Other Parts Discussed in Thread: TI-CGT
电脑重启后simulink编译ccs代码功能失效,错误代码:We need to see this ENTIRE error message and a complete, reproducible test case including ALL of the command-line options. gmake: *** [poketbench_1.obj] Error 2 gmake: *** Waiting for unfinished jobs.... INTERNAL ERROR: C:/PROGRA~3/MATLAB/SUPPOR~1/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/bin/cl2000 had an internal inconsistency and aborted while processing file C:/Users/Administrator/Desktop/matlab仿真文件/poketbench_1_ert_rtw/MW_c28xx_pwm.c This is caused by a defect in the TI C/C++ Compiler. TI Customer Support may be able to suggest a workaround to avoid this. Upgrading to the newest version of the compiler may fix this problem. Contact TI in the E2E support forums at http://e2e.ti.com under "Development Tools", "TI C/C++ Compiler". See the link titled "Submitting an issue". We need to see this ENTIRE error message and a complete, reproducible test case including ALL of the command-line options. gmake: *** [MW_c28xx_pwm.obj] Error 2 INTERNAL ERROR: C:/PROGRA~3/MATLAB/SUPPOR~1/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/bin/cl2000 had an internal inconsistency and aborted while processing file C:/Users/Administrator/Desktop/matlab仿真文件/poketbench_1_ert_rtw/MW_c28xx_adc.c This is caused by a defect in the TI C/C++ Compiler. TI Customer Support may be able to suggest a workaround to avoid this. Upgrading to the newest version of the compiler may fix this problem. Contact TI in the E2E support forums at http://e2e.ti.com under "Development Tools", "TI C/C++ Compiler". See the link titled "Submitting an issue". We need to see this ENTIRE error message and a complete, reproducible test case including ALL of the command-line options. gmake: *** [MW_c28xx_adc.obj] Error 2
