[参考译文] TMS320F28388D:关于在使用 IPC 消息队列时 CM4到 CPU1无法进入中断的问题
Guru**** 2964200 points
https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/1264371/tms320f28388d-about-the-problem-that-cm4-to-cpu1-cannot-enter-the-interrupt-when-using-the-ipc-message-queue
器件型号:TMS320F28388D
客户有问题需要您的帮助:
原始代码内容:
// FILE:   ipc_ex2_msgqueue_cm.c
// TITLE:  IPC example with interrupt and message queue
//! \addtogroup driver_cm_c28x_dual_example_list
//! <h1> IPC message passing example with interrupt and message queue </h1>
//! This example demonstrates how to configure IPC and pass information from
//! C28x to CM core with message queues.
//! It is recommended to run the C28x1 core first, followed by the CM core.
//! \b External \b Connections \n
//!  - None.
//! \b Watch \b Variables \n
//!  - None.
// $Copyright:
// Copyright (C) 2022 Texas Instruments Incorporated - http://www.ti.com
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
//   Redistributions of source code must retain the above copyright
//   notice, this list of conditions and the following disclaimer.
//   Redistributions in binary form must reproduce the above copyright
//   notice, this list of conditions and the following disclaimer in the
//   documentation and/or other materials provided with the
//   distribution.
//   Neither the name of Texas Instruments Incorporated nor the names of
//   its contributors may be used to endorse or promote products derived
//   from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "cm.h"
#include "ipc.h"
// Defines
#define IPC_CMD_READ_MEM   0x1001
#define IPC_CMD_RESP       0x2001
#define TEST_PASS          0x5555
#define TEST_FAIL          0xAAAA
IPC_MessageQueue_t messageQueue;
#pragma DATA_SECTION(CMData, "MSGRAM_CM_TO_CPU1")
uint32_t CMData[10];
// IPC ISR for Flag 1
// C28x core sends data with message queue using Flag 0
__interrupt void IPC_ISR1()
    int i;
    IPC_Message_t TxMsg, RxMsg;
    bool status = false;
    // Read the message from the message queue
    IPC_readMessageFromQueue(IPC_CM_L_CPU1_R, &messageQueue, IPC_ADDR_CORRECTION_ENABLE,
                             &RxMsg, IPC_NONBLOCKING_CALL);
    if(RxMsg.command == IPC_CMD_READ_MEM)
        status = true;
        // Read and compare data
        for(i=0; i<RxMsg.dataw1; i++)
            if((*(uint32_t *)RxMsg.address + i) != i)
                status = false;
    // Send response message
    TxMsg.command = IPC_CMD_RESP;
    TxMsg.address = (uint32_t)CMData;
    TxMsg.dataw1  = 10;
    TxMsg.dataw2  = 1;
    IPC_sendMessageToQueue(IPC_CM_L_CPU1_R, &messageQueue, IPC_ADDR_CORRECTION_ENABLE,
                           &TxMsg, IPC_NONBLOCKING_CALL);
    // Acknowledge the flag
    IPC_ackFlagRtoL(IPC_CM_L_CPU1_R, IPC_FLAG1);
// Main
void main(void)
    // Initialize device clock and peripherals
    CM_init();
    // Clear any IPC flags if set already
    IPC_clearFlagLtoR(IPC_CM_L_CPU1_R, IPC_FLAG_ALL);
    // Enable IPC interrupts
    IPC_registerInterrupt(IPC_CM_L_CPU1_R, IPC_INT1, IPC_ISR1);
    // Initialize message queue
    IPC_initMessageQueue(IPC_CM_L_CPU1_R, &messageQueue, IPC_INT1, IPC_INT1);
    // Synchronize both the cores.
    IPC_sync(IPC_CM_L_CPU1_R, IPC_FLAG31);
    int i;
    for(i=0; i<10; i++)
        CMData[i] = i+11;
    // Loop forever. Wait for IPC interrupt
    while(1);
// End of File
// FILE:   ipc_ex2_msgqueue_c28x1.c
//!  - None.
//!  - pass
// $Copyright:
// are met:
//   distribution.
// Included Files
#include "driverlib.h"
#include "device.h"
// Defines
#pragma DATA_SECTION(CPU1Data, "MSGRAM_CPU_TO_CM")
uint32_t CPU1Data[10];
uint32_t pass;
    int i;
    IPC_readMessageFromQueue(IPC_CPU1_L_CM_R, &messageQueue, IPC_ADDR_CORRECTION_ENABLE,
    if(RxMsg.command == IPC_CMD_RESP)
        status = true;
           if((*(uint32_t *)RxMsg.address + i) != i+11)
                       status = false;
    TxMsg.command = IPC_CMD_READ_MEM;
    TxMsg.address = (uint32_t)CPU1Data;
    TxMsg.dataw1  = 10;  // Using dataw1 as data length
    TxMsg.dataw2  = 1;   // Message identifier
    IPC_sendMessageToQueue(IPC_CPU1_L_CM_R, &messageQueue, IPC_ADDR_CORRECTION_ENABLE,
    IPC_ackFlagRtoL(IPC_CPU1_L_CM_R, IPC_FLAG1);
    Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP11);
// Main
void main(void)
    int i;
    Device_init();
    // Boot CM core
#ifdef _FLASH
    Device_bootCM(BOOTMODE_BOOT_TO_FLASH_SECTOR0);
#else
    Device_bootCM(BOOTMODE_BOOT_TO_S0RAM);
#endif
    // Initialize PIE and clear PIE registers. Disables CPU interrupts.
