMULTICASTFRAMES         ", portnum, (0x4603A208U));
        cpsw_print_stat_nonzero("RXPAUSEFRAMES             ", portnum, (0x4603A20CU));
        cpsw_print_stat_nonzero("RXCRCERRORS               ", portnum, (0x4603A210U));
        cpsw_print_stat_nonzero("RXALIGNCODEERRORS         ", portnum, (0x4603A214U));
        cpsw_print_stat_nonzero("RXOVERSIZEDFRAMES         ", portnum, (0x4603A218U));
        cpsw_print_stat_nonzero("RXJABBERFRAMES            ", portnum, (0x4603A21CU));
        cpsw_print_stat_nonzero("RXUNDERSIZEDFRAMES        ", portnum, (0x4603A220U));
        cpsw_print_stat_nonzero("RXFRAGMENTS               ", portnum, (0x4603A224U));
        cpsw_print_stat_nonzero("ALE_DROP                  ", portnum, (0x4603A228U));
        cpsw_print_stat_nonzero("ALE_OVERRUN_DROP          ", portnum, (0x4603A22CU));
        cpsw_print_stat_nonzero("RXOCTETS                  ", portnum, (0x4603A230U));
        cpsw_print_stat_nonzero("TXGOODFRAMES              ", portnum, (0x4603A234U));
        cpsw_print_stat_nonzero("TXBROADCASTFRAMES         ", portnum, (0x4603A238U));
        cpsw_print_stat_nonzero("TXMULTICASTFRAMES         ", portnum, (0x4603A23CU));
        cpsw_print_stat_nonzero("TXPAUSEFRAMES             ", portnum, (0x4603A240U));
        cpsw_print_stat_nonzero("TXDEFERREDFRAMES          ", portnum, (0x4603A244U));
        cpsw_print_stat_nonzero("TXCOLLISIONFRAMES         ", portnum, (0x4603A248U));
        cpsw_print_stat_nonzero("TXSINGLECOLLFRAMES        ", portnum, (0x4603A24CU));
        cpsw_print_stat_nonzero("TXMULTCOLLFRAMES          ", portnum, (0x4603A250U));
        cpsw_print_stat_nonzero("TXEXCESSIVECOLLISIONS     ", portnum, (0x4603A254U));
        cpsw_print_stat_nonzero("TXLATECOLLISIONS          ", portnum, (0x4603A258U));
        cpsw_print_stat_nonzero("RXIPGERROR                ", portnum, (0x4603A25CU));
        cpsw_print_stat_nonzero("TXCARRIERSENSEERRORS      ", portnum, (0x4603A260U));
        cpsw_print_stat_nonzero("TXOCTETS                  ", portnum, (0x4603A264U));
        cpsw_print_stat_nonzero("OCTETFRAMES64             ", portnum, (0x4603A268U));
        cpsw_print_stat_nonzero("OCTETFRAMES65T127         ", portnum, (0x4603A26CU));
        cpsw_print_stat_nonzero("OCTETFRAMES128T255        ", portnum, (0x4603A270U));
        cpsw_print_stat_nonzero("OCTETFRAMES256T511        ", portnum, (0x4603A274U));
        cpsw_print_stat_nonzero("OCTETFRAMES512T1023       ", portnum, (0x4603A278U));
        cpsw_print_stat_nonzero("OCTETFRAMES1024TUP        ", portnum, (0x4603A27CU));
        cpsw_print_stat_nonzero("NETOCTETS                 ", portnum, (0x4603A280U));
        cpsw_print_stat_nonzero("RX_BOTTOM_OF_FIFO_DROP    ", portnum, (0x4603A284U));
        cpsw_print_stat_nonzero("PORTMASK_DROP             ", portnum, (0x4603A288U));
        cpsw_print_stat_nonzero("RX_TOP_OF_FIFO_DROP       ", portnum, (0x4603A28CU));
        cpsw_print_stat_nonzero("ALE_RATE_LIMIT_DROP       ", portnum, (0x4603A290U));
        cpsw_print_stat_nonzero("ALE_VID_INGRESS_DROP      ", portnum, (0x4603A294U));
        cpsw_print_stat_nonzero("ALE_DA_EQ_SA_DROP         ", portnum, (0x4603A298U));
        cpsw_print_stat_nonzero("ALE_BLOCK_DROP            ", portnum, (0x4603A29CU));
        cpsw_print_stat_nonzero("ALE_SECURE_DROP           ", portnum, (0x4603A2A0U));
        cpsw_print_stat_nonzero("ALE_AUTH_DROP             ", portnum, (0x4603A2A4U));
        cpsw_print_stat_nonzero("ALE_UNKN_UNI              ", portnum, (0x4603A2A8U));
        cpsw_print_stat_nonzero("ALE_UNKN_UNI_BCNT         ", portnum, (0x4603A2ACU));
        cpsw_print_stat_nonzero("ALE_UNKN_MLT              ", portnum, (0x4603A2B0U));
        cpsw_print_stat_nonzero("ALE_UNKN_MLT_BCNT         ", portnum, (0x4603A2B4U));
        cpsw_print_stat_nonzero("ALE_UNKN_BRD              ", portnum, (0x4603A2B8U));
        cpsw_print_stat_nonzero("ALE_UNKN_BRD_BCNT         ", portnum, (0x4603A2BCU));
