最近在用28388的以太网接口与电脑通信。由于以太网只能用CM核心访问,所以得实现从CPU到CM核的通信。
C2000ware例程里面ex1是从CPU1发送指令到CM。调试时候发现直接换成CM到CPU1会有一些问题。
感觉注释写的挺详细的。就不过多解释了。给需要的人参考一下。
CPU1的代码:
//此文件改编于F28388的C2000ware的IPC例程ex1
//原文件是从CPU1发指令到CM。此文件从CM发指令到CPU1
// FILE: ipc_ex1_basic_c28x1.c
// TITLE: IPC example with interrupt
//! \addtogroup driver_cm_c28x_dual_example_list
//! <h1> IPC basic message passing example with interrupt </h1>
//! This example demonstrates how to configure IPC and pass information from
//! C28x to CM core without message queues.
//! It is recommended to run the C28x1 core first, followed by the CM core.
//! \b External \b Connections \n
//! - None.
//! \b Watch \b Variables \n
//! - pass
// $Copyright:
// Copyright (C) 2022 Texas Instruments Incorporated - http://www.ti.com
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "driverlib.h"
#include "device.h"
// 定义了两个指令数字,其实是随机的。文件里只用到了IPC_CMD_READ_MEM
#define IPC_CMD_READ_MEM 0x1001
#define IPC_CMD_RESP 0x2001
//就是俩指示符
#define TEST_PASS 0x5555
#define TEST_FAIL 0xAAAA
//IPC传输位32位数字。这里定义32问数组,大小为10
uint32_t readData[10];
uint32_t pass;
uint32_t data;//data为readData[10]长度,这里应该是10
__interrupt void IPC_ISR0()
uint8_t i;
uint32_t command, addr;
bool status = false;
// CPU1从CM读取指令。由于CPU1和CM内核共享区域不是共用地址的,所以得enable correction
// command读出来的就是IPC_CMD_READ_MEM
// addr是转化过来的存储数据的起始地址
// data是数组长度
IPC_readCommand(IPC_CPU1_L_CM_R, IPC_FLAG1, IPC_ADDR_CORRECTION_ENABLE,
&command, &addr, &data);
if(command == IPC_CMD_READ_MEM)//如果读出来的指令是IPC_CMD_READ_MEM
status = true;//把状态定义为true
// 由于读到的数据是起始位addr,32位数据,data长度的数组
// 以下操作吧数据写进read
// 可以用CCS的watch variable实时观察数据变化
for(i=0; i<data; i++)
readData[i] = *((uint32_t *)addr + i);
// 将读数正确或者错误信息返回给CM
if(status)
IPC_sendResponse(IPC_CPU1_L_CM_R, TEST_PASS);
else
IPC_sendResponse(IPC_CPU1_L_CM_R, TEST_FAIL);
// Acknowledge the flag
IPC_ackFlagRtoL(IPC_CPU1_L_CM_R, IPC_FLAG1);
//这个是必须得加的。接收中断如果在CM里面,不用有这句
//如果接收中断在C28x内核(CPU1和CPU2),就得加上这句
Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP11);
// Main
void main(void)
// Initialize device clock and peripherals
Device_init();
// Boot CM core
#ifdef _FLASH
Device_bootCM(BOOTMODE_BOOT_TO_FLASH_SECTOR0);
#else
Device_bootCM(BOOTMODE_BOOT_TO_S0RAM);
#endif
// Initialize PIE and clear PIE registers. Disables CPU interrupts.
Interrupt_initModule();
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
Interrupt_initVectorTable();
// Clear any IPC flags if set already
IPC_clearFlagLtoR(IPC_CPU1_L_CM_R, IPC_FLAG_ALL);
// Enable IPC interrupts
IPC_registerInterrupt(IPC_CPU1_L_CM_R, IPC_INT1, IPC_ISR0);
// Synchronize both the cores.
IPC_sync(IPC_CPU1_L_CM_R, IPC_FLAG31);
// Enable Global Interrupt (INTM) and realtime interrupt (DBGM)
EINT;
ERTM;
// End of example. Loop forever
while(1)
// End of File
CM代码
////此文件改编于F28388的C2000ware的IPC例程ex1
// FILE: ipc_ex1_basic_cm.c
//! - None.
//! - None.
// $Copyright:
// are met:
// distribution.
// Included Files
#include "cm.h"
#include "ipc.h"
//readData是要传输给CPU1的数据。要注意数组长度。MSGRAM_CM_TO_CPU1内存长度只有800
uint32_t readData[10]={11,12,13,14,15,16,17,18,19,20};
//MSGRAM_CM_TO_CPU1是从cmd文件里面查出来的
//这是把readData的首地址放到了MSGRAM_CM_TO_CPU1内存块里面
//由于要进行地址变换,这句话是放在发送的那个核心里面。
#pragma DATA_SECTION(readData, "MSGRAM_CM_TO_CPU1")
// Main
void main(void)
int i;
uint32_t pass;
CM_init();
// Loop forever. Wait for IPC interrupt
IPC_clearFlagLtoR(IPC_CM_L_CPU1_R, IPC_FLAG_ALL);
IPC_sync(IPC_CM_L_CPU1_R, IPC_FLAG31);
// 循环发送数字给CPU1
while(1)
SysCtl_delay(6000000);//等待一下,要不然发送太频繁了
// CM往CPU1发送数字。由于CPU1和CM内核共享区域不是共用地址的,所以得enable correction
// readData传输的是首地址
// 10是readData数组长度
IPC_sendCommand(IPC_CM_L_CPU1_R, IPC_FLAG1, IPC_ADDR_CORRECTION_ENABLE,
IPC_CMD_READ_MEM, (uint32_t)readData, 10);
// Wait for acknowledgment
IPC_waitForAck(IPC_CM_L_CPU1_R, IPC_FLAG1);
// Read response
if(IPC_getResponse(IPC_CM_L_CPU1_R) == TEST_PASS)
pass = 1;
else
pass = 0;
//持续让数据增加
//这样就可以用CCS的watch variable实时观察数据变化,判断程序是否持续运行
for(i=0; i<10; i++)
readData[i]++;
// End of File
