TMS320F28335: CCS8+W10编译之前CCSV3.3+dspbios工程编译出错问题
Part Number: TMS320F28335
Other Parts Discussed in Thread: CCSTUDIO
您好,请问:
新版本CCS8+W10是否支持编译之前一直编译OK的:XP+CCSV3.3+dspbios工程,编译出错见下,需要提出技术支持,需要另安装哪些工具吗?有没解决方案?
编译出错信息:
Description Resource Path Location Type
gmake: Target 'all' not remade because of errors. SL_SLAVE C/C++ Problem
gmake: *** [E:/2 sf/2 SMP/UL 25-30k/SVN/DSP/SVN 20150123/6KSlave_new/Debug/SL_slave_variable.obj] Error 1 SL_SLAVE C/C++ Problem
gmake: *** [E:/2 sf/2 SMP/UL 25-30k/SVN/DSP/SVN 20150123/6KSlave_new/Debug/SL_slave_StateSwitch.obj] Error 1 SL_SLAVE C/C++ Problem
gmake: *** [E:/2 sf/2 SMP/UL 25-30k/SVN/DSP/SVN 20150123/6KSlave_new/Debug/SL_slave_Spi.obj] Error 1 SL_SLAVE C/C++ Problem
gmake: *** [E:/2 sf/2 SMP/UL 25-30k/SVN/DSP/SVN 20150123/6KSlave_new/Debug/SL_slave_Sci.obj] Error 1 SL_SLAVE C/C++ Problem
gmake: *** [E:/2 sf/2 SMP/UL 25-30k/SVN/DSP/SVN 20150123/6KSlave_new/Debug/SL_slave_Regulator.obj] Error 1 SL_SLAVE C/C++ Problem
gmake: *** [E:/2 sf/2 SMP/UL 25-30k/SVN/DSP/SVN 20150123/6KSlave_new/Debug/SL_slave_ProtectionLogic.obj] Error 1 SL_SLAVE C/C++ Problem
gmake: *** [E:/2 sf/2 SMP/UL 25-30k/SVN/DSP/SVN 20150123/6KSlave_new/Debug/SL_slave_I2C.obj] Error 1 SL_SLAVE C/C++ Problem
gmake: *** [E:/2 sf/2 SMP/UL 25-30k/SVN/DSP/SVN 20150123/6KSlave_new/Debug/SL_slave_Gridperiodcalc.obj] Error 1 SL_SLAVE C/C++ Problem
gmake: *** [E:/2 sf/2 SMP/UL 25-30k/SVN/DSP/SVN 20150123/6KSlave_new/Debug/RTDXWork.obj] Error 1 SL_SLAVE C/C++ Problem
gmake: *** [E:/2 sf/2 SMP/UL 25-30k/SVN/DSP/SVN 20150123/6KSlave_new/Debug/main.obj] Error 1 SL_SLAVE C/C++ Problem
gmake: *** [E:/2 sf/2 SMP/UL 25-30k/SVN/DSP/SVN 20150123/6KSlave_new/Debug/DSP2803x_EPwm.obj] Error 1 SL_SLAVE C/C++ Problem
gmake: *** [E:/2 sf/2 SMP/UL 25-30k/SVN/DSP/SVN 20150123/6KSlave_new/Debug/DSP2803x_DefaultIsr_BIOS.obj] Error 1 SL_SLAVE C/C++ Problem
gmake: *** [E:/2 sf/2 SMP/UL 25-30k/SVN/DSP/SVN 20150123/6KSlave_new/Debug/CommProtocol.obj] Error 1 SL_SLAVE C/C++ Problem
#66 expected a ";" .ccsproject /SL_SLAVE line 1, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#66 expected a ";" .ccsproject /SL_SLAVE line 102, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#66 expected a ";" .ccsproject /SL_SLAVE line 14, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#66 expected a ";" .ccsproject /SL_SLAVE line 2, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#66 expected a ";" .ccsproject /SL_SLAVE line 3, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#66 expected a ";" .ccsproject /SL_SLAVE line 5, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#66 expected a ";" .ccsproject /SL_SLAVE line 7, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#20 identifier "Uint8" is undefined .ccsproject /SL_SLAVE line 308, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\include\CommProtocol.h C/C++ Problem
#20 identifier "Uint8" is undefined .ccsproject /SL_SLAVE line 443, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\include\SL_slave_variable.h C/C++ Problem
#20 identifier "Uint8" is undefined .ccsproject /SL_SLAVE line 444, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\include\SL_slave_variable.h C/C++ Problem
#20 identifier "Uint8" is undefined .ccsproject /SL_SLAVE line 445, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\include\SL_slave_variable.h C/C++ Problem
#20 identifier "Uint8" is undefined .ccsproject /SL_SLAVE line 446, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\include\SL_slave_variable.h C/C++ Problem
#20 identifier "Uint8" is undefined .ccsproject /SL_SLAVE line 447, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\include\SL_slave_variable.h C/C++ Problem
#20 identifier "Uint8" is undefined .ccsproject /SL_SLAVE line 450, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\include\SL_slave_variable.h C/C++ Problem
#20 identifier "Uint8" is undefined .ccsproject /SL_SLAVE line 452, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\include\SL_slave_variable.h C/C++ Problem
#20 identifier "Uint8" is undefined .ccsproject /SL_SLAVE line 454, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\include\SL_slave_variable.h C/C++ Problem
#20 identifier "Uint8" is undefined .ccsproject /SL_SLAVE line 456, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\include\SL_slave_variable.h C/C++ Problem
#20 identifier "Uint8" is undefined DSP2803x_DefaultIsr_BIOS.c /SL_SLAVE/source line 28 C/C++ Problem
#20 identifier "Uint8" is undefined DSP2803x_DefaultIsr_BIOS.c /SL_SLAVE/source line 29 C/C++ Problem