        cpsw_print_stat_nonzero("ALE_POL_MATCH             ", portnum, (0x4603A2C0U));
        cpsw_print_stat_nonzero("ALE_POL_MATCH_RED         ", portnum, (0x4603A2C4U));
        cpsw_print_stat_nonzero("ALE_POL_MATCH_YELLOW      ", portnum, (0x4603A2C8U));
        cpsw_print_stat_nonzero("TX_MEMORY_PROTECT_ERROR   ", portnum, (0x4603A37CU));
        for (i = 0; i < 8; i++)
            regAddr = 0x4603A380U + (i * 0x4U);
            cpsw_print_stat_with_index_nonzero("TX_PRI_REG             ", portnum, i, regAddr);
            regAddr = 0x4603A3A0U + (i * 0x4U);
            cpsw_print_stat_with_index_nonzero("TX_PRI_BCNT_REG        ", portnum, i, regAddr);
            regAddr = 0x4603A3C0U + (i * 0x4U);
            cpsw_print_stat_with_index_nonzero("TX_PRI_DROP_REG        ", portnum, i, regAddr);
            regAddr = 0x4603A3E0U + (i * 0x4U);
            cpsw_print_stat_with_index_nonzero("TX_PRI_DROP_BCNT_REG   ", portnum, i, regAddr);
    int Cpsw_getMacMod(int enetCtrl)
        return (enetCtrl & 0x7);
    int Cpsw_getRgmiiId(int enetCtrl)
        return ((enetCtrl >> 4) & 0x1);
    char* Cpsw_printMacMode(int mode)
        if (CPSW_MAC_MODE_GMII == mode)
            return("Mode: GMII");
        else if (CPSW_MAC_MODE_RMII == mode)
            return("Mode: RMII");
        else if (CPSW_MAC_MODE_RGMII == mode)
            return("Mode: RGMII");
        else if (CPSW_MAC_MODE_SGMII == mode)
            return("Mode: SGMII");
        else if (CPSW_MAC_MODE_QSGMII == mode)
            return("Mode: QSGMII");
        else if (CPSW_MAC_MODE_QSGMII_SUB == mode)
            return("Mode: QSGMII_SUB");
        else
            return("ERROR!");
    char* Cpsw_printRgmiiIdCfg(int rgmiiIdVal)
        if (CPSW_RGMII_ID_DISABLED == rgmiiIdVal)
            return ("RGMII-ID:Disabled");
        else
            return("RGMII-ID:Enabled");
    void Cpsw_matchEnetCntlCfg(int expMacMode,
                           int currMacMode,
                           int expRgmiiId,
                           int currRgmiiId)
        if (expMacMode == currMacMode)
            if ((expMacMode == CPSW_MAC_MODE_RGMII) && (expRgmiiId == currRgmiiId))
               appLogPrintf("   Config Matches\n");
            else
        else
            if (expMacMode != currMacMode)
               appLogPrintf("   ERROR: Expected: %s, Actual: %s \n",
                                Cpsw_printMacMode(expMacMode), Cpsw_printMacMode(currMacMode));
            if ((expRgmiiId != currRgmiiId) && (expMacMode == CPSW_MAC_MODE_RGMII))
                              Cpsw_printRgmiiIdCfg(expRgmiiId),
                              Cpsw_printRgmiiIdCfg(currRgmiiId));
    void Cpsw_printCfg(int portNum, int mode, int rgmiiIdVal)
        if (2U == mode)
            appLogPrintf("Port %d: %s, %s \n",
                    portNum, Cpsw_printMacMode(mode), Cpsw_printRgmiiIdCfg(rgmiiIdVal));
        else
            appLogPrintf("Port %d: %s\n",portNum, Cpsw_printMacMode(mode));
    void show_ale_entry_multicast_2g(uint32_t index, uint32_t word0, uint32_t word1, uint32_t word2)
        appLogPrintf("---------------------------------------------\n");
        appLogPrintf(" Entry %u - Multicast\n", index);
        appLogPrintf("PORT_MASK        = %x\n", (word2 >>  2) & 0x1FF);
        appLogPrintf("SUPER            = %u\n", (word2 >>  1) & 0x1);
        appLogPrintf("MCAST_FWD_STATE  = %u\n", (word1 >> 30) & 0x3);
        appLogPrintf("ENTRY_TYPE       = %u\n", (word1 >> 28) & 0x3);
        appLogPrintf("MULTICAST_ADDR   = %x %x\n", (word1 >>  0) & 0xFFFF, word0);
    void show_ale_entry_multicast_9g(uint32_t index, uint32_t word0, uint32_t word1, uint32_t word2)
        appLogPrintf("MCAST IGNORE BITS= %u\n", (word2 >>  0) & 0x1);
    void show_ale_entry_vlan_multicast_2g(uint32_t index, uint32_t word0, uint32_t word1, uint32_t word2)
        appLogPrintf(" Entry %u - VLAN/Multicast\n", index);
        appLogPrintf("VLAN_ID          = %u\n", (word1 >> 16) & 0xFFF);
