DCA1000EVM: 无法读取FPGA的型号
Part Number: DCA1000EVM
根据DCA1000EVM使用指南 这个网站链接进行的操作
前面的操作都已经通过
然后目前已经进行的工作:
已经改了网络连接192.168.33.30,并且关闭了防火墙
板子连接是正确的
output如下:
GM: Constructor
GM: Sat Nov 12 22:13:47 2022
RSTD.Transmit("/Settings")
[22:13:47]
[22:13:47]  ### Running Startup script: "C:\Ti\mmwave_studio_02_01_01_00\mmWaveStudio\Scripts\Startup.lua" ###
[22:13:47]  RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[22:13:47]  RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[22:13:47]  Scripter ignored: Attempt to UnBuild() again or before Build.
[22:13:47]  RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\Ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\Clients\\\\LabClient.dll")
[22:13:47]  RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[22:13:47]  RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[22:13:47]  RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[22:13:47]  RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[22:13:47]  RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[22:13:47]  RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\Ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\RunTime\\SAL.dll")
[22:13:47]  RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[22:13:47]  RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[22:13:47]  RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[22:13:47]  RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[22:13:47]  RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[22:13:47]  RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[22:13:47]  RSTD.Transmit("/")
[22:13:47]  RSTD.SaveSettings(): Settings saved to "C:\Users\Amor\AppData\Roaming\RSTD\config.xml"
[22:13:47]  RSTD.Build()
[22:13:47]  RSTD.AL_Build()
[22:13:47]  RSTD.AL_LoadXml()
[22:13:47]  RSTD.AL_Init()
[22:13:47]  RSTD.Clients_Build()
[22:13:47]  GM: Init
[22:13:47]  GM: Loaded 'C:\Ti\mmwave_studio_02_01_01_00\mmWaveStudio\Clients\\LabClient.dll'
[22:13:47]  GM: 1 Guest (s) init
[22:13:47]  GM: 1 Module(s) init
[22:13:47]  GM: 2 Tab   (s) init
[22:13:47]  RSTD.Client_LoadXml()
[22:13:47]  [RadarAPI]: ar1.selectRadarMode(0)
[22:13:47]  [RadarAPI]: Status: Passed
[22:13:47]  Matlab Runtime Engine is installed
[22:13:47]  [RadarAPI]: Starting Matlab Engine..
[22:13:50]  [RadarAPI]: Matlab Engine Started!
[22:13:51]  [RadarAPI]: ar1.selectCascadeMode(0)
[22:13:51]  [RadarAPI]: Status: Passed
[22:13:51]  [RadarAPI]: ar1.LoadSettings('C:\Users\Amor\AppData\Roaming\RSTD\ar1gui.ini')
[22:13:52]  TESTING = false
[22:13:52]  RstdNet: Port 2777: Listening..
[22:13:52]
[22:13:52]  ***Script completed successfully.***
[22:13:54]  [RadarAPI]: Opening Gpio Control Port()
[22:13:54]  [RadarAPI]: Status: Passed
[22:13:55]  [RadarAPI]: Opening Board Control Port()
[22:13:55]  [RadarAPI]: Status: Passed
[22:13:56]  [RadarAPI]: ar1.FullReset()
[22:13:56]  [RadarAPI]: Status: Passed
[22:13:57]  [RadarAPI]: Closing Board Control Port()
[22:13:57]  [RadarAPI]: Status: Passed
[22:13:57]  [RadarAPI]: Closing Gpio Control Port()
[22:13:57]  [RadarAPI]: ar1.SOPControl(2)
[22:14:00]  [RadarAPI]: ar1.Connect(3,115200,1000)
[22:14:01]  [RadarAPI]: ar1.Calling_IsConnected()
[22:14:02]  [RadarAPI]: ar1.SelectChipVersion("AR1642")
[22:14:02]  [RadarAPI]: Status: Passed
[22:14:02]  [RadarAPI]: ar1.deviceVariantSelection("XWR1642")
[22:14:02]  [RadarAPI]: ar1.frequencyBandSelection("77G")
[22:14:02]  [RadarAPI]: ar1.SelectChipVersion("XWR1642")
[22:14:02]  Device Status : XWR1642/ASIL-B/SOP:2/ES:2
[22:14:02]  [RadarAPI]: ar1.SaveSettings('C:\Users\Amor\AppData\Roaming\RSTD\ar1gui.ini')
[22:14:05]  [RadarAPI]: ar1.DownloadBSSFw("C:\\Ti\\mmwave_studio_02_01_01_00\\rf_eval_firmware\\radarss\\xwr16xx_radarss.bin")
[22:14:05]  [RadarAPI]: Downloading BSS Patch RPRC Binary..
