  • [参考译文] TXS0108E:反相输出类型
    Other Parts Discussed in Thread: SN74LV6T14, SN74LXC1T14, SN74LV1T04, TXS0108E
    https://e2e.ti.com/support/logic-group/logic/f/logic-forum/1455160/txs0108e-inverting-output-type
    器件型号:TXS0108E
    主题中讨论的其他器件…
  • [参考译文] TXS0108E-Q1:数据表和产品页面之间的高输入电压(min)差异
    Other Parts Discussed in Thread: TXS0108E
    https://e2e.ti.com/support/logic-group/logic/f/logic-forum/1455008/txs0108e-q1-high-input-voltage-min-differences-between-data-sheet-and-product-page
  • [参考译文] TXS0108E:物料数据表变更比较申请(修订版 I 至 L)
    https://e2e.ti.com/support/logic-group/logic/f/logic-forum/1454927/txs0108e-request-for-comparison-of-changes-in-material-data-sheets-rev-i-to-l
    器件型号:
  • [参考译文] TXS0108E:TXS0108E 输出低电平不为0V
    Other Parts Discussed in Thread: TXS0108E, TCA9509
    https://e2e.ti.com/support/logic-group/logic/f/logic-forum/1449179/txs0108e-txs0108e-output-low-level-is-not-0v
    器件型号:TXS0108E
    主题中讨论的其他器件: TCA…
  • [参考译文] SN74LV1T125:5V ->1.8V 放大器;1.8V ->5V 电平转换
    Other Parts Discussed in Thread: SN74LXC8T245, TXU0104, TXU0204, SN74AHCT244, TXS0108E, TXV0106, TXV0108, SN74AXC8T245
    https://e2e.ti.com/support/logic-group/logic/f/logic-forum/1444369/sn74lv1t125…
  • [参考译文] TXS0108E:问题
    https://e2e.ti.com/support/logic-group/logic/f/logic-forum/1445128/txs0108e-questions
    器件型号:TXS0108E
    工具与软件:
    尊敬的专家:
    客户使用了 TXS0108ENMER 并找到了一个脉冲1 WL_REG_ON。 您是否有任何想法、原因可能是什么?
    解决了
  • [参考译文] TXU0304:具有多个从 GPIO 的 SPI 驱动器
    Other Parts Discussed in Thread: TXV0108, TXU0102, TXU0304, LSF0108, TXV0106, TXU0104, TXU0202, TXS0108E
    https://e2e.ti.com/support/logic-group/logic/f/logic-forum/1430617/txu0304-spi-driver-with…
  • [参考译文] TXS0108E:电平转换器
    Other Parts Discussed in Thread: TXB0106
    https://e2e.ti.com/support/logic-group/logic/f/logic-forum/1427281/txs0108e-level-shifter
    器件型号:TXS0108E
    主题中讨论的其他器件:TXB0106
    工具与软件:
    尊敬的团队:
    来自印度 Dialtronics…
  • [参考译文] UCC21750:连接到 TI TXS0108E PWM 时 UCC21750输入异常
    Other Parts Discussed in Thread: UCC21750, TXS0108E
    https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1427454/ucc21750-ucc21750-input-abnormal-when-connecting…
  • [参考译文] TXS0108E:IO 级兼容性
    Other Parts Discussed in Thread: LSF0102, SN74LVC244A
    https://e2e.ti.com/support/logic-group/logic/f/logic-forum/1425640/txs0108e-io-level-compatibility
    器件型号:TXS0108E
    主题中讨论的其他器件:LSF0102SN74L…
  • TXS0108E: TXS0108E两路电源的相关问题
    Part Number: TXS0108E
    工程师你好,
    我们目前选用TXS0108EPWR芯片,用来将1.8V的信号和3.3V的信号进行相互转换。
    目前芯片的VCCA接1.8V,VCCB接3.3V。
    请问VCCA与VCCB的两个电源,有没有上电时序的要求呢?
    感谢。
  • [参考译文] TXS0108E:I2C 低电平高达0.6V 甚至更高
    Other Parts Discussed in Thread: TXS0108E, TCA9800, TS5A23159
    https://e2e.ti.com/support/logic-group/logic/f/logic-forum/1401751/txs0108e-i2c-low-level-up-to-0-6v-or-even-higher
    器件型号:TXS0108E
  • [参考译文] TXS0108E:睡眠模式工作异常
    https://e2e.ti.com/support/logic-group/logic/f/logic-forum/1404912/txs0108e-sleep-mode-work-abnormal
    器件型号:TXS0108E
    工具与软件:
    目前、我们的低功耗门铃产品使用 TXS0108E (连接到…
  • [参考译文] TXS0108E:TXS0108E 是否与 ADG3308BCBZ-1-RL7引脚相同?