    void show_ale_entry_vlan_multicast_9g(uint32_t index, uint32_t word0, uint32_t word1, uint32_t word2)
    void show_ale_entry_unicast_2g(uint32_t index, uint32_t word0, uint32_t word1, uint32_t word2)
        appLogPrintf(" Entry %u - Unicast\n", index);
        appLogPrintf("PORT_NUMBER      = %u\n", (word2 >>  2) & 0x1FF);
        appLogPrintf("BLOCK            = %u\n", (word2 >>  1) & 0x1);
        appLogPrintf("SECURE           = %u\n", (word2 >>  0) & 0x1);
        appLogPrintf("UNICAST_TYPE     = %u\n", (word1 >> 30) & 0x3);
        appLogPrintf("UNICAST_ADDR     = %x %x\n", (word1 >>  0) & 0xFFFF, word0);
    void show_ale_entry_unicast_9g(uint32_t index, uint32_t word0, uint32_t word1, uint32_t word2)
        appLogPrintf("TRUNK            = %u\n", (word2 >> 10) & 0x1);
        appLogPrintf("PORT_NUMBER      = %u\n", (word2 >> 2) & 0xF);
        appLogPrintf("TOUCH            = %u\n", (word1 >> 31) & 0x1);
        appLogPrintf("AGEABLE          = %u\n", (word1 >> 30) & 0x1);
    void show_ale_entry_oui_unicast_2g(uint32_t index, uint32_t word0, uint32_t word1, uint32_t word2)
        appLogPrintf(" Entry %u - OUI Unicast\n", index);
        appLogPrintf("UNICAST_OUI      = %x %x\n", (word1 >>  0) & 0xFFFF, (word0 >> 24) & 0xFF);
    void show_ale_entry_oui_unicast_9g(uint32_t index, uint32_t word0, uint32_t word1, uint32_t word2)
    void show_ale_entry_vlan_unicast_2g(uint32_t index, uint32_t word0, uint32_t word1, uint32_t word2)
        appLogPrintf(" Entry %u - VLAN/Unicast\n", index);
    void show_ale_entry_vlan_unicast_9g(uint32_t index, uint32_t word0, uint32_t word1, uint32_t word2)
    void show_ale_entry_vlan_2g(uint32_t index, uint32_t word0, uint32_t word1, uint32_t word2)
        appLogPrintf(" Entry %u - VLAN\n", index);
        appLogPrintf("FORCE_UNTAG_EG    = %u\n", (word0 >> 24) & 0x1FF);
        appLogPrintf("REG_MCAST_FLOOD   = %u\n", (word0 >> 16) & 0x1FF);
        appLogPrintf("UNREG_MCAST_FLOOD = %u\n", (word0 >>  8) & 0x1FF);
        appLogPrintf("VLAN_MEMBER_LIST  = %u\n", (word0 >>  0) & 0x1FF);
    void show_ale_entry_vlan_inner_9g(uint32_t index, uint32_t word0, uint32_t word1, uint32_t word2)
        appLogPrintf(" Entry %u - VLAN INNER \n", index);
        appLogPrintf("IVLAN_ID           = %u\n", (word1 >> 16) & 0xFFF);
        appLogPrintf("NO FRAG           = %u\n", (word1 >> 15) & 0x1);
        appLogPrintf("REG_MCAST_FLOOD   = %u\n", (word1 >> 4) & 0x1FF);
        appLogPrintf("VLAN FWD Untagged Egress = %u\n",
                                    ((word1 >> 0U) & 0x100) + (word0 >> 24) & 0x1FF);
        appLogPrintf("LMT NEXT HDR      = %u\n", (word0 >> 23) & 0x1);
        appLogPrintf("UNREG_MCAST_FLOOD = %u\n", (word0 >> 12) & 0x1FF);
    void show_ale_entry_vlan_outer_9g(uint32_t index, uint32_t word0, uint32_t word1, uint32_t word2)
        appLogPrintf(" Entry %u - VLAN OUTER\n", index);
        appLogPrintf("OVLAN_ID           = %u\n", (word1 >> 16) & 0xFFF);
    void show_ale_entry_vlan_ethertype_9g(uint32_t index, uint32_t word0, uint32_t word1, uint32_t word2)
        appLogPrintf(" Entry %u - VLAN ETHERTYPE \n", index);
        appLogPrintf("ETHERTYPE  = %u\n", (word0 >>  0) & 0xFFFF);
    void show_ale_entry_vlan_ip4_9g(uint32_t index, uint32_t word0, uint32_t word1, uint32_t word2)
        appLogPrintf(" Entry %u - VLAN IPV4 \n", index);
        appLogPrintf("IGNORE BITS       = %u\n", (word2 >> 1) & 0x1F);
        appLogPrintf("IPV4 ADDR  = %u\n", word0);
    void show_ale_entry_vlan_ip6_9g(uint32_t index, uint32_t word0, uint32_t word1, uint32_t word2)
        appLogPrintf(" Entry %u - VLAN IPV6 \n", index);
        appLogPrintf("Understanding Gap hence not printing :(");
    void cpsw_print_ale_table_2g()
        uint32_t word0, word1, word2;
        uint32_t type;
        int i;
        appLogPrintf("-------CPSW2G ALE TABLE----------------------\n");
        for (i = 0; i < ALE_TABLE_DEPTH_2G; i++)
            cpsw_addr_write_noprint(ALE_TBLCTL_2G, i);
            word0 = mdio_addr_read_noprint(ALE_TBLW0_2G);
            word1 = mdio_addr_read_noprint(ALE_TBLW1_2G);
            word2 = mdio_addr_read_noprint(ALE_TBLW2_2G);
            if (0)
                appLogPrintf("WORD1  = %u\n", word0);
                appLogPrintf("WORD1  = %u\n", word1);
                appLogPrintf("WORD1  = %u\n", word2);
            /* ENTRY_TYPE (bits 61:60) */
            type = (word1 >> 28) & 0x3;
            if (type == ALE_ENTRY_EMTPY) {
                //appLogPrintf(" Entry %u - Empty\n", i);
            } else if (type == ALE_ENTRY_ADDR) {
                if ((word1 >> 8) & 0x1) {
                    show_ale_entry_multicast_2g(i, word0, word1, word2);
    //            } else if ((word1 >> 30) & 0x3) {
    //                show_ale_entry_oui_unicast(i, word0, word1, word2);
                } else {
                    show_ale_entry_unicast_2g(i, word0, word1, word2);
            } else if (type == ALE_ENTRY_VLAN) {
                show_ale_entry_vlan_2g(i, word0, word1, word2);
            } else if (type == ALE_ENTRY_VLAN_ADDR) {
                    show_ale_entry_vlan_multicast_2g(i, word0, word1, word2);
                } else {
                    show_ale_entry_vlan_unicast_2g(i, word0, word1, word2);
        appLogPrintf("Completed analysis of %u ALE entries\n", i);
    void cpsw_print_ale_table_ng(int numAleEntries)
        uint32_t type;
        uint32_t vlanEntryType;
        int i;
        appLogPrintf("-------CPSWnG ALE TABLE----------------------\n");
        for (i = 0; i < numAleEntries; i++)
            cpsw_addr_write_noprint(ALE_TBLCTL_9G, i);
            word0 = mdio_addr_read_noprint(ALE_TBLW0_9G);
            word1 = mdio_addr_read_noprint(ALE_TBLW1_9G);
            word2 = mdio_addr_read_noprint(ALE_TBLW2_9G);
            if (0)
                appLogPrintf("WORD0  = %x\n", word0);
                appLogPrintf("WORD1  = %x\n", word1);
                appLogPrintf("WORD2  = %x\n", word2);
                    show_ale_entry_multicast_9g(i, word0, word1, word2);
                else if ( ((word1 >> 30) & 0x3) == 0x2 )
                   show_ale_entry_oui_unicast_9g(i, word0, word1, word2);
                else
                    show_ale_entry_unicast_9g(i, word0, word1, word2);
                vlanEntryType = ((word1 >> 30) & 0x3);
                vlanEntryType |= ((word2 >> 0) & 0x1);
                if ( 0x0 == vlanEntryType)
                    show_ale_entry_vlan_inner_9g(i, word0, word1, word2);
                else if ( 0x2 == vlanEntryType)
                    show_ale_entry_vlan_outer_9g(i, word0, word1, word2);
                else if ( 0x4 == vlanEntryType)
                    show_ale_entry_vlan_ethertype_9g(i, word0, word1, word2);
                else if ( 0x6 == vlanEntryType )
                    show_ale_entry_vlan_ip4_9g(i, word0, word1, word2);
                else if ((word1 >> 30) & 0x1)
                    show_ale_entry_vlan_ip6_9g(i, word0, word1, word2);
                    show_ale_entry_vlan_multicast_9g(i, word0, word1, word2);
                else {
                    show_ale_entry_vlan_unicast_9g(i, word0, word1, word2);
    void cpsw_print_ale_table_9g()
        cpsw_print_ale_table_ng(ALE_TABLE_DEPTH_9G);
    void cpsw_9g_statsprint_nonzero(void)
        uint32_t baseAddr;
        uint32_t numMacPorts = CPSW_9G_PORT_NUM;
        portnum = 0;
        cpsw_print_stat_nonzero("RXGOODFRAMES              ", portnum, (0x0C03A000U));
        cpsw_print_stat_nonzero("RXBROADCASTFRAMES         ", portnum, (0x0C03A004U));
        cpsw_print_stat_nonzero("RXMULTICASTFRAMES         ", portnum, (0x0C03A008U));
        cpsw_print_stat_nonzero("RXCRCERRORS               ", portnum, (0x0C03A010U));
        cpsw_print_stat_nonzero("RXOVERSIZEDFRAMES         ", portnum, (0x0C03A018U));
        cpsw_print_stat_nonzero("RXUNDERSIZEDFRAMES        ", portnum, (0x0C03A020U));
        cpsw_print_stat_nonzero("RXFRAGMENTS               ", portnum, (0x0C03A024U));
        cpsw_print_stat_nonzero("ALE_DROP                  ", portnum, (0x0C03A028U));
        cpsw_print_stat_nonzero("ALE_OVERRUN_DROP          ", portnum, (0x0C03A02CU));
        cpsw_print_stat_nonzero("RXOCTETS                  ", portnum, (0x0C03A030U));
        cpsw_print_stat_nonzero("TXGOODFRAMES              ", portnum, (0x0C03A034U));
        cpsw_print_stat_nonzero("TXBROADCASTFRAMES         ", portnum, (0x0C03A038U));
        cpsw_print_stat_nonzero("TXMULTICASTFRAMES         ", portnum, (0x0C03A03CU));
        cpsw_print_stat_nonzero("TXOCTETS                  ", portnum, (0x0C03A064U));
        cpsw_print_stat_nonzero("OCTETFRAMES64             ", portnum, (0x0C03A068U));
        cpsw_print_stat_nonzero("OCTETFRAMES65T127         ", portnum, (0x0C03A06CU));
        cpsw_print_stat_nonzero("OCTETFRAMES128T255        ", portnum, (0x0C03A070U));
        cpsw_print_stat_nonzero("OCTETFRAMES256T511        ", portnum, (0x0C03A074U));
        cpsw_print_stat_nonzero("OCTETFRAMES512T1023       ", portnum, (0x0C03A078U));
        cpsw_print_stat_nonzero("OCTETFRAMES1024TUP        ", portnum, (0x0C03A07CU));
        cpsw_print_stat_nonzero("NETOCTETS                 ", portnum, (0x0C03A080U));
        cpsw_print_stat_nonzero("RX_BOTTOM_OF_FIFO_DROP    ", portnum, (0x0C03A084U));
        cpsw_print_stat_nonzero("PORTMASK_DROP             ", portnum, (0x0C03A088U));
        cpsw_print_stat_nonzero("RX_TOP_OF_FIFO_DROP       ", portnum, (0x0C03A08CU));
        cpsw_print_stat_nonzero("ALE_RATE_LIMIT_DROP       ", portnum, (0x0C03A090U));
        cpsw_print_stat_nonzero("ALE_VID_INGRESS_DROP      ", portnum, (0x0C03A094U));
        cpsw_print_stat_nonzero("ALE_DA_EQ_SA_DROP         ", portnum, (0x0C03A098U));
        cpsw_print_stat_nonzero("ALE_BLOCK_DROP            ", portnum, (0x0C03A09CU));
        cpsw_print_stat_nonzero("ALE_SECURE_DROP           ", portnum, (0x0C03A0A0U));
        cpsw_print_stat_nonzero("ALE_AUTH_DROP             ", portnum, (0x0C03A0A4U));
        cpsw_print_stat_nonzero("ALE_UNKN_UNI              ", portnum, (0x0C03A0A8U));
        cpsw_print_stat_nonzero("ALE_UNKN_UNI_BCNT         ", portnum, (0x0C03A0ACU));
        cpsw_print_stat_nonzero("ALE_UNKN_MLT              ", portnum, (0x0C03A0B0U));
        cpsw_print_stat_nonzero("ALE_UNKN_MLT_BCNT         ", portnum, (0x0C03A0B4U));
        cpsw_print_stat_nonzero("ALE_UNKN_BRD              ", portnum, (0x0C03A0B8U));
        cpsw_print_stat_nonzero("ALE_UNKN_BRD_BCNT         ", portnum, (0x0C03A0BCU));
        cpsw_print_stat_nonzero("ALE_POL_MATCH             ", portnum, (0x0C03A0C0U));
        cpsw_print_stat_nonzero("ALE_POL_MATCH_RED         ", portnum, (0x0C03A0C4U));
        cpsw_print_stat_nonzero("ALE_POL_MATCH_YELLOW      ", portnum, (0x0C03A0C8U));
        cpsw_print_stat_nonzero("TX_MEMORY_PROTECT_ERROR   ", portnum, (0x0C03A17CU));
            regAddr = 0x0C03A180U + (i * 0x4U);
            regAddr = 0x0C03A1A0U + (i * 0x4U);
            regAddr = 0x0C03A1C0U + (i * 0x4U);
            regAddr = 0x0C03A1E0U + (i * 0x4U);
        for (portnum = 1; portnum <= numMacPorts; portnum++)
            baseAddr = 0x0C03A200U + ((portnum-1) * 0x200);
            cpsw_print_stat_nonzero("RXGOODFRAMES              ", portnum, (baseAddr));
            cpsw_print_stat_nonzero("RXBROADCASTFRAMES         ", portnum, (baseAddr + 0x4U));
            cpsw_print_stat_nonzero("RXMULTICASTFRAMES         ", portnum, (baseAddr + 0x8U));
            cpsw_print_stat_nonzero("RXPAUSEFRAMES             ", portnum, (baseAddr + 0xCU));
            cpsw_print_stat_nonzero("RXCRCERRORS               ", portnum, (baseAddr + 0x10U));
            cpsw_print_stat_nonzero("RXALIGNCODEERRORS         ", portnum, (baseAddr + 0x14U));
            cpsw_print_stat_nonzero("RXOVERSIZEDFRAMES         ", portnum, (baseAddr + 0x18U));