#20 identifier "Uint8" is undefined DSP2803x_DefaultIsr_BIOS.c /SL_SLAVE/source line 30 C/C++ Problem
#20 identifier "Uint8" is undefined DSP2803x_DefaultIsr_BIOS.c /SL_SLAVE/source line 31 C/C++ Problem
#20 identifier "Uint8" is undefined DSP2803x_DefaultIsr_BIOS.c /SL_SLAVE/source line 84 C/C++ Problem
#20 identifier "Uint8" is undefined DSP2803x_DefaultIsr_BIOS.c /SL_SLAVE/source line 85 C/C++ Problem
#20 identifier "Uint8" is undefined DSP2803x_DefaultIsr_BIOS.c /SL_SLAVE/source line 87 C/C++ Problem
#20 identifier "Uint8" is undefined SL_slave_I2C.c /SL_SLAVE/source line 25 C/C++ Problem
#20 identifier "Uint8" is undefined SL_slave_I2C.c /SL_SLAVE/source line 37 C/C++ Problem
#20 identifier "Uint8" is undefined SL_slave_ProtectionLogic.c /SL_SLAVE/source line 72 C/C++ Problem
#20 identifier "Uint8" is undefined SL_slave_ProtectionLogic.c /SL_SLAVE/source line 73 C/C++ Problem
#20 identifier "Uint8" is undefined SL_slave_ProtectionLogic.c /SL_SLAVE/source line 146 C/C++ Problem
#20 identifier "Uint8" is undefined SL_slave_ProtectionLogic.c /SL_SLAVE/source line 147 C/C++ Problem
#20 identifier "Uint8" is undefined SL_slave_ProtectionLogic.c /SL_SLAVE/source line 200 C/C++ Problem
#20 identifier "Uint8" is undefined SL_slave_ProtectionLogic.c /SL_SLAVE/source line 201 C/C++ Problem
#20 identifier "Uint8" is undefined SL_slave_ProtectionLogic.c /SL_SLAVE/source line 274 C/C++ Problem
#20 identifier "Uint8" is undefined SL_slave_ProtectionLogic.c /SL_SLAVE/source line 275 C/C++ Problem
#20 identifier "Uint8" is undefined SL_slave_Sci.c /SL_SLAVE/source line 27 C/C++ Problem
#20 identifier "Uint8" is undefined SL_slave_Sci.c /SL_SLAVE/source line 54 C/C++ Problem
#20 identifier "Uint8" is undefined SL_slave_Sci.c /SL_SLAVE/source line 55 C/C++ Problem
#20 identifier "Uint8" is undefined SL_slave_Sci.c /SL_SLAVE/source line 56 C/C++ Problem
#20 identifier "Uint8" is undefined SL_slave_Spi.c /SL_SLAVE/source line 23 C/C++ Problem
#20 identifier "Uint8" is undefined SL_slave_Spi.c /SL_SLAVE/source line 30 C/C++ Problem
#20 identifier "Uint8" is undefined SL_slave_Spi.c /SL_SLAVE/source line 151 C/C++ Problem
#20 identifier "Uint8" is undefined SL_slave_Spi.c /SL_SLAVE/source line 153 C/C++ Problem
#20 identifier "SYS_FOREVER" is undefined SL_slave_StateSwitch.c /SL_SLAVE/source line 121 C/C++ Problem
#20 identifier "SYS_FOREVER" is undefined main.c /SL_SLAVE/source line 118 C/C++ Problem
#20 identifier "SWI_I2Ca" is undefined DSP2803x_DefaultIsr_BIOS.c /SL_SLAVE/source line 75 C/C++ Problem
#20 identifier "SEM_TskGridPeriodCalcReady" is undefined SL_slave_Gridperiodcalc.c /SL_SLAVE/source line 481 C/C++ Problem
#20 identifier "SEM_TskGridPeriodCalcReady" is undefined SL_slave_Gridperiodcalc.c /SL_SLAVE/source line 499 C/C++ Problem
#20 identifier "SEM_StateSwitch_2msPRD" is undefined SL_slave_StateSwitch.c /SL_SLAVE/source line 121 C/C++ Problem
#20 identifier "SEM_StateSwitch_2msPRD" is undefined main.c /SL_SLAVE/source line 97 C/C++ Problem
#20 identifier "SEM_SPIb" is undefined DSP2803x_DefaultIsr_BIOS.c /SL_SLAVE/source line 64 C/C++ Problem
#20 identifier "SEM_SPIb" is undefined main.c /SL_SLAVE/source line 118 C/C++ Problem
#20 identifier "SEM_I2C_isr" is undefined SL_slave_I2C.c /SL_SLAVE/source line 298 C/C++ Problem
#20 identifier "MODULE" is undefined .ccsproject /SL_SLAVE line 101, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#20 identifier "LCK_EEPROM" is undefined SL_slave_I2C.c /SL_SLAVE/source line 448 C/C++ Problem
#20 identifier "Int32" is undefined .ccsproject /SL_SLAVE line 45, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\include\RTDXWork.h C/C++ Problem
#20 identifier "Int32" is undefined .ccsproject /SL_SLAVE line 47, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\include\RTDXWork.h C/C++ Problem
#20 identifier "Int32" is undefined .ccsproject /SL_SLAVE line 48, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\include\RTDXWork.h C/C++ Problem
#20 identifier "Int32" is undefined .ccsproject /SL_SLAVE line 55, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\include\RTDXWork.h C/C++ Problem
#20 identifier "Int32" is undefined .ccsproject /SL_SLAVE line 60, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\include\RTDXWork.h C/C++ Problem
#20 identifier "Int32" is undefined SL_slave_Gridperiodcalc.c /SL_SLAVE/source line 24 C/C++ Problem
