Part Number: LAUNCHXL-CC26X2R1
Other Parts Discussed in Thread: UNIFLASH, CC2538
使用tiarmobjcopy将 simple_peripheral_CC26X2R1_LAUNCHXL_tirtos7_ticlang.hex 转化为bin(352KB)文件,并使用unflash指定起始位置为0x30000烧录,结果设备被锁,无法继续刷写flash。
使用UniFlash全部擦书flash也无法恢复正常
windows设备管理器依然能够识别XDS110 com口
使用 异常开发板的XDS连接 正常的开发板的cc2642r1芯片可以进行flash刷写,因此怀疑是CC2642r1芯片被锁
错误log如下:
CCS:
IcePick_C: Error connecting to the target: (Error -241 @ 0x0) A router subpath could not be accessed. A security error has probably occurred. Make sure your device is unlocked. (Emulation package 9.10.0.00080)
UniFlash:
