Part Number: DS90UB948-Q1
Test the quality of the eye diagram under different LVDS signal cable length conditions: test experiment 1 and test experiment 2 set the same EQ level range and the same STROBE position range, the test results are not what I expected, why is it that the longer the length of the LVDS signal cable, the better the quality of the eye diagram, and the shorter the length of the LVDS signal cable connection. The test results are as follows. In addition, I would like to know what parameters are used to judge the eye diagram results, and whether they are related to the EQ and the strobe position values? What is the relationship between them?