#20 identifier "Int16" is undefined .ccsproject /SL_SLAVE line 177, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\include\CommProtocol.h C/C++ Problem
#20 identifier "Int16" is undefined .ccsproject /SL_SLAVE line 244, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\include\CommProtocol.h C/C++ Problem
#20 identifier "Int16" is undefined .ccsproject /SL_SLAVE line 292, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\include\CommProtocol.h C/C++ Problem
#20 identifier "Int16" is undefined .ccsproject /SL_SLAVE line 375, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\include\CommProtocol.h C/C++ Problem
#20 identifier "Int16" is undefined SL_slave_Gridperiodcalc.c /SL_SLAVE/source line 23 C/C++ Problem
#20 identifier "INPUT" is undefined .ccsproject /SL_SLAVE line 5, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#20 identifier "generated" is undefined .ccsproject /SL_SLAVE line 2, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#20 identifier "g_SpiTxBuf" is undefined DSP2803x_DefaultIsr_BIOS.c /SL_SLAVE/source line 60 C/C++ Problem
#20 identifier "g_SpiTxBuf" is undefined DSP2803x_DefaultIsr_BIOS.c /SL_SLAVE/source line 65 C/C++ Problem
#20 identifier "EXTERNAL" is undefined .ccsproject /SL_SLAVE line 13, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#20 identifier "Do" is undefined .ccsproject /SL_SLAVE line 1, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#20 identifier "changes" is undefined .ccsproject /SL_SLAVE line 3, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 103, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 104, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 105, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 107, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 108, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 109, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 110, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 111, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 112, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 113, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 114, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 115, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 116, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 117, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#168 invalid floating constant .ccsproject /SL_SLAVE line 145, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#168 invalid floating constant .ccsproject /SL_SLAVE line 144, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#168 invalid floating constant .ccsproject /SL_SLAVE line 137, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#168 invalid floating constant .ccsproject /SL_SLAVE line 135, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#168 invalid floating constant .ccsproject /SL_SLAVE line 106, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 201, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 199, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 196, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 193, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 192, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 191, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 179, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 178, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 177, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 175, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 173, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 172, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 170, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 169, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 168, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 167, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 166, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 162, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 161, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 159, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 158, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 157, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 156, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 155, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 154, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 152, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 150, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 149, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 147, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 143, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 142, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 141, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 140, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 139, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 138, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 136, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 134, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 133, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 132, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 131, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 130, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 129, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 128, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 127, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 125, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 123, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 120, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#19 extra text after expected end of number .ccsproject /SL_SLAVE line 118, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
Invalid project path: Include path not found (E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\DSP2803x_headers\include). SL_SLAVE pathentry Path Entry Problem
<a href="file:/C:/ti/ccs1100/ccs/tools/compiler/dmed/HTML/225.html">#225-D</a> function "TSK_sleep" declared implicitly SL_slave_I2C.c /SL_SLAVE/source line 229 C/C++ Problem
<a href="file:/C:/ti/ccs1100/ccs/tools/compiler/dmed/HTML/225.html">#225-D</a> function "SWI_post" declared implicitly DSP2803x_DefaultIsr_BIOS.c /SL_SLAVE/source line 75 C/C++ Problem
<a href="file:/C:/ti/ccs1100/ccs/tools/compiler/dmed/HTML/225.html">#225-D</a> function "SEM_post" declared implicitly DSP2803x_DefaultIsr_BIOS.c /SL_SLAVE/source line 64 C/C++ Problem
<a href="file:/C:/ti/ccs1100/ccs/tools/compiler/dmed/HTML/225.html">#225-D</a> function "SEM_post" declared implicitly SL_slave_Gridperiodcalc.c /SL_SLAVE/source line 481 C/C++ Problem
<a href="file:/C:/ti/ccs1100/ccs/tools/compiler/dmed/HTML/225.html">#225-D</a> function "SEM_post" declared implicitly main.c /SL_SLAVE/source line 97 C/C++ Problem
<a href="file:/C:/ti/ccs1100/ccs/tools/compiler/dmed/HTML/225.html">#225-D</a> function "SEM_pendBinary" declared implicitly SL_slave_I2C.c /SL_SLAVE/source line 298 C/C++ Problem
<a href="file:/C:/ti/ccs1100/ccs/tools/compiler/dmed/HTML/225.html">#225-D</a> function "SEM_pend" declared implicitly SL_slave_Gridperiodcalc.c /SL_SLAVE/source line 499 C/C++ Problem
<a href="file:/C:/ti/ccs1100/ccs/tools/compiler/dmed/HTML/225.html">#225-D</a> function "SEM_pend" declared implicitly SL_slave_StateSwitch.c /SL_SLAVE/source line 121 C/C++ Problem
<a href="file:/C:/ti/ccs1100/ccs/tools/compiler/dmed/HTML/225.html">#225-D</a> function "SEM_pend" declared implicitly main.c /SL_SLAVE/source line 118 C/C++ Problem
<a href="file:/C:/ti/ccs1100/ccs/tools/compiler/dmed/HTML/225.html">#225-D</a> function "LCK_pend" declared implicitly SL_slave_I2C.c /SL_SLAVE/source line 448 C/C++ Problem
#78-D this declaration has no storage class or type specifier .ccsproject /SL_SLAVE line 2, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#78-D this declaration has no storage class or type specifier .ccsproject /SL_SLAVE line 7, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#552-D variable "VISO2TEST" was set but never used SL_slave_Gridperiodcalc.c /SL_SLAVE/source line 168 C/C++ Problem
#552-D variable "VISO1TEST" was set but never used SL_slave_Gridperiodcalc.c /SL_SLAVE/source line 167 C/C++ Problem
#552-D variable "ISOUoTest0" was set but never used SL_slave_StateSwitch.c /SL_SLAVE/source line 46 C/C++ Problem
#179-D variable "s_relaycnt" was declared but never referenced SL_slave_StateSwitch.c /SL_SLAVE/source line 443 C/C++ Problem
#179-D variable "ISOCheckCnt" was declared but never referenced SL_slave_Gridperiodcalc.c /SL_SLAVE/source line 170 C/C++ Problem
#12-D parsing restarts here after previous syntax error .ccsproject /SL_SLAVE line 101, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#12-D parsing restarts here after previous syntax error .ccsproject /SL_SLAVE line 13, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\BIOS\F28035_BIOS_flashcfg.h C/C++ Problem
#12-D parsing restarts here after previous syntax error .ccsproject /SL_SLAVE line 134, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\include\IQmathLib.h C/C++ Problem
