TMS320F28075: Missing Clock Detect测试不通过
Part Number: TMS320F28075
你好,TI的技术专家
      我使用的MCU是TMS320F28075PZP(100PIN),测试MCD不通过,使用的是C2000Ware库,版本C2000Ware_4_02_00_00,问题详细描述在英文技术论坛已发,请参考
      https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/1166767/tms320f28075-missing-clock-detection-no-work?tisearch=e2e-sitesearch&keymatch=MCD#
      目前的问题是,设置了OSCOFF(SysCtl_disconnectMCDClockSource();就是这条语句),MCDCR寄存器的bit0,即MCDSTS flag没有变1,也就是说没有检查到时钟丢失。用的是库里面的示例程序。
// FILE:  sta_main.c
// TITLE: Self Test Application Main source
// $TI Release: F2807x Diagnostic Library v1.00.02.00 $
// $Release Date: Mon Dec 18 17:00:32 CST 2017 $
// $Copyright:
// Copyright (C) 2016-2017 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
//   Redistributions of source code must retain the above copyright
//   notice, this list of conditions and the following disclaimer.
//   Redistributions in binary form must reproduce the above copyright
//   notice, this list of conditions and the following disclaimer in the
//   documentation and/or other materials provided with the
//   distribution.
//   Neither the name of Texas Instruments Incorporated nor the names of
//   its contributors may be used to endorse or promote products derived
//   from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included files for device configuration
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "driverlib.h"
#include "device.h"
#include "F2807x_device.h"
#include "F021_F2837xD_C28x.h"
// Included files for test-infrastructure.
#include "sta_timer.h"
#include "sta_tests.h"
#include "sta_comm.h"
// Globals
int16_t enableErrorInject;
int16_t enableReset;
volatile bool nmiISRFlag = false;
uint16_t nmiStatus = 0U;
bool mcdDetect = false;
uint32_t result = 1;
uint32_t fail = 0U;
// Prototypes
void STA_Main_configXCLKOut(void);
Fapi_StatusType STA_Main_initFlashAPI(void);
#ifdef _FLASH
// These are defined by the linker (see device linker command file)
extern uint16_t RamfuncsLoadStart;
extern uint16_t RamfuncsLoadSize;
extern uint16_t RamfuncsRunStart;
extern uint16_t HwbistLoadStart;
extern uint16_t HwbistLoadSize;
extern uint16_t HwbistRunStart;
#endif
// Function Prototypes
__interrupt void nmi_isr(void);
// Main
void main(void)
#ifdef _FLASH
    memcpy(&HwbistRunStart, &HwbistLoadStart, (size_t)&HwbistLoadSize);
#endif
    unsigned char *msg;
    uint16_t testIndex = 0;
    Fapi_StatusType statusFlashAPI =  Fapi_Status_Success;
    enableErrorInject = 0;
    uint16_t nmiWatchdogPeriod = 0x1000;
    // Configure PLL, disable WD, enable peripheral clocks.
    Device_init();
    // Disable pin locks and enable internal pull-ups.
    Device_initGPIO();
    //added by yang for debug
    GPIO_setPinConfig(GPIO_43_GPIO43);
    GPIO_setDirectionMode(43,GPIO_DIR_MODE_OUT);
    GPIO_setPadConfig(43,GPIO_PIN_TYPE_STD);
    GPIO_writePin(43,1);
    // Put watchdog in interrupt mode.
    SysCtl_setWatchdogMode(SYSCTL_WD_MODE_INTERRUPT);
 //   statusFlashAPI = STA_Main_initFlashAPI();
 //   if(statusFlashAPI != Fapi_Status_Success)
 //       ESTOP0;
    // Disable global interrupts.
    DINT;
    // Initialize interrupt controller and vector table.
    Interrupt_initModule();
    Interrupt_initVectorTable();
    SysCtl_clearAllNMIFlags();
    Interrupt_register(INT_NMI, &nmi_isr);
    SysCtl_setNMIWatchdogPeriod(nmiWatchdogPeriod);
    // Enabling the NMI global interrupt (typically already enabled by boot ROM
    // or GEL file).