            cpsw_print_stat_nonzero("RXJABBERFRAMES            ", portnum, (baseAddr + 0x1CU));
            cpsw_print_stat_nonzero("RXUNDERSIZEDFRAMES        ", portnum, (baseAddr + 0x20U));
            cpsw_print_stat_nonzero("RXFRAGMENTS               ", portnum, (baseAddr + 0x24U));
            cpsw_print_stat_nonzero("ALE_DROP                  ", portnum, (baseAddr + 0x28U));
            cpsw_print_stat_nonzero("ALE_OVERRUN_DROP          ", portnum, (baseAddr + 0x2CU));
            cpsw_print_stat_nonzero("RXOCTETS                  ", portnum, (baseAddr + 0x30U));
            cpsw_print_stat_nonzero("TXGOODFRAMES              ", portnum, (baseAddr + 0x34U));
            cpsw_print_stat_nonzero("TXBROADCASTFRAMES         ", portnum, (baseAddr + 0x38U));
            cpsw_print_stat_nonzero("TXMULTICASTFRAMES         ", portnum, (baseAddr + 0x3CU));
            cpsw_print_stat_nonzero("TXPAUSEFRAMES             ", portnum, (baseAddr + 0x40U));
            cpsw_print_stat_nonzero("TXDEFERREDFRAMES          ", portnum, (baseAddr + 0x44U));
            cpsw_print_stat_nonzero("TXCOLLISIONFRAMES         ", portnum, (baseAddr + 0x48U));
            cpsw_print_stat_nonzero("TXSINGLECOLLFRAMES        ", portnum, (baseAddr + 0x4CU));
            cpsw_print_stat_nonzero("TXMULTCOLLFRAMES          ", portnum, (baseAddr + 0x50U));
            cpsw_print_stat_nonzero("TXEXCESSIVECOLLISIONS     ", portnum, (baseAddr + 0x54U));
            cpsw_print_stat_nonzero("TXLATECOLLISIONS          ", portnum, (baseAddr + 0x58U));
            cpsw_print_stat_nonzero("RXIPGERROR                ", portnum, (baseAddr + 0x5CU));
            cpsw_print_stat_nonzero("TXCARRIERSENSEERRORS      ", portnum, (baseAddr + 0x60U));
            cpsw_print_stat_nonzero("TXOCTETS                  ", portnum, (baseAddr + 0x64U));
            cpsw_print_stat_nonzero("OCTETFRAMES64             ", portnum, (baseAddr + 0x68U));
            cpsw_print_stat_nonzero("OCTETFRAMES65T127         ", portnum, (baseAddr + 0x6CU));
            cpsw_print_stat_nonzero("OCTETFRAMES128T255        ", portnum, (baseAddr + 0x70U));
            cpsw_print_stat_nonzero("OCTETFRAMES256T511        ", portnum, (baseAddr + 0x74U));
            cpsw_print_stat_nonzero("OCTETFRAMES512T1023       ", portnum, (baseAddr + 0x78U));
            cpsw_print_stat_nonzero("OCTETFRAMES1024TUP        ", portnum, (baseAddr + 0x7CU));
            cpsw_print_stat_nonzero("NETOCTETS                 ", portnum, (baseAddr + 0x80U));
            cpsw_print_stat_nonzero("RX_BOTTOM_OF_FIFO_DROP    ", portnum, (baseAddr + 0x84U));
            cpsw_print_stat_nonzero("PORTMASK_DROP             ", portnum, (baseAddr + 0x88U));
            cpsw_print_stat_nonzero("RX_TOP_OF_FIFO_DROP       ", portnum, (baseAddr + 0x8CU));
            cpsw_print_stat_nonzero("ALE_RATE_LIMIT_DROP       ", portnum, (baseAddr + 0x90U));
            cpsw_print_stat_nonzero("ALE_VID_INGRESS_DROP      ", portnum, (baseAddr + 0x94U));
            cpsw_print_stat_nonzero("ALE_DA_EQ_SA_DROP         ", portnum, (baseAddr + 0x98U));
            cpsw_print_stat_nonzero("ALE_BLOCK_DROP            ", portnum, (baseAddr + 0x9CU));
            cpsw_print_stat_nonzero("ALE_SECURE_DROP           ", portnum, (baseAddr + 0xA0U));
            cpsw_print_stat_nonzero("ALE_AUTH_DROP             ", portnum, (baseAddr + 0xA4U));
            cpsw_print_stat_nonzero("ALE_UNKN_UNI              ", portnum, (baseAddr + 0xA8U));
            cpsw_print_stat_nonzero("ALE_UNKN_UNI_BCNT         ", portnum, (baseAddr + 0xACU));
            cpsw_print_stat_nonzero("ALE_UNKN_MLT              ", portnum, (baseAddr + 0xB0U));
            cpsw_print_stat_nonzero("ALE_UNKN_MLT_BCNT         ", portnum, (baseAddr + 0xB4U));
            cpsw_print_stat_nonzero("ALE_UNKN_BRD              ", portnum, (baseAddr + 0xB8U));
            cpsw_print_stat_nonzero("ALE_UNKN_BRD_BCNT         ", portnum, (baseAddr + 0xBCU));