    Interrupt_initModule();
    // Initialize the PIE vector table with pointers to the shell Interrupt
    // Service Routines (ISR).
    Interrupt_initVectorTable();
    IPC_clearFlagLtoR(IPC_CPU1_L_CM_R, IPC_FLAG_ALL);
    IPC_registerInterrupt(IPC_CPU1_L_CM_R, IPC_INT1, IPC_ISR1);
    IPC_initMessageQueue(IPC_CPU1_L_CM_R, &messageQueue, IPC_INT1, IPC_INT1);
    IPC_sync(IPC_CPU1_L_CM_R, IPC_FLAG31);
    // Enable Global Interrupt (INTM) and realtime interrupt (DBGM)
    EINT;
    ERTM;
    // Fill in the data to be sent
    for(i=0; i<10; i++)
        CPU1Data[i] = i;
    // Update the message
    // Send message to the queue
    // Since C28x and CM does not share the same address space for shared RAM,
    // ADDRESS_CORRECTION is enabled
    // End of example. Loop forever
    while(1);
// End of File
修改:
1.在 CM4内核的 while 循环中、我一直向 CPU1发送消息、但发现 CPU1不能重复进入中断。 原因是什么?
    while(1)
        TxMsg.dataw1  = 10;
        TxMsg.dataw2  = 1;
2.我想问一下如何理解消息队列的阻塞和非阻塞方法? 也就是说、 根据要选择的情况、我不理解 IPC_nONBLOCKING_CALL 和 IPC_BLOCKING_CALL 这两种方式?
谢谢。此致、
本
    ISR 是否触发一次、而不是再次触发? 我将在明天尝试提供有关 IPC Message Queue 工作方式的更多信息。
    本·科利尔
    尊敬的 Benjamin:
    有任何更新吗?
    本
    Ben、您好!
    本杰明目前不在办公室,但他应该能够在下周星期三之前回复你。 很抱歉耽误你的时间。
    阿米尔·奥马尔
    尊敬的 Ben:
    很抱歉耽误你的时间。 您是否能够确认 客户是否能够至少进入 ISR 一次?
    关于'block '参数,我认为最好的理解是 在 ipc.c 中阅读 IPC_sendMessageToQueue()和 IPC_readMessageFromQueue()函数:
    如果 Put 缓冲区已满,这看起来像非阻塞调用会使 IPC_sendMessageToQueue()函数立即失败。 blocking 参数将使函数等待、直到 Put 缓冲区槽空闲。
    我认为这在实践中意味着 如果没有 IPC_readMessageFromQueue(),IPC_sendMessageToQueue()就不能多次使用 ,否则队列将被填满。 阻塞呼叫将等待(可能永远)队列有空间、而非阻塞呼叫将在队列已满时立即失败。
    本·科利尔
    尊敬的 Benjamin:
    感谢您的回复!
    您 是否能够确认客户是否能够至少输入一次 ISR?  [/报价]
    可以、但只能进入第一个 ISR。
    本
    Ben、
      在 ISR 已经被触发一次之后、客户是否能够在他们的内存浏览器中检查针对 CM 消息队列的 Put 缓冲区的内容? 此外,他们是否能够进入他们的 IPC_sendMessageToQueue()函数来查看函数内部的情况? 它们是否使其通过了上面的屏幕截图中的 while 循环? 函数第一次运行和后续运行之间是否有任何不同?
    本·科利尔
    尊敬的 Benjamin:
    现在、我只执行 cm 来发送 IPC 消息、使用 CPU1中断来读取消息、通过将两个内核上的点断开来查看 writeIndex 和 readIndex。
    验证过程:
    1. CM   首次执行 IPC_sendMessageToQueue()函数后,CPU1进入 IPC 中断,但不进入  IPC_readMessageToQueue()。
    如以上两幅图所示、cm 的 PutWriteIndex 和 CPU1的 GetWriteIndex 均为 add 1。
    2.在 CM   首次执行 IPC_sendMessageToQueue()函数后,CPU1进入 IPC 中断并 执行 IPC_readMessageToQueue()。
    当 CPU1执行  IPC_readMessageToQueue()时,  CM 的 PutReadIndex 和 CPU1的 GetReadIndex 都将递增1
    根据上述两个验证结果可以重复执行 IPC 的消息队列、代码没有问题。
    我以前无法重复该中断的原因是、我仅在 CPU1的 IPC 中断中设置了一个断点、而 CM 没有设置断点、这会导致 CM 继续发送 IPC 消息。 在 PutBuffer 已满并在 IPC_sendMessageToQueue()函数的 while 循环中执行之前,CPU1未进行读取,因此 CPU1无法重复输入中断来读取消息。
    对于阻塞呼叫和非阻塞呼叫、如果发送方使用阻塞呼叫持续发送数据、而接收方使用阻塞接收、当发送方的 PutBuffer 已满时、发送方和接收方将进入 while 循环、导致两者工作不正常、 如果其中一个端使用非阻塞调用,则该端可以继续执行其他任务。 我的理解是否正确?
    本
    尊敬的 Ben:
    您的理解是正确的。 如果您有任何其他问题、请告诉我。
    本·科利尔
