Hello:
I'd like to summarize my problem by measuring the parameters of your company's TS3USB30E -3DB bandwidth right now.
According to the measurement method provided in your company's specifications, it is to continuously increase the signal frequency at the input end until 900Mhz to observe whether the output amplitude becomes 0.707;
However, due to the limited equipment of our test equipment, the signal generator we use can only increase the signal frequency up to 350Mhz, which makes this parameter difficult to measure; I also know whether the spectrum analyzer can be used to observe this parameter, but according to your company's requirements, you need to add a DC bias of 350mv at the same time, and the spectrum analyzer isolates DC.
1. Therefore, it is not possible to measure this parameter, how does your company measure this parameter?
2. What instruments and equipment are used, can you describe the test method in detail, how to give the signal and add bias?
3. Can we give some solutions to our current situation?