            cpsw_print_stat_nonzero("ALE_POL_MATCH             ", portnum, (baseAddr + 0xC0U));
            cpsw_print_stat_nonzero("ALE_POL_MATCH_RED         ", portnum, (baseAddr + 0xC4U));
            cpsw_print_stat_nonzero("ALE_POL_MATCH_YELLOW      ", portnum, (baseAddr + 0xC8U));
            cpsw_print_stat_nonzero("TX_MEMORY_PROTECT_ERROR   ", portnum, (baseAddr + 0x17CU));
                regAddr = (baseAddr + 0x180U) + (i * 0x4U);
                regAddr = (baseAddr + 0x1A0U) + (i * 0x4U);
                regAddr = (baseAddr + 0x1C0U) + (i * 0x4U);
                regAddr = (baseAddr + 0x1E0U) + (i * 0x4U);
    void Cpsw9g_PrintEnetCtrl()
        int enetCtrl;
        int portNum;
       appLogPrintf("\n");
       appLogPrintf("==============================\n");
       appLogPrintf("     CPSW9G MAC Mode Config   \n");
        for (portNum = 0; portNum < CPSW_9G_PORT_NUM; portNum++)
            enetCtrl = mdio_addr_read(MAIN_CTRLMMR_ENET0_CTRL + (portNum * 0x04));
            Cpsw_printCfg(portNum, Cpsw_getMacMod(enetCtrl), Cpsw_getRgmiiId(enetCtrl));
    void Board_Cpsw9g_VerifyEnetCtrl()
        int currMacMode, currRgmiiId, enetCtrl, portNum;
            currMacMode = Cpsw_getMacMod(enetCtrl);
            currRgmiiId = Cpsw_getRgmiiId(enetCtrl);
           appLogPrintf("CPSW9G Port %d \n",portNum);
            if (0U == portNum)
                Cpsw_matchEnetCntlCfg(BOARD_CPSW9G_PORT0_MAC_MODE,
                                       currMacMode,
                                       BOARD_CPSW9G_PORT0_RGMII_ID,
                                       currRgmiiId);
            else if (1U == portNum)
                Cpsw_matchEnetCntlCfg(BOARD_CPSW9G_PORT1_MAC_MODE,
                                       currMacMode,
                                       BOARD_CPSW9G_PORT1_RGMII_ID,
                                       currRgmiiId);
            else if (2U == portNum)
                Cpsw_matchEnetCntlCfg(BOARD_CPSW9G_PORT2_MAC_MODE,
                                       currMacMode,
                                       BOARD_CPSW9G_PORT2_RGMII_ID,
                                       currRgmiiId);
            else if (3U == portNum)
                Cpsw_matchEnetCntlCfg(BOARD_CPSW9G_PORT3_MAC_MODE,
                                       currMacMode,
                                       BOARD_CPSW9G_PORT3_RGMII_ID,
                                       currRgmiiId);
            else if (7U == portNum)
                Cpsw_matchEnetCntlCfg(BOARD_CPSW9G_PORT7_MAC_MODE,
                                       currMacMode,
                                       0U, /* don't care */
                                       currRgmiiId);
            else
               appLogPrintf("   Not configured \n");
       appLogPrintf("\n");
    void Cpsw9g_PrintMACCfg()
        int portNum;
        int portBaseAddr;
        for (portNum = 1; portNum < CPSW_9G_MAC_PORT_NUM; portNum++)
            portBaseAddr = CPSW5G_BASE_ADDR + (portNum * 0x1000);
           appLogPrintf("CPSW5G Port %d \n",portNum);
            Cpsw_ng_PrintMACCfg_local(portBaseAddr, 0U);
    void cpsw_clear_stat(uint32_t  regAddr)
        WR_MEM_32(regAddr, regVal);
    void cpsw_2g_clear_stats(void)
        uint32_t portnum, baseAddr, numStats;
        for (portnum = 0; portnum <= CPSW_2G_PORT_NUM; portnum++)
            baseAddr = 0x4603A000U + (portnum * 0x200);
            appLogPrintf("Clearing stats for port[%d]\n",portnum);
            for (numStats = 0; numStats < 128U; numStats++)
                cpsw_clear_stat(baseAddr + (numStats*0x4));
        appLogPrintf("--------CLEARED ALL STATS-------\n");
    void cpsw_9g_clear_stats(void)
        uint32_t portnum, baseAddr, numStats, numMacPorts;
        for (portnum = 0; portnum <= numMacPorts; portnum++)
            baseAddr = 0x0C03A000U + (portnum * 0x200);
    这是我添加 PVID 的接口
    /*A72 -> R5F COMMAND*/
    int32_t HirainMainR5FRemoteServiceHandler(char *service_name, uint32_t cmd, void *prm, uint32_t prm_size, uint32_t flags)
        int32_t rtnVal = IPC_SOK;
        int32_t status = 0;
        int16_t log_index = 0;
        Enet_Handle hEnet;
        uint32_t *data = (uint32_t *)prm;
        prm_size = prm_size / 4;
        switch (cmd)
            case HIRAIN_CMD_CPSW2G_ALE_PRINT:
                cpsw_print_ale_table_2g();
                appLogPrintf("HIRAIN_CMD_CPSW2G_ALE_PRINT exec end!\n\n\n\n\n");
            break;
            case HIRAIN_CMD_CPSW9G_ALE_PRINT:
                cpsw_print_ale_table_9g();
                appLogPrintf("HIRAIN_CMD_CPSW9G_ALE_PRINT exec end!\n\n\n\n\n");
            break;
            case HIRAIN_CMD_CPSW9G_VLAN_TEST:
                if (5 != prm_size)
                    appLogPrintf("UnValid prm_size (cmd = %08x, prm_size = %d B\n", cmd, prm_size);
                    break;
                if (data[2] >= 9 || data[2] == 0)
                    appLogPrintf("UnValid Port Num (cmd = %08x, data[0] = %d B\n", cmd, data[2]);
                    break;
                uint32_t outArgs = 0;
                inArgs.vlanIdInfo.vlanId = (int16_t)data[1];
                inArgs.vlanMemberList = (1 << CPSW_ALE_MACPORT_TO_ALEPORT(data[2]-1));
                inArgs.unregMcastFloodMask = 0x0;
                inArgs.regMcastFloodMask = CPSW_ALE_ALL_PORTS_MASK;
                inArgs.forceUntaggedEgressMask =  CPSW_ALE_ALL_PORTS_MASK;
                hEnet = Enet_getHandle(ENET_CPSW_9G, 0U);
                status = Enet_ioctl(hEnet, EnetSoc_getCoreId(), CPSW_ALE_IOCTL_ADD_VLAN, &prms);
                if (status != ENET_SOK)
                else
                    appLogPrintf("Valid Port Num (cmd = %08x, PORT_MEMBER List = %d vlan id %d\n", cmd, data[2], data[1]);
                    appLogPrintf("%s()  ADD_VLAN ioctl success: %d\n", __func__, status);
                appLogPrintf("HIRAIN_CMD_CPSW9G_VLAN_TEST exec end!\n\n\n\n\n");
            break;
            case HIRAIN_CMD_CPSW9G_VLAN_REMOVE:
                if (3 != prm_size)
                    break;
                CpswAle_VlanIdInfo inArgs  =
                    .vlanId = (int16_t)data[1],
                inArgs.tagType       = ENET_VLAN_TAG_TYPE_INNER;
                ENET_IOCTL_SET_IN_ARGS(&prms, &inArgs);
                status = Enet_ioctl(hEnet, EnetSoc_getCoreId(), CPSW_ALE_IOCTL_REMOVE_VLAN, &prms);
                    EnetAppUtils_print("%s: REMOVE_VLAN ioctl failed: %d\n",  __func__,
                                        status);
                appLogPrintf("HIRAIN_CMD_CPSW9G_VLAN_REMOVE exec end!\n\n\n\n\n");
            break;
            case HIRAIN_CMD_CPSW9G_PVID_TEST:
                if (5 != prm_size)
                    break;
                    appLogPrintf("UnValid Port Num (cmd = %08x, data[2] = %d B\n", cmd, data[2]);
                    break;
                uint32_t outArgs;
                inArgs.vlanMemberList = (1 << CPSW_ALE_MACPORT_TO_ALEPORT(data[2]-1)) | CPSW_ALE_HOST_PORT_MASK;
                inArgs.unregMcastFloodMask = CPSW_ALE_ALL_PORTS_MASK;
                    appLogPrintf("%s() failed ADD_PVID ioctl failed: %d\n", __func__, status);
                else
                    appLogPrintf("%s()  ADD_VLAN ioctl success: %d,id:%d,port:%d,list:%x\n", __func__, status,data[1],data[2],inArgs.vlanMemberList);
                appLogPrintf("HIRAIN_CMD_CPSW9G_PVID_TEST exec end!\n\n\n\n\n");
            break;
            default:
                status = -1;
                appLogPrintf("UnValid command (cmd = %08x, prm_size = %d B\n", cmd, prm_size);
            break;
        return status;
    从 ALE 表转储中、我可以看到配置了以下 VLAN。
    P0和 P5 ->内部 VLAN 50
    所有端口->内部 VLAN 300、406
    P8、P6、P5、P3、P1、 P0 ->内部 VLAN 1
    P4、P2、P0 ->内部 VLAN 0
    P3、P0 ->内部 VLAN 100
    P5、P0 ->内部 VLAN 110
    100和110 ->外层 VLAN
    请将"reg_mcast_fluy_mask"设置为与 VLAN 成员列表类似、因为转发规则将其用作端口掩码。
    此外、确认 是否启用了 CPSW_ALE_CONTROL (0x0C03E008).ALE_VLAN_AWARE?
    如上所述、请在更正后进行检查。
    苏德黑尔