#12-D parsing restarts here after previous syntax error .ccsproject /SL_SLAVE line 19, external location: E:\2 sf\2 SMP\UL 25-30k\SVN\DSP\SVN 20150123\6KSlave_new\include\SL_slave_variable.h C/C++ Problem
  • 参照上面么两种方式打开CCSv3.3+DSPBIOS工程,分别在公司台式电脑W10和笔记本W10,家里W10下安装CCSv3.3(包含之前一直用各插件和上面链接说明)编译出错不通过、CCSv8.1 输入CCSv3.3工程编译出错不通过,帮忙分析支持什么原因?整了有两三天了。
    CCS3.3 编译出错:
    1、
    [SL_master.tcf] "C:\CCStudio_v3.3\bios_5_31_02\xdctools\tconf" -b -Dconfig.importPath="C:/CCStudio_v3.3MCU/bios_5_41_10_36/packages;C:/CCStudio_v3.3/bios_5_31_02/packages" SL_master.tcf
    js: "C:/CCStudio_v3.3/bios_5_31_02/xdctools/include/utils.tci", line 784: exception from uncaught JavaScript throw: Error: Can't find Platform.tc[ip] file for 'ti.platforms.control28335'
    "./SL_master.tcf", line 1
    2、
    [SL_master.tcf] "C:\CCStudio_v3.3\bios_5_31_02\xdctools\tconf" -b -Dconfig.importPath="C:/CCStudio_v3.3/bios_5_33_06/packages;C:/CCStudio_v3.3/bios_5_31_02/packages" SL_master.tcf
    js: "C:/CCStudio_v3.3/bios_5_31_02/xdctools/include/utils.tci", line 591: exception from uncaught JavaScript throw: Error: Can't find cpu definition file: ti/catalog/c2800/C28335.tci
    "C:/CCStudio_v3.3/bios_5_33_06/packages/ti/platforms/generic/Platform.tcp", line 60
    "C:/CCStudio_v3.3/bios_5_31_02/xdctools/include/utils.tci", line 562
    "C:/CCStudio_v3.3/bios_5_31_02/xdctools/include/utils.tci", line 791
    "C:/CCStudio_v3.3/bios_5_33_06/packages/ti/platforms/control28335/Platform.tci", line 42
    js: "C:/CCStudio_v3.3/bios_5_31_02/xdctools/include/utils.tci", line 834: exception from uncaught JavaScript throw: TypeError: Cannot call method "create" of undefined (C:/CCStudio_v3.3/bios_5_31_02/xdctools/include/utils.tci#834)
    js: "C:/CCStudio_v3.3/bios_5_33_06/packages/ti/bios/bios.tci", line 243: exception from uncaught JavaScript throw: TypeError: Cannot set property "ENABLEINST" of undefined to "true" (C:/CCStudio_v3.3/bios_5_33_06/packages/ti/bios/bios.tci#243)
    "C:/CCStudio_v3.3/bios_5_31_02/xdctools/include/utils.tci", line 563
    "C:/CCStudio_v3.3/bios_5_31_02/xdctools/include/utils.tci", line 860
    "./SL_master.tcf", line 4
    CCSv8 Importing CCSv3.3 Project 编译出错:
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 103: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 104: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 105: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 106: error #168: invalid floating constant
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 107: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 108: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 109: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 110: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 111: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 112: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 113: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 114: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 115: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 116: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 117: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 118: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 120: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 123: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 125: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 127: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 128: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 129: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 130: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 131: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 132: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 133: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 134: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 135: error #168: invalid floating constant
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 136: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 137: error #168: invalid floating constant
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 138: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 139: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 140: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 141: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 142: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 143: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 144: error #168: invalid floating constant