    Other Parts Discussed in Thread: TXS0108E, TXB0108
    https://e2e.ti.com/support/logic-group/logic/f/logic-forum/1401580/txs0108e-is-txs0108e-p2p-with-adg3308bcbz-1-rl7
    器件型号:TXS0108E
    主题中讨论的其他器件:
  • TXS0108E: TXS0108转换问题
    我们在调试过程中发现推挽模式下B端口输入信号1MHZ时钟信号上下沿几个ns,A端口输出信号下沿达到200ns左右,A端口PCB走线不到50mm,这是怎么回事?我看了一下手册,手册上有对输入信号上下沿的要求
    下图有标注输出信号上下沿,但是实际没有表格和文字说明输出信号能达到的性能效果,只对输入信号又上下沿要求?下沿时间太长会限制信号频率大小?
  • [参考译文] TXS0108E:应用问题。
    https://e2e.ti.com/support/logic-group/logic/f/logic-forum/1401318/txs0108e-application-issues
    器件型号:TXS0108E
    工具与软件:
    嗨、团队:
    通过使用 TXS0108E、MCU 控制引脚 OE、在睡眠模式下…
  • [参考译文] TXS0108E-Q1:是否适用于 MII 模式?
    Other Parts Discussed in Thread: LSF0108, TXS0108E, TXS0108E-Q1, TXV0108-Q1, LSF0108-Q1
    https://e2e.ti.com/support/logic-group/logic/f/logic-forum/1399723/txs0108e-q1-is-suitable-for-mii-mode
  • TXS0108E: 推挽最大速率110Mbps怎么实现?
    TXS0108标注支持Push pull速率最高到110Mbps,请问是在什么情况下才能达到的?datasheet关于spec描述里没有写哪种工况最大能到110Mbps,比如VCCA=1.8V,VCCB=3.3V时,datashheet上写的推挽最大速率为60Mbps,与110Mbps相差也太远了。
    而且在相关问题下TI工程师说“data rate确实和很多因素有关,比如您提到的delay,rise time /fall time. 所以我们如果根据delay…
  • TXS0108E: 推挽最大支持速率在什么情况下能实现?
  • [参考译文] TXS0108E:设计疑问
    Other Parts Discussed in Thread: TXU0204, TXU0304, TXU0104
    https://e2e.ti.com/support/logic-group/logic/f/logic-forum/1394845/txs0108e-design-queries
    器件型号:TXS0108E
    主题中讨论的其他器件:TXU0304TXU0104、TXU0204…
  • [参考译文] TXS0108E:用于 PS/2鼠标应用的电压转换
    Other Parts Discussed in Thread: TXS0108E, LSF0102, LSF0002
    https://e2e.ti.com/support/logic-group/logic/f/logic-forum/1397310/txs0108e-voltage-translation-for-ps-2-mouse-applications
    器件型号:TXS…
  • [参考译文] TXS0108E:TXS0108应该如何进入推挽模式
    https://e2e.ti.com/support/logic-group/logic/f/logic-forum/1397643/txs0108e-how-should-txs0108-enter-push-pull-mode
    器件型号:TXS0108E
    工具与软件:
    尊敬的支持团队、
    我的客户使用的 是 TXS0108驱动8通道电平转换、但是当端口输入信号‘s 频率 超过1MHz…
  • TXS0108E: 请问是否有RGMII高速通讯的电平转换芯片推荐?
    Other Parts Discussed in Thread: TXV0108-Q1, TXV0106-Q1
    工程师你好,
    之前我们一直使用TXS0108做低速通讯的电平转换,目前我们的业务是:
    主控芯片的RGMII以太网是1.8V的,但是对应的以太网PHY芯片的RGMII最低电压只能到2.5V。
    请问是否有合适的高速电平转换芯片推荐呢?
    感谢。
  • TXS0108E: TXS0108E开漏输入输出问题
    最近在测试TXS0108E时发现开漏模式有点问题,具体描述如下:
    1、通过FPGA输出1MHz波形(输出信号=0或z,模拟1MHz开漏信号),外部上拉到VCCA的电阻R1=1K
    2、TXS0108E的VCCA=3.3V,VCCB=5V,输出端B端口上拉1K到VCCB
    3、测试波形发现输入端波形弟弟阿平被抬高到了几百mV,输出端的5V波形VPP实际只有3V的样子,而且低电平被抬高到了1.25V
    当波形改为100KHz时,波形比较理想。
    在保持1MHz条件下…
  • [参考译文] DP83867IR:不能使用 USB-2-MDIO 软件读取或写入 DP83867IR 芯片的寄存器
    Other Parts Discussed in Thread: USB-2-MDIO, DP83867IR, TXS-EVM, TXS0108E
    https://e2e.ti.com/support/interface-group/interface/f/interface-forum/1378437/dp83867ir-the-register-of-dp83867ir-chip…
1 2 3 4 5 »
