CC2642R: cc2642串口配置相关问题请教
Part Number: CC2642R
Other Parts Discussed in Thread: SYSCONFIG, LAUNCHXL-CC26X2R1
我在使用ccs的配置工具配置完串口1时并未找到波特率和回调函数相关的配置,同时想问串口如果初始化相关的函数名称是什么.
望解答Rose
  • 你好,
    1.波特率的配置
    https://e2echina.ti.com/support/wireless-connectivity/bluetooth/f/bluetooth-forum/201641/cc2642-syscfg-uart
    2.是要用sysconfig配置回调函数吗?哪个函数
    3.
    UART_init() 的function描述在如下link中
    https://software-dl.ti.com/simplelink/esd/simplelink_cc2640r2_sdk/2.20.00.49/exports/docs/tidrivers/doxygen/html/_u_a_r_t_8h.html#ab60a36f7295d704926120d22f806dcd1
    // Import the UART driver definitions
    #include <ti/drivers/UART.h>
    // One-time initialization of UART driver
    UART_init();
    // Initialize UART parameters
    UART_Params params;
    UART_Params_init(&params);
    params.baudRate = 9600;
    params.readMode = UART_MODE_BLOCKING;
    params.writeMode = UART_MODE_BLOCKING;
    params.readTimeout = UART_WAIT_FOREVER;
    params.writeTimeout = UART_WAIT_FOREVER;
  • static void writeCallback(UART_Handle handle, void *rxBuf, size_t size)
        // Do nothing
    int uarttree = 0;
    static void readCallback(UART_Handle handle, void *rxBuf, size_t size)
        // // Make sure we received all expected bytes
        // if (size == 16) {
        //     // Copy bytes from RX buffer to TX buffer
        //    for(size_t i = 0; i < size; i++)
        //        txBuf[i] = ((uint8_t*)rxBuf)[i];
        //    // Echo the bytes received back to transmitter
        //    UART_write(handle, txBuf, size);
        //    // Start another read, with size the same as it was during first call to
        //    // UART_read()
        //    UART_read(handle, rxBuf, 16);
        // else {
        //     // Handle error or call to UART_readCancel()
        uarttree ++;
    void fp_init(void)
        UART_Handle handle;
        UART_Params params;
        /* 相关串口初始化 */
        UART_init();
        params.baudRate      = 115200;
        params.writeMode     = UART_MODE_CALLBACK;
        params.writeDataMode = UART_DATA_BINARY;
        params.writeCallback = writeCallback;
        params.readMode      = UART_MODE_CALLBACK;
        params.readDataMode  = UART_DATA_BINARY;
        params.readCallback  = readCallback;
        handle = UART_open(CONFIG_FP_UART, &params);
        // Do nothing
    int uarttree = 0;
        //    // UART_read()
        // else {
        uarttree ++;
    void fp_init(void)
        UART_Handle handle;
        UART_Params params;
        /* 相关串口初始化 */
        UART_init();
        // Do nothing
    int uarttree = 0;
        //    // UART_read()
        // else {
        uarttree ++;
    void fp_init(void)
        UART_Handle handle;
        UART_Params params;
        /* 相关串口初始化 */
        UART_init();
        // Do nothing
    int uarttree = 0;
        //    // UART_read()
        // else {
        uarttree ++;
    void fp_init(void)
        UART_Handle handle;
        UART_Params params;
        /* 相关串口初始化 */
        UART_init();
        // Do nothing
    int uarttree = 0;
        //    // UART_read()
        // else {
        uarttree ++;
    void fp_init(void)
        UART_Handle handle;
        UART_Params params;
        /* 相关串口初始化 */
        UART_init();
        // Do nothing
    int uarttree = 0;
        //    // UART_read()
        // else {
        uarttree ++;
    void fp_init(void)
        UART_Handle handle;
        UART_Params params;
        /* 相关串口初始化 */
        UART_init();
        // Do nothing
    int uarttree = 0;
        //    // UART_read()
        // else {
        uarttree ++;
    void fp_init(void)
        UART_Handle handle;
        UART_Params params;
        /* 相关串口初始化 */
        UART_init();
    int uartTemp = 0;
        // Do nothing
        uartTemp ++;
    void fp_init(void)
        UART_Handle handle;
        UART_Params params;
        /* 相关串口初始化 */
        UART_init();
    您好上述是我的代码,我在配置完串口后,通过串口助手给芯片发送消息,我在其中一个任务中不断查看uartTemp 的值,发现其一直为零,串口并未进入接收中断.
  • 你好,
    1.首先你需要检查你的串口引脚和串口助手是否正确连接,并且稳定
    然后你的芯片的串口配置是否正常。
    2.你可以把do nothing 添加打印语句进行调试
         uartTemp++;
    printf("Received data: %s\n",(char *)rxBuf);
    以此来验证是否触发回调函数
    3.请问你具体是要通过这个串口做什么事情?
  • 这个串口连接传感器进行通讯
  • 刚尝试了下,writeCallback和串口发送正常,串口中断依旧无反应
  • 我需要硬件中断触发串口读取回调函数readCallback
  • 1.你可以使用 PIN 驱动程序,
    2.考虑在 GAP 角色处于活动状态时不要对 UART 使用blocking mode
  • 需要一些时间,谢谢
  • 我发现问题了,
    DIO29作为RX引脚,通过串口助手给其发送消息该引脚一致为低电平,后将程序烧录到LAUNCHXL-CC26X2R1开发板中该引脚同样为低电平不变.
    这是我串口中的引脚配置
  • 好,有问题欢迎再来论坛交流
  • 我更换rx引脚后,通过串口助手发送数据,逻辑分析仪查看RX引脚波形,发现全程依旧为低电平
  • 你烧录的程序是哪个?
  • 我烧录的程序是公司的代码,将该程序烧录至ti开发板上,对rx引脚输入高电平其并未变高
