文件目录(C:\ti\controlSUITE\development_kits\TMDSIDDK_v2.0\IDDK_PM_Servo_F2837x_v2_00_00_00)
目录下的IDDK_PM_Servo_F2837x.C文件中:
母线电压配置:
// Bus Voltage Feedback at B0 (not used) 母线电压反馈
AdcbRegs.ADCSOC3CTL.bit.CHSEL = 0; // SOC3 will convert pin B0
AdcbRegs.ADCSOC3CTL.bit.ACQPS = 30; // sample window in SYSCLK cycles
AdcbRegs.ADCSOC3CTL.bit.TRIGSEL = 5; // trigger on ePWM1 SOCA/C
AdcbRegs.ADCPPB4CONFIG.bit.CONFIG = 3; //dx PPB is associated with SOC3
AdcbRegs.ADCPPB4OFFCAL.bit.OFFCAL = 0; //dx Write zero to this for now till offset ISR is run