    EALLOW;
    HWREGH(NMI_BASE + NMI_O_CFG) |= NMI_CFG_NMIE;
    EDIS;
    Interrupt_enable(INT_NMI);
    EINT;
    ERTM;
    if(SysCtl_getClock(DEVICE_OSCSRC_FREQ) != DEVICE_SYSCLK_FREQ)
       fail++;
    SysCtl_enableMCD();
    fail=3;
    while(nmiISRFlag != true)
        fail++;
    fail=5;
    // A missing clock was detected.
    if(mcdDetect != true)
        fail++;
    // Check if the NMI triggered was due to a clock failure.
    if((nmiStatus & SYSCTL_NMI_CLOCKFAIL) != SYSCTL_NMI_CLOCKFAIL)
        fail++;
    // Check the PLL System clock after the Missing clock detection
    // is simulated. It should be equal to INTOSC1(10Mhz).
    if(SysCtl_getClock(DEVICE_OSCSRC_FREQ) != SYSCTL_DEFAULT_OSC_FREQ)
        fail++;
    // To lock the PLL after missing clock detection, we first explicitly
        // switch the clock source to INTOSC1, reset the missing clock detect
        // circuit, and then re-lock the PLL.
        // Configure oscillator source to INTOSC1.
    SysCtl_selectOscSource(SYSCTL_OSCSRC_OSC1);
    SysCtl_connectMCDClockSource();
    // Reset the missing clock detection logic after clock failure.
    SysCtl_resetMCD();
    // Set up PLL control and clock dividers using the original clock source.
    SysCtl_setClock(DEVICE_SETCLOCK_CFG);
    // Check the system clock after the missing clock detection is cleared
    // and handled using INTOSC1 as clock source.
       fail++;
    // Status of a successful handling of missing clock detection.
    if(fail != 0U)
       result = 1;    //fail
    //   GPIO_writePin(43,0);
    else
       result = 0;   //pass
    while(1);
    // Debug
   // STA_Main_configXCLKOut();
    // Configure SCI A as the main communication port
  //  STA_Comm_configSCIA();
    // Configure Timer 0 as the main time-out timer
  //  STA_Timer_config(4000U);
//#if STA_UTIL_PROFILE
//    STA_Util_configProfiler(CPUTIMER1_BASE);
//#endif
    // Enable Global Interrupt (INTM) and real time interrupt (DBGM)
//    EINT;
//    ERTM;
    // Send starting message.
 //   msg = "\r\n\n\nBegin Test\0";
//    STA_Comm_transmitData(msg);
 /*   for(;;)
        if(STA_Timer_isTimedOut())
            if(enableErrorInject)
                STA_Tests_injectErrorEnable();
            else
                STA_Tests_injectErrorDisable();
            if(enableReset)
                STA_Tests_enableReset();
            else
                STA_Tests_disableReset();
                     STA_Tests_testDevice(STA_Tests_testArray[testIndex++]));
            if(testIndex >= STA_TESTS_NUMBERS)
                testIndex = 0U;
            STA_Timer_restart();
// STA_Main_configXCLKOut(void)
    // Configure GPIO 73 as SYSCLK out
    GPIO_setPadConfig(73,GPIO_PIN_TYPE_STD);
    GPIO_setPinConfig(GPIO_73_XCLKOUT);
    // Clock source is SYSCLK
    SysCtl_selectClockOutSource(SYSCTL_CLOCKOUT_SYSCLK);
    EALLOW;
    // XCLOCK out = clock source /8
    HWREG(CLKCFG_BASE + SYSCTL_O_XCLKOUTDIVSEL) = 3U;
    EDIS;
// STA_Main_initFlashAPI(void)
#pragma CODE_SECTION(STA_Main_initFlashAPI, ".TI.ramfunc");
    Fapi_StatusType returnStatus;
    // Disable ECC when initializing the Flash API
    Flash_disableECC(FLASH0ECC_BASE);
    EALLOW;
    // This function is required to initialize the Flash API based on System
    // frequency before any other Flash API operation can be performed
    returnStatus = Fapi_initializeAPI(F021_CPU0_BASE_ADDRESS,
                                      DEVICE_SYSCLK_FREQ / 1000000U);
    EDIS;
    return(returnStatus);
// nmiISR -  The interrupt service routine called when the NMI
//           is generated on clock failure detection.
    nmiISRFlag = true;
    mcdDetect = SysCtl_isMCDClockFailureDetected();
    nmiStatus = SysCtl_getNMIFlagStatus();
// End of File
  • 你好,由于您在英文论坛发了帖,建议您在英文论坛等待回复,将有资深的工程师为您提供帮助。我们的E2E英文社区有TI专家进行回复,并得到全球各地工程师的支持,分享他们的知识和经验。
