Other Parts Discussed in Thread: TMS320F280021
问题:用TMS320F280021做LLC充电过程,ePWM3和ePwm4为驱动H桥LLC,PWM工作频率为80K~150K,为软件设置的上下限值,谐振工作频率为90KHZ。当LLC工作过程进行调节频率从85K往下调节,接近80K时,偶尔有几率有发生半桥上下MOS管驱动同高现象,非百分百,MOS管直通短路,管子烧坏。请问各位大神帮忙审核下配置是否有问题?感谢!
波形如下:
短路前一时刻的驱动波形和频率:
以下为PWM配置代码:
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
void UserSetEPWM()
EALLOW;
CpuSysRegs.PCLKCR0.bit.TBCLKSYNC = 0;
EDIS;
EALLOW;
GpioCtrlRegs.GPHAMSEL.bit.GPIO242 = 0;
GpioCtrlRegs.GPHQSEL2.bit.GPIO242 = 3;
InputXbarRegs.INPUT1SELECT = 242;
GpioCtrlRegs.GPHLOCK.bit.GPIO242 = 1;
GpioCtrlRegs.GPHCR.bit.GPIO242 = 1;
InputXbarRegs.INPUTSELECTLOCK.bit.INPUT1SELECT = 1;
EPwm1Regs.TZSEL.bit.OSHT1 = TZ_ENABLE;
EPwm2Regs.TZSEL.bit.OSHT1 = TZ_ENABLE;
EPwm3Regs.TZSEL.bit.OSHT1 = TZ_ENABLE;
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
void UserSetEPWM() { EALLOW; CpuSysRegs.PCLKCR0.bit.TBCLKSYNC = 0; EDIS; EALLOW; GpioCtrlRegs.GPHAMSEL.bit.GPIO242 = 0; GpioCtrlRegs.GPHQSEL2.bit.GPIO242 = 3; InputXbarRegs.INPUT1SELECT = 242; GpioCtrlRegs.GPHLOCK.bit.GPIO242 = 1; GpioCtrlRegs.GPHCR.bit.GPIO242 = 1; InputXbarRegs.INPUTSELECTLOCK.bit.INPUT1SELECT = 1; EPwm1Regs.TZSEL.bit.OSHT1 = TZ_ENABLE; EPwm2Regs.TZSEL.bit.OSHT1 = TZ_ENABLE; EPwm3Regs.TZSEL.bit.OSHT1 = TZ_ENABLE; EPwm4Regs.TZSEL.bit.OSHT1 = TZ_ENABLE; EPwm1Regs.TZSEL.bit.OSHT5 = TZ_ENABLE; EPwm2Regs.TZSEL.bit.OSHT5 = TZ_ENABLE; EPwm3Regs.TZSEL.bit.OSHT5 = TZ_ENABLE; EPwm4Regs.TZSEL.bit.OSHT5 = TZ_ENABLE; EPwm1Regs.TZSEL.bit.OSHT6 = TZ_ENABLE; EPwm2Regs.TZSEL.bit.OSHT6 = TZ_ENABLE; EPwm3Regs.TZSEL.bit.OSHT6 = TZ_ENABLE; EPwm4Regs.TZSEL.bit.OSHT6 = TZ_ENABLE; EPwm1Regs.TZCTL.bit.TZA = TZ_FORCE_LO; EPwm1Regs.TZCTL.bit.TZB = TZ_FORCE_LO; EPwm2Regs.TZCTL.bit.TZA = TZ_FORCE_LO; EPwm2Regs.TZCTL.bit.TZB = TZ_FORCE_LO; EPwm3Regs.TZCTL.bit.TZA = TZ_FORCE_LO; EPwm3Regs.TZCTL.bit.TZB = TZ_FORCE_LO; EPwm4Regs.TZCTL.bit.TZA = TZ_FORCE_LO; EPwm4Regs.TZCTL.bit.TZB = TZ_FORCE_LO; EPwm1Regs.TZFRC.bit.OST = 1; EPwm2Regs.TZFRC.bit.OST = 1; EPwm3Regs.TZFRC.bit.OST = 1; EPwm4Regs.TZFRC.bit.OST = 1; EPwm1Regs.GLDCFG.all = 0x07FF; EPwm1Regs.GLDCTL.bit.GLDMODE = 6; EPwm1Regs.GLDCTL.bit.OSHTMODE = 1; EPwm1Regs.GLDCTL.bit.GLD = 1; EPwm1Regs.EPWMXLINK.bit.GLDCTL2LINK = 0; EPwm2Regs.GLDCFG.all = 0x07FF; EPwm2Regs.GLDCTL.bit.GLDMODE = 6; EPwm2Regs.GLDCTL.bit.OSHTMODE = 1; EPwm2Regs.GLDCTL.bit.GLD = 1; EPwm2Regs.EPWMXLINK.bit.GLDCTL2LINK = 0; EPwm3Regs.GLDCFG.all = 