[22:14:13]  [RadarAPI]: ar1.GetBSSFwVersion()
[22:14:13]  [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
[22:14:13]  [RadarAPI]: ar1.GetBSSPatchFwVersion()
[22:14:13]  [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
[22:14:14]  [RadarAPI]: ar1.DownloadMSSFw("C:\\Ti\\mmwave_studio_02_01_01_00\\rf_eval_firmware\\masterss\\xwr16xx_masterss.bin")
[22:14:15]  [RadarAPI]: Downloading MSS RPRC Binary..
[22:14:26]  [RadarAPI]: ar1.GetMSSFwVersion()
[22:14:26]  [RadarAPI]: MSSFwVersion:(01.02.05.02 (16/07/19))
[22:14:27]  [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
[22:14:27]  [RadarAPI]: Status: Passed
[22:14:27]  MSS power up done async event received!
[22:14:30]  [RadarAPI]: ar1.SelectChipVersion("AR1642")
[22:14:30]  [RadarAPI]: Status: Passed
[22:14:30]  [RadarAPI]: ar1.SelectChipVersion("XWR1642")
[22:14:30]  Device Status : XWR1642/ASIL-B/SOP:2/ES:2
[22:14:30]  [RadarAPI]: ar1.RfEnable()
[22:14:30]  BSS power up done async event received!
[22:14:31]  [RadarAPI]: ar1.GetMSSFwVersion()
[22:14:31]  [RadarAPI]: MSSFwVersion:(01.02.05.02 (16/07/19))
[22:14:31]  [RadarAPI]: ar1.GetBSSFwVersion()
[22:14:31]  [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
[22:14:32]  [RadarAPI]: ar1.GetBSSPatchFwVersion()
[22:14:32]  [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
[22:14:39]  [RadarAPI]: ar1.ChanNAdcConfig(1, 1, 0, 1, 1, 1, 1, 2, 0, 0)
[22:14:39]  [RadarAPI]: Status: Passed
[22:14:42]  [RadarAPI]: ar1.LPModConfig(0, 1)
[22:14:42]  [RadarAPI]: Status: Passed
[22:14:45]  [RadarAPI]: ar1.RfInit()
[22:14:45]  RF Init async event received!
[22:14:45]  [RadarAPI]: Time stamp, Temperture: 14584,37; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 0, 0; RxIQMM Status, Update: 0, 0;
[22:14:45]  [RadarAPI]: Status: Passed
[22:14:46]  [RadarAPI]: ar1.SetCalMonFreqLimitConfig(77,81)
[22:14:46]  [RadarAPI]: Status: Passed
[22:14:51]  [RadarAPI]: ar1.DataPathConfig(513, 1216644097, 0)
[22:14:51]  [RadarAPI]: Status: Passed
[22:14:52]  [RadarAPI]: ar1.LvdsClkConfig(1, 1)
[22:14:52]  [RadarAPI]: Status: Passed
[22:14:54]  [RadarAPI]: ar1.LVDSLaneConfig(0, 1, 1, 0, 0, 1, 0, 0)
[22:14:54]  [RadarAPI]: Status: Passed
[22:15:01]  [RadarAPI]: ar1.ProfileConfig(0, 77, 100, 6, 60, 0, 0, 0, 0, 0, 0, 29.982, 0, 256, 10000, 0, 0, 30)
[22:15:01]  [RadarAPI]: Status: Passed
[22:15:03]  [RadarAPI]: ar1.ChirpConfig(0, 0, 0, 0, 0, 0, 0, 1, 0, 0)
[22:15:03]  [RadarAPI]: Status: Passed
[22:15:04]  Test Source Already Disabled...!!!
[22:15:04]  [RadarAPI]: ar1.DisableTestSource(0)
[22:15:04]  [RadarAPI]: Status: Passed
[22:15:04]  [RadarAPI]: ar1.FrameConfig(0, 0, 8, 128, 40, 0, 0, 1)
[22:15:08]  [RadarAPI]: ar1.GetCaptureCardDllVersion()
[22:15:08]  [RadarAPI]: Sending dll_version command to DCA1000
[22:15:08]  DLL Version : 1.0
[22:15:08]  [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
[22:15:08]  [RadarAPI]: Status: Passed
[22:15:12]  [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[22:15:12]  [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 2, 1, 2, 3, 30)
[22:15:12]  [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
[22:15:12]  [RadarAPI]: Sending fpga command to DCA1000
[22:15:23]  [RadarAPI]:
[22:15:23]  FPGA Configuration :
[22:15:23]  Timeout Error! System disconnected
[22:15:23]  [RadarAPI]: Sending record command to DCA1000
[22:15:33]  [RadarAPI]:
[22:15:33]  Configure Record :
[22:15:33]  Timeout Error! System disconnected
[22:15:33]  [RadarAPI]: ar1.GetCaptureCardFPGAVersion()
[22:15:33]  [RadarAPI]: Sending fpga_version command to DCA1000
[22:15:43]  [RadarAPI]:
[22:15:43]
[22:15:43]  Unable to read FPGA Version. [error -5]
[22:15:43]