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 145: error #168: invalid floating constant
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 147: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 149: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 150: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 152: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 154: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 155: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 156: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 157: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 158: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 159: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 161: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 162: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 166: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 167: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 168: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 169: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 170: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 172: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 173: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 175: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 177: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 178: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 179: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 191: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 192: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 193: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 196: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 199: error #19: extra text after expected end of number
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 201: error #19: extra text after expected end of number
    "C:\Users\Administrator\Desktop\liyf\2\SVN 20150123\6KSlave_new\include\IQmathLib.h", line 134: warning #12-D: parsing restarts here after previous syntax error
    "C:\Users\Administrator\Desktop\liyf\2\SVN 20150123\6KSlave_new\include\SL_slave_variable.h", line 443: error #20: identifier "Uint8" is undefined
    "C:\Users\Administrator\Desktop\liyf\2\SVN 20150123\6KSlave_new\include\SL_slave_variable.h", line 444: error #20: identifier "Uint8" is undefined
    "C:\Users\Administrator\Desktop\liyf\2\SVN 20150123\6KSlave_new\include\SL_slave_variable.h", line 445: error #20: identifier "Uint8" is undefined
    "C:\Users\Administrator\Desktop\liyf\2\SVN 20150123\6KSlave_new\include\SL_slave_variable.h", line 446: error #20: identifier "Uint8" is undefined
    "C:\Users\Administrator\Desktop\liyf\2\SVN 20150123\6KSlave_new\include\SL_slave_variable.h", line 447: error #20: identifier "Uint8" is undefined
    "C:\Users\Administrator\Desktop\liyf\2\SVN 20150123\6KSlave_new\include\SL_slave_variable.h", line 450: error #20: identifier "Uint8" is undefined
    "C:\Users\Administrator\Desktop\liyf\2\SVN 20150123\6KSlave_new\include\SL_slave_variable.h", line 452: error #20: identifier "Uint8" is undefined
    "C:\Users\Administrator\Desktop\liyf\2\SVN 20150123\6KSlave_new\include\SL_slave_variable.h", line 454: error #20: identifier "Uint8" is undefined
    "C:\Users\Administrator\Desktop\liyf\2\SVN 20150123\6KSlave_new\include\SL_slave_variable.h", line 456: error #20: identifier "Uint8" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/include/RTDXWork.h", line 45: error #20: identifier "Int32" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/include/RTDXWork.h", line 47: error #20: identifier "Int32" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/include/RTDXWork.h", line 48: error #20: identifier "Int32" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/include/RTDXWork.h", line 55: error #20: identifier "Int32" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/include/RTDXWork.h", line 60: error #20: identifier "Int32" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_Sci.c", line 27: error #20: identifier "Uint8" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_Sci.c", line 54: error #20: identifier "Uint8" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_Sci.c", line 55: error #20: identifier "Uint8" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_Sci.c", line 56: error #20: identifier "Uint8" is undefined
    Error limit reached.