0x07FF; EPwm3Regs.GLDCTL.bit.GLDMODE = 6; EPwm3Regs.GLDCTL.bit.OSHTMODE = 1; EPwm3Regs.GLDCTL.bit.GLD = 1; EPwm3Regs.EPWMXLINK.bit.GLDCTL2LINK = 0; EPwm4Regs.GLDCFG.all = 0x07FF; EPwm4Regs.GLDCTL.bit.GLDMODE = 6; EPwm4Regs.GLDCTL.bit.OSHTMODE = 1; EPwm4Regs.GLDCTL.bit.GLD = 1; EPwm4Regs.EPWMXLINK.bit.GLDCTL2LINK = 0; EDIS; EPwm1Regs.TBPRD = EPWMPeriod; EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1; // TBCLK = SYSCLKOUT /(HSPCLKDIV ×CLKDIV) EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; EPwm1Regs.TBCTL.bit.PHSDIR = TB_UP; EPwm1Regs.TBCTL.bit.PRDLD = TB_SHADOW; EPwm1Regs.TBCTL.bit.PHSEN = TB_ENABLE; //使能同步 EPwm1Regs.TBPHS.bit.TBPHS = 0; EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count updown EPwm1Regs.EPWMSYNCINSEL.bit.SEL = SYNC_IN_SRC_DISABLE_ALL; EPwm1Regs.EPWMSYNCOUTEN.bit.ZEROEN = SYNC_OUT_SRC_ENABLE; EPwm2Regs.TBPRD = EPWMPeriod; EPwm2Regs.TBCTL.bit.CLKDIV = TB_DIV1; // TBCLK = SYSCLKOUT /(HSPCLKDIV ×CLKDIV) EPwm2Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; EPwm2Regs.TBCTL.bit.PHSDIR = TB_UP; EPwm2Regs.TBCTL.bit.PRDLD = TB_SHADOW; EPwm2Regs.TBCTL.bit.PHSEN = TB_ENABLE; EPwm2Regs.TBPHS.bit.TBPHS = 2; EPwm2Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count updown EPwm2Regs.EPWMSYNCINSEL.bit.SEL = SYNC_IN_SRC_SYNCOUT_EPWM1; EPwm3Regs.TBPRD = EPWMPeriod; EPwm3Regs.TBCTL.bit.CLKDIV = TB_DIV1; // TBCLK = SYSCLKOUT /(HSPCLKDIV ×CLKDIV) EPwm3Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; EPwm3Regs.TBCTL.bit.PHSDIR = TB_UP; EPwm3Regs.TBCTL.bit.PRDLD = TB_SHADOW; EPwm3Regs.TBCTL.bit.PHSEN = TB_ENABLE; EPwm3Regs.TBPHS.bit.TBPHS = 3; //补偿10ns数字隔离器延迟 EPwm3Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count updown EPwm3Regs.EPWMSYNCINSEL.bit.SEL = SYNC_IN_SRC_SYNCOUT_EPWM1; EPwm4Regs.TBPRD = EPWMPeriod; EPwm4Regs.TBCTL.bit.CLKDIV = TB_DIV1; // TBCLK = SYSCLKOUT /(HSPCLKDIV ×CLKDIV) EPwm4Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; EPwm4Regs.TBCTL.bit.PHSDIR = TB_UP; EPwm4Regs.TBCTL.bit.PRDLD = TB_SHADOW; EPwm4Regs.TBCTL.bit.PHSEN = TB_ENABLE; EPwm4Regs.TBPHS.bit.TBPHS = 3; //补偿10ns数字隔离器延迟 EPwm4Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count updown EPwm4Regs.EPWMSYNCINSEL.bit.SEL = SYNC_IN_SRC_SYNCOUT_EPWM1; EPwm5Regs.TBPRD = 1000; EPwm5Regs.TBCTL.bit.CLKDIV = TB_DIV1; // TBCLK = SYSCLKOUT /(HSPCLKDIV ×CLKDIV) EPwm5Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; EPwm5Regs.TBCTL.bit.PHSDIR = TB_UP; EPwm5Regs.TBCTL.bit.PRDLD = TB_SHADOW; EPwm5Regs.TBCTL.bit.PHSEN = TB_DISABLE; // EPwm5Regs.TBPHS.bit.TBPHS = 2; //补偿10ns数字隔离器延迟 EPwm5Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count updown EPwm5Regs.EPWMSYNCINSEL.bit.SEL = SYNC_IN_SRC_DISABLE_ALL; //计数比较模块设定 EPwm1Regs.TBCTR = 0; //计数初值为0 EPwm1Regs.CMPA.bit.CMPA = EPWMPeriod_DIV2 - LeastTime_LLC; EPwm1Regs.CMPB.bit.CMPB = EPWMPeriod_DIV2 + LeastTime_LLC; EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW; EPwm2Regs.TBCTR = 0; //计数初值为0 EPwm2Regs.CMPA.bit.CMPA = EPWMPeriod_DIV2 - LeastTime_LLC; EPwm2Regs.CMPB.bit.CMPB = EPWMPeriod_DIV2 + LeastTime_LLC; EPwm2Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; EPwm2Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; EPwm2Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; EPwm2Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW; EPwm3Regs.TBCTR = 0; //计数初值为0 EPwm3Regs.CMPA.bit.CMPA = EPWMPeriod_DIV2 - LeastTime_LLC; EPwm3Regs.CMPB.bit.CMPB = EPWMPeriod_DIV2 + LeastTime_LLC; EPwm3Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; EPwm3Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; EPwm3Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; EPwm3Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW; EPwm4Regs.TBCTR = 0; //计数初值为0 EPwm4Regs.CMPA.bit.CMPA = EPWMPeriod_DIV2 - LeastTime_LLC; EPwm4Regs.CMPB.bit.CMPB = EPWMPeriod_DIV2 + LeastTime_LLC; EPwm4Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; EPwm4Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; EPwm4Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; EPwm4Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW; EPwm5Regs.TBCTR = 0; //计数初值为0 // EPwm5Regs.CMPA.bit.CMPA = 0; // EPwm5Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // EPwm5Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; // AQ模块设定 EPwm1Regs.AQCTLA.bit.CAU = AQ_SET; EPwm1Regs.AQCTLA.bit.CBU = AQ_CLEAR; EPwm1Regs.AQCTLB.bit.CBD = AQ_SET; EPwm1Regs.AQCTLB.bit.CAD = AQ_CLEAR; EPwm1Regs.AQCTLA.bit.ZRO = AQ_CLEAR; EPwm1Regs.AQCTLB.bit.ZRO = AQ_CLEAR; EPwm2Regs.AQCTLB.bit.CAU = AQ_SET; EPwm2Regs.AQCTLB.bit.CBU = AQ_CLEAR; EPwm2Regs.AQCTLA.bit.CBD = AQ_SET; EPwm2Regs.AQCTLA.bit.CAD = AQ_CLEAR; EPwm2Regs.AQCTLA.bit.ZRO = AQ_CLEAR; EPwm2Regs.AQCTLB.bit.ZRO = AQ_CLEAR; EPwm3Regs.AQCTLA.bit.CAU = AQ_SET; EPwm3Regs.AQCTLA.bit.CBU = AQ_CLEAR; EPwm3Regs.AQCTLB.bit.CBD = AQ_SET; EPwm3Regs.AQCTLB.bit.CAD = AQ_CLEAR; EPwm3Regs.AQCTLA.bit.ZRO = AQ_CLEAR; EPwm3Regs.AQCTLB.bit.ZRO = AQ_CLEAR; EPwm4Regs.AQCTLB.bit.CAU = AQ_SET; EPwm4Regs.AQCTLB.bit.CBU = AQ_CLEAR; EPwm4Regs.AQCTLA.bit.CBD = AQ_SET; EPwm4Regs.AQCTLA.bit.CAD = AQ_CLEAR; EPwm4Regs.AQCTLA.bit.ZRO = AQ_CLEAR; EPwm4Regs.AQCTLB.bit.ZRO = AQ_CLEAR; //DB死区模块设定 EPwm1Regs.DBCTL.bit.OUT_MODE = DB_DISABLE; EPwm2Regs.DBCTL.bit.OUT_MODE = DB_DISABLE; EPwm3Regs.DBCTL.bit.OUT_MODE = DB_DISABLE; EPwm4Regs.DBCTL.bit.OUT_MODE = DB_DISABLE; EPwm1Regs.GLDCTL2.bit.GFRCLD = 1; EPwm5Regs.ETSEL.bit.SOCAEN = 1; // 1 Enable the ADC Start of Conversion B (EPWMxSOCB) Pulse, Enable EPWMxSOCB pulse. EPwm5Regs.ETSEL.bit.SOCASEL = ET_CTR_ZERO; //PRD 触发ADC_B EPwm5Regs.ETPS.bit.SOCAPRD = ET_1ST; // EPwm1Regs.ETSEL.bit.INTEN = 1; // 1 Enable the ADC Start of Conversion B (EPWMxSOCB) Pulse, Enable EPWMxSOCB pulse. // EPwm1Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO; //PRD 触发ADC_B // EPwm1Regs.ETPS.bit.INTPRD = ET_1ST; EALLOW; CpuSysRegs.PCLKCR0.bit.TBCLKSYNC = 1; EDIS; }
以下为PWM转载代码:
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
void loadpwm()
F_SW = CC_PID.PIDU; //PI计算值
F_SW = __fmin(150,F_SW);
F_SW = __fmax(80,F_SW);
EPWMPeriod = 50000 / F_SW;
EPWMPeriod_DIV2 = EPWMPeriod / 2;
LLC_Hduty_EPWM = LLC_duty * EPWMPeriod_DIV2;
if( LLC_Hduty_EPWM > EPWMPeriod_DIV2 - 25 )
LLC_Hduty_EPWM = EPWMPeriod_DIV2 - 25;
EPWMPeriod = EPWM_Cal_SW / F_SW;
EPWMPeriod = EPWMPeriod_DIV2 * 2;
F_Int = 50;
T_Ctrl = 0.001f/F_Int;
EPwm3Regs.TBPRD = EPWMPeriod; //Period of TB = 10kHz
void loadpwm() { F_SW = CC_PID.PIDU; //PI计算值 F_SW = __fmin(150,F_SW); F_SW = __fmax(80,F_SW); EPWMPeriod = 50000 / F_SW; EPWMPeriod_DIV2 = EPWMPeriod / 2; LLC_Hduty_EPWM = LLC_duty * EPWMPeriod_DIV2; if( LLC_Hduty_EPWM > EPWMPeriod_DIV2 - 25 ) { LLC_Hduty_EPWM = EPWMPeriod_DIV2 - 25; } EPWMPeriod = EPWM_Cal_SW / F_SW; EPWMPeriod_DIV2 = EPWMPeriod / 2; EPWMPeriod = EPWMPeriod_DIV2 * 2; F_Int = 50; T_Ctrl = 0.001f/F_Int; EPwm3Regs.TBPRD = EPWMPeriod; //Period of TB = 10kHz EPwm4Regs.TBPRD = EPWMPeriod; //Period of TB = 10kHz EPwm3Regs.CMPA.bit.CMPA = EPWMPeriod_DIV2 - LLC_Hduty_EPWM; EPwm3Regs.CMPB.bit.CMPB = EPWMPeriod_DIV2 + LLC_Hduty_EPWM; EPwm4Regs.CMPA.bit.CMPA = EPWMPeriod_DIV2 - LLC_Hduty_EPWM; EPwm4Regs.CMPB.bit.CMPB = EPWMPeriod_DIV2 + LLC_Hduty_EPWM; EPwm1Regs.GLDCTL2.bit.OSHTLD = 1; }