    100 errors detected in the compilation of "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_Sci.c".
    Compilation terminated.
    gmake: *** [C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug/SL_slave_Sci.obj] Error 1
    Building file: "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_Spi.c"
    Invoking: C2000 Compiler
    "C:/ti/bin/cl2000" -v28 -ml -mt --cla_support=cla0 --include_path="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/SL_SLAVE" --include_path="D:/liyf/bios/bios/xdais_7_24_00_04/xdais_7_24_00_04/packages/ti/xdais" --include_path="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/include" --include_path="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/DSP2803x_headers/include" --include_path="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS" --include_path="C:/ti/include" --define=_DEBUG --define=LARGE_MODEL --define=LOGOUT -g --diag_suppress=303 --diag_warning=225 --diag_wrap=off --display_error_number --abi=coffabi --asm_directory="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug" --list_directory="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug" --obj_directory="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug" --temp_directory="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug" --preproc_with_compile --preproc_dependency="source/SL_slave_Spi.d_raw" "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_Spi.c"
    >> Compilation failure
    source/subdir_rules.mk:177: recipe for target 'C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug/SL_slave_Spi.obj' failed
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 1: error #20: identifier "Do" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 1: error #66: expected a ";"
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 2: error #20: identifier "generated" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 2: error #66: expected a ";"
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 2: warning #78-D: this declaration has no storage class or type specifier
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 3: error #20: identifier "changes" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 3: error #66: expected a ";"
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 5: error #20: identifier "INPUT" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 5: error #66: expected a ";"
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 7: warning #78-D: this declaration has no storage class or type specifier
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 7: error #66: expected a ";"
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 13: warning #12-D: parsing restarts here after previous syntax error
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 13: error #20: identifier "EXTERNAL" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 14: error #66: expected a ";"
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 101: warning #12-D: parsing restarts here after previous syntax error
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 101: error #20: identifier "MODULE" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS/F28035_BIOS_flashcfg.h", line 102: error #66: expected a ";"
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_Spi.c", line 23: error #20: identifier "Uint8" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_Spi.c", line 30: error #20: identifier "Uint8" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_Spi.c", line 151: error #20: identifier "Uint8" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_Spi.c", line 153: error #20: identifier "Uint8" is undefined
    100 errors detected in the compilation of "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_Spi.c".
    gmake: *** [C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug/SL_slave_Spi.obj] Error 1
    Building file: "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_variable.c"
    "C:/ti/bin/cl2000" -v28 -ml -mt --cla_support=cla0 --include_path="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/SL_SLAVE" --include_path="D:/liyf/bios/bios/xdais_7_24_00_04/xdais_7_24_00_04/packages/ti/xdais" --include_path="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/include" --include_path="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/DSP2803x_headers/include" --include_path="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS" --include_path="C:/ti/include" --define=_DEBUG --define=LARGE_MODEL --define=LOGOUT -g --diag_suppress=303 --diag_warning=225 --diag_wrap=off --display_error_number --abi=coffabi --asm_directory="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug" --list_directory="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug" --obj_directory="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug" --temp_directory="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug" --preproc_with_compile --preproc_dependency="source/SL_slave_variable.d_raw" "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_variable.c"
    >> Compilation failure
    source/subdir_rules.mk:191: recipe for target 'C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug/SL_slave_variable.obj' failed
    89 errors detected in the compilation of "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_variable.c".
    gmake: *** [C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug/SL_slave_variable.obj] Error 1
    Building file: "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_StateSwitch.c"
    "C:/ti/bin/cl2000" -v28 -ml -mt --cla_support=cla0 --include_path="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/SL_SLAVE" --include_path="D:/liyf/bios/bios/xdais_7_24_00_04/xdais_7_24_00_04/packages/ti/xdais" --include_path="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/include" --include_path="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/DSP2803x_headers/include" --include_path="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS" --include_path="C:/ti/include" --define=_DEBUG --define=LARGE_MODEL --define=LOGOUT -g --diag_suppress=303 --diag_warning=225 --diag_wrap=off --display_error_number --abi=coffabi --asm_directory="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug" --list_directory="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug" --obj_directory="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug" --temp_directory="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug" --preproc_with_compile --preproc_dependency="source/SL_slave_StateSwitch.d_raw" "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_StateSwitch.c"
    >> Compilation failure
    source/subdir_rules.mk:184: recipe for target 'C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug/SL_slave_StateSwitch.obj' failed
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_StateSwitch.c", line 121: warning #225-D: function "SEM_pend" declared implicitly
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_StateSwitch.c", line 121: error #20: identifier "SEM_StateSwitch_2msPRD" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_StateSwitch.c", line 121: error #20: identifier "SYS_FOREVER" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_StateSwitch.c", line 443: warning #179-D: variable "s_relaycnt" was declared but never referenced
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_StateSwitch.c", line 46: warning #552-D: variable "ISOUoTest0" was set but never used
    98 errors detected in the compilation of "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/SL_slave_StateSwitch.c".
    gmake: *** [C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug/SL_slave_StateSwitch.obj] Error 1
    Building file: "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/main.c"
    "C:/ti/bin/cl2000" -v28 -ml -mt --cla_support=cla0 --include_path="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/SL_SLAVE" --include_path="D:/liyf/bios/bios/xdais_7_24_00_04/xdais_7_24_00_04/packages/ti/xdais" --include_path="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/include" --include_path="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/DSP2803x_headers/include" --include_path="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/BIOS" --include_path="C:/ti/include" --define=_DEBUG --define=LARGE_MODEL --define=LOGOUT -g --diag_suppress=303 --diag_warning=225 --diag_wrap=off --display_error_number --abi=coffabi --asm_directory="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug" --list_directory="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug" --obj_directory="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug" --temp_directory="C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug" --preproc_with_compile --preproc_dependency="source/main.d_raw" "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/main.c"
    >> Compilation failure
    source/subdir_rules.mk:198: recipe for target 'C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug/main.obj' failed
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/main.c", line 97: warning #225-D: function "SEM_post" declared implicitly
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/main.c", line 97: error #20: identifier "SEM_StateSwitch_2msPRD" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/main.c", line 118: warning #225-D: function "SEM_pend" declared implicitly
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/main.c", line 118: error #20: identifier "SEM_SPIb" is undefined
    "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/main.c", line 118: error #20: identifier "SYS_FOREVER" is undefined
    92 errors detected in the compilation of "C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/source/main.c".
    gmake: *** [C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KSlave_new/Debug/main.obj] Error 1
    **** Build Finished ****
  • 在W10+CCS3.3 打开.tcf文件时信息:
      • js: "C:/CCStudio_v3.3/bios_5_31_02/xdctools/include/utils.tci", line 784: exception from uncaught JavaScript throw: Error: Can't find Platform.tc[ip] file for 'ti.platforms.control28335' "./SL_master.tcf", line 1
        "./<stdin>", line 4
        Correct any script errors in C:/Users/Administrator/Desktop/liyf/2/SVN 20150123/6KMaster_new/bios/SL_master.tcf
        using the Configuration Tool or a text editor, if necessary.
        TConf initialization arguments:
        -e environment['config.importPath']='C:/CCStudio_v3.3MCU/bios_5_41_10_36/packages;C:/CCStudio_v3.3/bios_5_31_02/packages;' -e environment['config.scriptName']='SL_master.tcf'
    在深圳宝安西乡,安排现场支持下,谢谢。
  • 您好,请联系您的销售或FAE以寻求现场支持。
